[postgis-tickets] r16794 - Do not define PERL twice in the same Makefile
Sandro Santilli strk at kbt.io
Fri Sep 14 06:57:00 PDT 2018
Author: strk
Date: 2018-09-14 06:57:00 -0700 (Fri, 14 Sep 2018)
New Revision: 16794
   trunk/extensions/postgis/Makefile.in
   trunk/extensions/postgis_raster/Makefile.in
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2018-09-14 13:55:25 UTC (rev 16793)
+++ trunk/extensions/postgis/Makefile.in	2018-09-14 13:57:00 UTC (rev 16794)
@@ -5,7 +5,6 @@
 MINORVERSION  = @POSTGIS_MAJOR_VERSION at .@POSTGIS_MINOR_VERSION@
 MODULEPATH    = $$libdir/$(EXTENSION)-$(MINORVERSION)
 GREP = @GREP@
-PERL = @PERL@
 MICRO_NUMBER  = $(shell echo $(EXTVERSION) | \
 						$(PERL) -pe 's/\d.\d.(\d+)[a-zA-Z]*\d*/$1/'
@@ -81,7 +80,7 @@
 	$(MAKE) -C ../../raster/rt_pg sql_objs
 sql/raster_unpackage.sql: Makefile
-sql/raster_unpackage.sql: $(PERL) ../../utils/create_extension_unpackage.pl
+sql/raster_unpackage.sql: ../../utils/create_extension_unpackage.pl
 sql/raster_unpackage.sql: unpackage_raster_if_needed.sql
 sql/raster_unpackage.sql: $(RASTER_DROP_SCRIPTS) | sql
Modified: trunk/extensions/postgis_raster/Makefile.in
--- trunk/extensions/postgis_raster/Makefile.in	2018-09-14 13:55:25 UTC (rev 16793)
+++ trunk/extensions/postgis_raster/Makefile.in	2018-09-14 13:57:00 UTC (rev 16794)
@@ -5,7 +5,6 @@
 GREP = @GREP@
-PERL = @PERL@
