[postgis-tickets] [PostGIS] #4180: liblwgeom.h:2378:10: fatal error: lwinline.h: No such file or directory
PostGIS trac at osgeo.org
Sun Sep 16 08:47:37 PDT 2018
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  2.4.x
Resolution:                         |   Keywords:
Comment (by Algunenano):
 I think that `rtpostgis.c` uses a different set of flags, defined in
 `raster/rt_pg/Makefile.in`. The problem there is that the include of
 `liblwgeom` directory should be first, not in the middle.
 For example, this is the compilation command that fails:
 05:29:34 cc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-
 after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-
 security -fno-strict-aliasing -fwrapv -Wno-unused-command-line-argument
 -O2 -pipe  -fstack-protector -fno-strict-aliasing -fPIC -DPIC
 -I/usr/local/include -I/usr/local/include  -I/usr/local/include/libxml2
 -I/usr/include -I/usr/local/include -DHAVE_SFCGAL    -g -O2
 -I/usr/local/include "-I../../liblwgeom" "-I../../libpgcommon"
 -I/usr/local/include -I../rt_core -I. -I./
 -I/usr/local/include/postgresql/server
 -I/usr/local/include/postgresql/internal  -I/usr/local/include
 -I/usr/local/include -I/usr/local/include  -c -o rtpostgis.o rtpostgis.c
 The first include there should be `"-I../../liblwgeom"` not
 `-I/usr/local/include`.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4180#comment:4>
