[postgis-tickets] r16801 - Use qualified names in topology extension install
Raul raul at rmr.ninja
Fri Sep 14 08:39:56 PDT 2018
Author: algunenano
Date: 2018-09-14 08:39:56 -0700 (Fri, 14 Sep 2018)
New Revision: 16801
   trunk/NEWS
   trunk/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
Closes #4160
Closes https://github.com/postgis/postgis/pull/300
Modified: trunk/NEWS
--- trunk/NEWS	2018-09-14 15:38:30 UTC (rev 16800)
+++ trunk/NEWS	2018-09-14 15:39:56 UTC (rev 16801)
@@ -16,6 +16,7 @@
   - #4173, Fix undefined behaviour in ptarray_segmentize2d (Raúl Marín)
   - #4176, ST_Intersects supports GEOMETRYCOLLECTION (Darafei Praliaskouski)
   - #4177, Postgres 12 disallows variable length arrays in C (Laurenz Albe)
+  - #4160, Use qualified names in topology extension install (Raúl Marín)
 PostGIS 2.5.0rc1
 2018/08/19
Modified: trunk/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
--- trunk/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in	2018-09-14 15:38:30 UTC (rev 16800)
+++ trunk/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in	2018-09-14 15:39:56 UTC (rev 16801)
@@ -1,2 +1,2 @@
-SELECT pg_catalog.pg_extension_config_dump('topology', '');
-SELECT pg_catalog.pg_extension_config_dump('layer', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.topology', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.layer', '');
