[postgis-tickets] [PostGIS] #4180: liblwgeom.h:2378:10: fatal error: lwinline.h: No such file or directory
PostGIS trac at osgeo.org
Sun Sep 16 08:11:43 PDT 2018
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  2.4.x
Resolution:                         |   Keywords:
Comment (by robe):
 It appears that in r16342 the raster make file was changed to include
 these lines at the top.
 CC=@CC@
 CFLAGS=-I../liblwgeom @CFLAGS@ @WARNFLAGS@
 LDFLAGS = @LDFLAGS@
  all: @RT_CORE_LIB@ @RT_PG_LIB@ @RT_LOADER@ @RT_POSTGIS_SQL@
 with note:
 Address configure issues for unusual CC/CFLAGS
 Patch by Raúl Marín Rodríguez.
 Closes #3995
 Closes https://github.com/postgis/postgis/pull/195
 I know this change was done a while ago - in January, but could be only
 showing now because the includes between 3.0 and 2.5 are tripping each
 other.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4180#comment:3>
