[postgis-tickets] r16795 - Remove more duplicated PERL assignments
Sandro Santilli strk at kbt.io
Fri Sep 14 07:32:40 PDT 2018
Author: strk
Date: 2018-09-14 07:32:40 -0700 (Fri, 14 Sep 2018)
New Revision: 16795
   trunk/extensions/address_standardizer/Makefile.in
   trunk/extensions/postgis/Makefile.in
   trunk/extensions/postgis_raster/Makefile.in
   trunk/extensions/postgis_sfcgal/Makefile.in
   trunk/extensions/postgis_topology/Makefile.in
Modified: trunk/extensions/address_standardizer/Makefile.in
--- trunk/extensions/address_standardizer/Makefile.in	2018-09-14 13:57:00 UTC (rev 16794)
+++ trunk/extensions/address_standardizer/Makefile.in	2018-09-14 14:32:40 UTC (rev 16795)
@@ -29,7 +29,6 @@
 # SQL preprocessor
 SQLPP = @SQLPP@
 GREP=@GREP@
-PERL=@PERL@
 EXTVERSION    = @POSTGIS_LIB_VERSION@
 MINORVERSION  = @POSTGIS_MAJOR_VERSION at .@POSTGIS_MINOR_VERSION@
 MODULE_big = address_standardizer
@@ -62,10 +61,6 @@
 PGVER := $(shell $(PG_CONFIG) --version)
-# Set PERL _after_ the include of PGXS
-PERL=@PERL@
 # Borrow the $libdir substitution from PGXS but customise by running the preprocessor
 # and adding the version number
 sql/%.sql: %.sql.in
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2018-09-14 13:57:00 UTC (rev 16794)
+++ trunk/extensions/postgis/Makefile.in	2018-09-14 14:32:40 UTC (rev 16795)
@@ -55,7 +55,6 @@
 	../../raster/rt_pg/rtpostgis_drop.sql \
 	../../raster/rt_pg/uninstall_rtpostgis.sql
-#DOCS         = $(wildcard ../../doc/html/*.html)
 PG_CONFIG    = @PG_CONFIG@
 SQL_BITS     = $(wildcard sql/*.sql)
Modified: trunk/extensions/postgis_raster/Makefile.in
--- trunk/extensions/postgis_raster/Makefile.in	2018-09-14 13:57:00 UTC (rev 16794)
+++ trunk/extensions/postgis_raster/Makefile.in	2018-09-14 14:32:40 UTC (rev 16795)
@@ -47,7 +47,6 @@
 EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS = \
 	sql/rtpostgis.sql
Modified: trunk/extensions/postgis_sfcgal/Makefile.in
--- trunk/extensions/postgis_sfcgal/Makefile.in	2018-09-14 13:57:00 UTC (rev 16794)
+++ trunk/extensions/postgis_sfcgal/Makefile.in	2018-09-14 14:32:40 UTC (rev 16795)
@@ -4,7 +4,6 @@
 GREP = @GREP@
-PERL = @PERL@
 MICRO_NUMBER  = $(shell echo $(EXTVERSION) | \
 						$(PERL) -pe 's/\d.\d.(\d+)[a-zA-Z]*\d*/$1/'
Modified: trunk/extensions/postgis_topology/Makefile.in
--- trunk/extensions/postgis_topology/Makefile.in	2018-09-14 13:57:00 UTC (rev 16794)
+++ trunk/extensions/postgis_topology/Makefile.in	2018-09-14 14:32:40 UTC (rev 16795)
@@ -4,7 +4,6 @@
 GREP = @GREP@
-PERL = @PERL@
 MICRO_NUMBER  = $(shell echo $(EXTVERSION) | sed "s/[0-9]\.[0-9]\.\([0-9]*\)[a-zA-Z]*[0-9]*/\1/")
 PREREL_NUMBER = $(shell echo $(EXTVERSION) | \
