[postgis-tickets] r16799 - Use qualified names in topology extension install
Raul raul at rmr.ninja
Fri Sep 14 08:30:58 PDT 2018
Author: algunenano
Date: 2018-09-14 08:30:57 -0700 (Fri, 14 Sep 2018)
New Revision: 16799
   branches/2.3/NEWS
   branches/2.3/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
References #4160
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2018-09-14 15:30:20 UTC (rev 16798)
+++ branches/2.3/NEWS	2018-09-14 15:30:57 UTC (rev 16799)
@@ -7,6 +7,7 @@
   - #4074, Disable interrupt tests by default (Regina Obe)
   - #3997, fix bug in lwgeom_median and avoid division by zero (Raúl Marín)
   - #4093, Inconsistent results from qsort callback (yugr)
+  - #4160, Use qualified names in topology extension install (Raúl Marín)
 PostGIS 2.3.7
Modified: branches/2.3/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
--- branches/2.3/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in	2018-09-14 15:30:20 UTC (rev 16798)
+++ branches/2.3/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in	2018-09-14 15:30:57 UTC (rev 16799)
@@ -1,2 +1,2 @@
-SELECT pg_catalog.pg_extension_config_dump('topology', '');
-SELECT pg_catalog.pg_extension_config_dump('layer', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.topology', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.layer', '');
