[postgis-tickets] r16800 - Use qualified names in topology extension install
Raul raul at rmr.ninja
Fri Sep 14 08:38:30 PDT 2018
Author: algunenano
Date: 2018-09-14 08:38:30 -0700 (Fri, 14 Sep 2018)
New Revision: 16800
   branches/2.4/NEWS
   branches/2.4/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
References #4160
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2018-09-14 15:30:57 UTC (rev 16799)
+++ branches/2.4/NEWS	2018-09-14 15:38:30 UTC (rev 16800)
@@ -2,9 +2,9 @@
 2018/xx/xx
   * Bug Fixes and Enhancements
+  - #4160, Use qualified names in topology extension install (Raúl Marín)
 PostGIS 2.4.5
 2018/09/12
Modified: branches/2.4/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
--- branches/2.4/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in	2018-09-14 15:30:57 UTC (rev 16799)
+++ branches/2.4/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in	2018-09-14 15:38:30 UTC (rev 16800)
@@ -1,2 +1,2 @@
-SELECT pg_catalog.pg_extension_config_dump('topology', '');
-SELECT pg_catalog.pg_extension_config_dump('layer', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.topology', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.layer', '');
