[postgis-tickets] r16802 - Use qualified names in topology extension install
Raul raul at rmr.ninja
Fri Sep 14 09:13:29 PDT 2018
Author: algunenano
Date: 2018-09-14 09:13:29 -0700 (Fri, 14 Sep 2018)
New Revision: 16802
   branches/2.5/NEWS
   branches/2.5/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
References #4160
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2018-09-14 15:39:56 UTC (rev 16801)
+++ branches/2.5/NEWS	2018-09-14 16:13:29 UTC (rev 16802)
@@ -8,6 +8,7 @@
   - #4164, Parse error on incorrectly nested GeoJSON input (Paul Ramsey)
   - #4176, ST_Intersects supports GEOMETRYCOLLECTION (Darafei Praliaskouski)
   - #4177, Postgres 12 disallows variable length arrays in C (Laurenz Albe)
+  - #4160, Use qualified names in topology extension install (Raúl Marín)
 PostGIS 2.5.0rc1
 2018/08/19
Modified: branches/2.5/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
--- branches/2.5/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in	2018-09-14 15:39:56 UTC (rev 16801)
+++ branches/2.5/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in	2018-09-14 16:13:29 UTC (rev 16802)
@@ -1,2 +1,2 @@
-SELECT pg_catalog.pg_extension_config_dump('topology', '');
-SELECT pg_catalog.pg_extension_config_dump('layer', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.topology', '');
+SELECT pg_catalog.pg_extension_config_dump('topology.layer', '');
