[postgis-tickets] r17417 - Add missing files from previous commits
Paul Ramsey pramsey at cleverelephant.ca
Mon Apr 29 09:16:56 PDT 2019
Author: pramsey
Date: 2019-04-29 09:16:56 -0700 (Mon, 29 Apr 2019)
New Revision: 17417
Added:
   trunk/postgis/lwgeom_out_geojson.c
   trunk/regress/core/out_geojson.sql
   trunk/regress/core/out_geojson_expected
References #1833 and #3687
Added: trunk/postgis/lwgeom_out_geojson.c
--- trunk/postgis/lwgeom_out_geojson.c	                        (rev 0)
+++ trunk/postgis/lwgeom_out_geojson.c	2019-04-29 16:16:56 UTC (rev 17417)
@@ -0,0 +1,706 @@
+/* PostgreSQL headers */
+#include "postgres.h"
+#include "funcapi.h"
+#include "miscadmin.h"
+#include "access/htup_details.h"
+#include "access/transam.h"
+#include "catalog/pg_type.h"
+#include "executor/spi.h"
+#include "lib/stringinfo.h"
+#include "libpq/pqformat.h"
+#include "mb/pg_wchar.h"
+#include "parser/parse_coerce.h"
+#include "utils/array.h"
+#include "utils/builtins.h"
+#include "utils/date.h"
+#include "utils/datetime.h"
+#include "utils/lsyscache.h"
+#include "utils/json.h"
+#include "utils/jsonapi.h"
+#include "utils/typcache.h"
+#include "utils/syscache.h"
+/* PostGIS headers */
+#include "../postgis_config.h"
+#include "lwgeom_pg.h"
+#include "lwgeom_log.h"
+#include "liblwgeom.h"
+typedef enum					/* type categories for datum_to_json */
+	JSONTYPE_NULL,				/* null, so we didn't bother to identify */
+	JSONTYPE_BOOL,				/* boolean (built-in types only) */
+	JSONTYPE_NUMERIC,			/* numeric (ditto) */
+	JSONTYPE_DATE,				/* we use special formatting for datetimes */
+	JSONTYPE_TIMESTAMP,
+	JSONTYPE_TIMESTAMPTZ,
+	JSONTYPE_JSON,				/* JSON itself (and JSONB) */
+	JSONTYPE_ARRAY,				/* array */
+	JSONTYPE_COMPOSITE,			/* composite */
+	JSONTYPE_CAST,				/* something with an explicit cast to JSON */
+	JSONTYPE_OTHER				/* all else */
+} JsonTypeCategory;
+static void array_dim_to_json(StringInfo result, int dim, int ndims, int *dims,
+				  Datum *vals, bool *nulls, int *valcount,
+				  JsonTypeCategory tcategory, Oid outfuncoid,
+				  bool use_line_feeds);
+static void array_to_json_internal(Datum array, StringInfo result,
+static void composite_to_geojson(Datum composite,
+					 char *geom_column_name, int32 maxdecimaldigits,
+					 StringInfo result, bool use_line_feeds);
+static void composite_to_json(Datum composite, StringInfo result,
+static void datum_to_json(Datum val, bool is_null, StringInfo result,
+						  bool key_scalar);
+static void json_categorize_type(Oid typoid,
+								 JsonTypeCategory *tcategory,
+								 Oid *outfuncoid);
+static char * postgis_JsonEncodeDateTime(char *buf, Datum value, Oid typid);
+static int postgis_time2tm(TimeADT time, struct pg_tm *tm, fsec_t *fsec);
+static int postgis_timetz2tm(TimeTzADT *time, struct pg_tm *tm, fsec_t *fsec, int *tzp);
+Datum row_to_geojson(PG_FUNCTION_ARGS);
+extern Datum LWGEOM_asGeoJson(PG_FUNCTION_ARGS);
+ * SQL function row_to_geojson(row)
+PG_FUNCTION_INFO_V1(ST_AsGeoJsonRow);
+Datum
+ST_AsGeoJsonRow(PG_FUNCTION_ARGS)
+	Datum		array = PG_GETARG_DATUM(0);
+	text        *geom_column_text = PG_GETARG_TEXT_P(1);
+	int32       maxdecimaldigits = PG_GETARG_INT32(2);
+	bool		do_pretty = PG_GETARG_BOOL(3);
+	StringInfo	result;
+	char        *geom_column = text_to_cstring(geom_column_text);
+	if (strlen(geom_column) == 0)
+		geom_column = NULL;
+	result = makeStringInfo();
+	composite_to_geojson(array, geom_column, maxdecimaldigits, result, do_pretty);
+	PG_RETURN_TEXT_P(cstring_to_text_with_len(result->data, result->len));
+ * Turn a composite / record into GEOJSON.
+static void
+composite_to_geojson(Datum composite, char *geom_column_name, int32 maxdecimaldigits,
+	HeapTupleHeader td;
+	Oid			tupType;
+	int32		tupTypmod;
+	TupleDesc	tupdesc;
+	HeapTupleData tmptup,
+			   *tuple;
+	int			i;
+	bool		needsep = false;
+	const char *sep;
+	StringInfo	props = makeStringInfo();
+	bool		geom_column_found = false;
+	Oid         geom_oid = postgis_geometry_oid();
+	Oid         geog_oid = postgis_geography_oid();
+	sep = use_line_feeds ? ",\n " : ", ";
+	td = DatumGetHeapTupleHeader(composite);
+	/* Extract rowtype info and find a tupdesc */
+	tupType = HeapTupleHeaderGetTypeId(td);
+	tupTypmod = HeapTupleHeaderGetTypMod(td);
+	tupdesc = lookup_rowtype_tupdesc(tupType, tupTypmod);
+	/* Build a temporary HeapTuple control structure */
+	tmptup.t_len = HeapTupleHeaderGetDatumLength(td);
+	tmptup.t_data = td;
+	tuple = &tmptup;
+	appendStringInfoString(result, "{\"type\": \"Feature\", \"geometry\": ");
+	for (i = 0; i < tupdesc->natts; i++)
+		Datum		val;
+		bool		isnull;
+		char	   *attname;
+		JsonTypeCategory tcategory;
+		Oid			outfuncoid;
+		Form_pg_attribute att = TupleDescAttr(tupdesc, i);
+		bool        is_geom_column = false;
+		if (att->attisdropped)
+			continue;
+		attname = NameStr(att->attname);
+		/* Use the column name if provided, use the first geometry column otherwise */
+		if (geom_column_name)
+			is_geom_column = (strcmp(attname, geom_column_name) == 0);
+		else
+			is_geom_column = (att->atttypid == geom_oid || att->atttypid == geog_oid);
+		if ((!geom_column_found) && is_geom_column)
+			/* this is our geom column */
+			geom_column_found = true;
+			val = heap_getattr(tuple, i + 1, tupdesc, &isnull);
+			if (!isnull)
+				appendStringInfo(result, "%s",
+					TextDatumGetCString(DirectFunctionCall2(LWGEOM_asGeoJson, val, Int32GetDatum(maxdecimaldigits))));
+			else
+				appendStringInfoString(result, "{\"type\": null}");
+		else
+			if (needsep)
+				appendStringInfoString(props, sep);
+			needsep = true;
+			escape_json(props, attname);
+			appendStringInfoString(props, ": ");
+			if (isnull)
+				tcategory = JSONTYPE_NULL;
+				outfuncoid = InvalidOid;
+			else
+				json_categorize_type(att->atttypid, &tcategory, &outfuncoid);
+			datum_to_json(val, isnull, props, tcategory, outfuncoid, false);
+	if (!geom_column_found)
+		ereport(ERROR,
+				(errcode(ERRCODE_INVALID_PARAMETER_VALUE),
+				 errmsg("geometry column is missing")));
+	appendStringInfoString(result, ", \"properties\": {");
+	appendStringInfo(result, "%s", props->data);
+	appendStringInfoString(result, "}}");
+	ReleaseTupleDesc(tupdesc);
+ * The following code was all cut and pasted directly from
+ * json.c from the Postgres source tree as of 2019-03-28.
+ * It would be far better if these were exported from the
+ * backend so we could just use them here. Maybe someday.
+ * Determine how we want to print values of a given type in datum_to_json.
+ * Given the datatype OID, return its JsonTypeCategory, as well as the type's
+ * output function OID.  If the returned category is JSONTYPE_CAST, we
+ * return the OID of the type->JSON cast function instead.
+static void
+json_categorize_type(Oid typoid,
+					 Oid *outfuncoid)
+	bool		typisvarlena;
+	/* Look through any domain */
+	typoid = getBaseType(typoid);
+	*outfuncoid = InvalidOid;
+	 * We need to get the output function for everything except date and
+	 * timestamp types, array and composite types, booleans, and non-builtin
+	 * types where there's a cast to json.
+	switch (typoid)
+		case BOOLOID:
+			*tcategory = JSONTYPE_BOOL;
+			break;
+		case INT2OID:
+		case INT4OID:
+		case INT8OID:
+		case FLOAT4OID:
+		case FLOAT8OID:
+		case NUMERICOID:
+			getTypeOutputInfo(typoid, outfuncoid, &typisvarlena);
+			*tcategory = JSONTYPE_NUMERIC;
+			break;
+		case DATEOID:
+			*tcategory = JSONTYPE_DATE;
+			break;
+		case TIMESTAMPOID:
+			*tcategory = JSONTYPE_TIMESTAMP;
+			break;
+		case TIMESTAMPTZOID:
+			*tcategory = JSONTYPE_TIMESTAMPTZ;
+			break;
+		case JSONOID:
+		case JSONBOID:
+			*tcategory = JSONTYPE_JSON;
+			break;
+		default:
+			/* Check for arrays and composites */
+			if (OidIsValid(get_element_type(typoid)) || typoid == ANYARRAYOID
+				|| typoid == RECORDARRAYOID)
+				*tcategory = JSONTYPE_ARRAY;
+			else if (type_is_rowtype(typoid))	/* includes RECORDOID */
+				*tcategory = JSONTYPE_COMPOSITE;
+			else
+				/* It's probably the general case ... */
+				*tcategory = JSONTYPE_OTHER;
+				/* but let's look for a cast to json, if it's not built-in */
+				if (typoid >= FirstNormalObjectId)
+					Oid			castfunc;
+					CoercionPathType ctype;
+					ctype = find_coercion_pathway(JSONOID, typoid,
+												  COERCION_EXPLICIT,
+												  &castfunc);
+					if (ctype == COERCION_PATH_FUNC && OidIsValid(castfunc))
+						*tcategory = JSONTYPE_CAST;
+						*outfuncoid = castfunc;
+					else
+						/* non builtin type with no cast */
+				else
+					/* any other builtin type */
+			break;
+ * Turn a Datum into JSON text, appending the string to "result".
+ * tcategory and outfuncoid are from a previous call to json_categorize_type,
+ * except that if is_null is true then they can be invalid.
+ * If key_scalar is true, the value is being printed as a key, so insist
+ * it's of an acceptable type, and force it to be quoted.
+static void
+datum_to_json(Datum val, bool is_null, StringInfo result,
+			  bool key_scalar)
+	char	   *outputstr;
+	text	   *jsontext;
+	check_stack_depth();
+	/* callers are expected to ensure that null keys are not passed in */
+	Assert(!(key_scalar && is_null));
+	if (is_null)
+		appendStringInfoString(result, "null");
+		return;
+	if (key_scalar &&
+		(tcategory == JSONTYPE_ARRAY ||
+		 tcategory == JSONTYPE_COMPOSITE ||
+		 tcategory == JSONTYPE_JSON ||
+		 tcategory == JSONTYPE_CAST))
+		ereport(ERROR,
+				 errmsg("key value must be scalar, not array, composite, or json")));
+	switch (tcategory)
+		case JSONTYPE_ARRAY:
+			array_to_json_internal(val, result, false);
+			break;
+		case JSONTYPE_COMPOSITE:
+			composite_to_json(val, result, false);
+			break;
+		case JSONTYPE_BOOL:
+			outputstr = DatumGetBool(val) ? "true" : "false";
+			if (key_scalar)
+				escape_json(result, outputstr);
+			else
+				appendStringInfoString(result, outputstr);
+			break;
+		case JSONTYPE_NUMERIC:
+			outputstr = OidOutputFunctionCall(outfuncoid, val);
+			 * Don't call escape_json for a non-key if it's a valid JSON
+			 * number.
+			if (!key_scalar && IsValidJsonNumber(outputstr, strlen(outputstr)))
+			else
+			pfree(outputstr);
+			break;
+		case JSONTYPE_DATE:
+				char		buf[MAXDATELEN + 1];
+				postgis_JsonEncodeDateTime(buf, val, DATEOID);
+				appendStringInfo(result, "\"%s\"", buf);
+			break;
+		case JSONTYPE_TIMESTAMP:
+				postgis_JsonEncodeDateTime(buf, val, TIMESTAMPOID);
+			break;
+		case JSONTYPE_TIMESTAMPTZ:
+				postgis_JsonEncodeDateTime(buf, val, TIMESTAMPTZOID);
+			break;
+		case JSONTYPE_JSON:
+			/* JSON and JSONB output will already be escaped */
+			pfree(outputstr);
+			break;
+		case JSONTYPE_CAST:
+			/* outfuncoid refers to a cast function, not an output function */
+			jsontext = DatumGetTextPP(OidFunctionCall1(outfuncoid, val));
+			outputstr = text_to_cstring(jsontext);
+			pfree(outputstr);
+			pfree(jsontext);
+			break;
+		default:
+			pfree(outputstr);
+			break;
+ * Turn an array into JSON.
+static void
+array_to_json_internal(Datum array, StringInfo result, bool use_line_feeds)
+	ArrayType  *v = DatumGetArrayTypeP(array);
+	Oid			element_type = ARR_ELEMTYPE(v);
+	int		   *dim;
+	int			ndim;
+	int			nitems;
+	int			count = 0;
+	Datum	   *elements;
+	bool	   *nulls;
+	int16		typlen;
+	bool		typbyval;
+	char		typalign;
+	Oid			outfuncoid;
+	ndim = ARR_NDIM(v);
+	dim = ARR_DIMS(v);
+	nitems = ArrayGetNItems(ndim, dim);
+	if (nitems <= 0)
+		appendStringInfoString(result, "[]");
+		return;
+	get_typlenbyvalalign(element_type,
+						 &typlen, &typbyval, &typalign);
+	json_categorize_type(element_type,
+						 &tcategory, &outfuncoid);
+	deconstruct_array(v, element_type, typlen, typbyval,
+					  typalign, &elements, &nulls,
+					  &nitems);
+	array_dim_to_json(result, 0, ndim, dim, elements, nulls, &count, tcategory,
+					  outfuncoid, use_line_feeds);
+	pfree(elements);
+	pfree(nulls);
+ * Turn a composite / record into JSON.
+static void
+composite_to_json(Datum composite, StringInfo result, bool use_line_feeds)
+	Oid			tupType;
+	int32		tupTypmod;
+			   *tuple;
+	int			i;
+	const char *sep;
+	sep = use_line_feeds ? ",\n " : ",";
+	tuple = &tmptup;
+	appendStringInfoChar(result, '{');
+		Datum		val;
+		bool		isnull;
+		char	   *attname;
+		Oid			outfuncoid;
+			continue;
+		if (needsep)
+			appendStringInfoString(result, sep);
+		needsep = true;
+		escape_json(result, attname);
+		appendStringInfoChar(result, ':');
+		if (isnull)
+		else
+		datum_to_json(val, isnull, result, tcategory, outfuncoid, false);
+	appendStringInfoChar(result, '}');
+ * Process a single dimension of an array.
+ * If it's the innermost dimension, output the values, otherwise call
+ * ourselves recursively to process the next dimension.
+static void
+array_dim_to_json(StringInfo result, int dim, int ndims, int *dims, Datum *vals,
+				  bool *nulls, int *valcount, JsonTypeCategory tcategory,
+				  Oid outfuncoid, bool use_line_feeds)
+	int			i;
+	const char *sep;
+	Assert(dim < ndims);
+	appendStringInfoChar(result, '[');
+	for (i = 1; i <= dims[dim]; i++)
+		if (i > 1)
+		if (dim + 1 == ndims)
+			datum_to_json(vals[*valcount], nulls[*valcount], result, tcategory,
+						  outfuncoid, false);
+			(*valcount)++;
+		else
+			 * Do we want line feeds on inner dimensions of arrays? For now
+			 * we'll say no.
+			array_dim_to_json(result, dim + 1, ndims, dims, vals, nulls,
+							  valcount, tcategory, outfuncoid, false);
+	appendStringInfoChar(result, ']');
+static int
+postgis_time2tm(TimeADT time, struct pg_tm *tm, fsec_t *fsec)
+	tm->tm_hour = time / USECS_PER_HOUR;
+	time -= tm->tm_hour * USECS_PER_HOUR;
+	tm->tm_min = time / USECS_PER_MINUTE;
+	time -= tm->tm_min * USECS_PER_MINUTE;
+	tm->tm_sec = time / USECS_PER_SEC;
+	time -= tm->tm_sec * USECS_PER_SEC;
+	*fsec = time;
+	return 0;
+static int
+postgis_timetz2tm(TimeTzADT *time, struct pg_tm *tm, fsec_t *fsec, int *tzp)
+	TimeOffset	trem = time->time;
+	tm->tm_hour = trem / USECS_PER_HOUR;
+	trem -= tm->tm_hour * USECS_PER_HOUR;
+	tm->tm_min = trem / USECS_PER_MINUTE;
+	trem -= tm->tm_min * USECS_PER_MINUTE;
+	tm->tm_sec = trem / USECS_PER_SEC;
+	*fsec = trem - tm->tm_sec * USECS_PER_SEC;
+	if (tzp != NULL)
+		*tzp = time->zone;
+	return 0;
+static char *
+postgis_JsonEncodeDateTime(char *buf, Datum value, Oid typid)
+	if (!buf)
+		buf = palloc(MAXDATELEN + 1);
+	switch (typid)
+		case DATEOID:
+				DateADT		date;
+				struct pg_tm tm;
+				date = DatumGetDateADT(value);
+				/* Same as date_out(), but forcing DateStyle */
+				if (DATE_NOT_FINITE(date))
+					EncodeSpecialDate(date, buf);
+				else
+					j2date(date + POSTGRES_EPOCH_JDATE,
+						   &(tm.tm_year), &(tm.tm_mon), &(tm.tm_mday));
+					EncodeDateOnly(&tm, USE_XSD_DATES, buf);
+			break;
+		case TIMEOID:
+				TimeADT		time = DatumGetTimeADT(value);
+				struct pg_tm tt,
+						   *tm = &tt;
+				fsec_t		fsec;
+				/* Same as time_out(), but forcing DateStyle */
+				postgis_time2tm(time, tm, &fsec);
+				EncodeTimeOnly(tm, fsec, false, 0, USE_XSD_DATES, buf);
+			break;
+		case TIMETZOID:
+				TimeTzADT  *time = DatumGetTimeTzADTP(value);
+				struct pg_tm tt,
+						   *tm = &tt;
+				fsec_t		fsec;
+				int			tz;
+				/* Same as timetz_out(), but forcing DateStyle */
+				postgis_timetz2tm(time, tm, &fsec, &tz);
+				EncodeTimeOnly(tm, fsec, true, tz, USE_XSD_DATES, buf);
+			break;
+				Timestamp	timestamp;
+				struct pg_tm tm;
+				fsec_t		fsec;
+				timestamp = DatumGetTimestamp(value);
+				/* Same as timestamp_out(), but forcing DateStyle */
+				if (TIMESTAMP_NOT_FINITE(timestamp))
+					EncodeSpecialTimestamp(timestamp, buf);
+				else if (timestamp2tm(timestamp, NULL, &tm, &fsec, NULL, NULL) == 0)
+					EncodeDateTime(&tm, fsec, false, 0, NULL, USE_XSD_DATES, buf);
+				else
+					ereport(ERROR,
+							(errcode(ERRCODE_DATETIME_VALUE_OUT_OF_RANGE),
+							 errmsg("timestamp out of range")));
+			break;
+				TimestampTz timestamp;
+				struct pg_tm tm;
+				int			tz;
+				fsec_t		fsec;
+				const char *tzn = NULL;
+				timestamp = DatumGetTimestampTz(value);
+				/* Same as timestamptz_out(), but forcing DateStyle */
+				else if (timestamp2tm(timestamp, &tz, &tm, &fsec, &tzn, NULL) == 0)
+					EncodeDateTime(&tm, fsec, true, tz, tzn, USE_XSD_DATES, buf);
+				else
+					ereport(ERROR,
+			break;
+		default:
+			elog(ERROR, "unknown jsonb value datetime type oid %d", typid);
+			return NULL;
+	return buf;
Added: trunk/regress/core/out_geojson.sql
--- trunk/regress/core/out_geojson.sql	                        (rev 0)
+++ trunk/regress/core/out_geojson.sql	2019-04-29 16:16:56 UTC (rev 17417)
@@ -0,0 +1,38 @@
+DROP TABLE IF EXISTS g;
+CREATE TABLE g (
+	g geometry,
+	i integer,
+	f real,
+	t text,
+	d date
+INSERT INTO g (g, i, f, t, d)
+VALUES ('POINT(42 42)', 1, 1.1, 'one', '2001-01-01');
+VALUES ('LINESTRING(42 42, 45 45)', 2, 2.2, 'two', '2002-02-02');
+VALUES ('POLYGON((42 42, 45 45, 45 42, 42 42))', 3, 3.3, 'three', '2003-03-03');
+VALUES ('GEOMETRYCOLLECTION(POINT(42 42))', 4, 4.4, 'four', '2004-04-04');
+INSERT INTO g VALUES ('POINT EMPTY', 5, 5.5, 'five', '2005-05-05');
+INSERT INTO g VALUES (NULL, 6, 6.6, 'six', '2006-06-06');
+INSERT INTO g VALUES ('GEOMETRYCOLLECTION(POINT EMPTY, POINT(1 2))', 7, 7.7, 'seven', '2007-07-07');
+SELECT 'gj01', i, ST_AsGeoJSON(g) AS g1
+	FROM g ORDER BY i;
+SELECT 'gj02', i, ST_AsGeoJSON(g.*) AS gj2
+SELECT 'gj03', i, to_json(g.*) AS rj3
+SELECT 'gj04', i, to_jsonb(g.*) AS rj4
+DROP TABLE g;
Added: trunk/regress/core/out_geojson_expected
--- trunk/regress/core/out_geojson_expected	                        (rev 0)
+++ trunk/regress/core/out_geojson_expected	2019-04-29 16:16:56 UTC (rev 17417)
@@ -0,0 +1,29 @@
+NOTICE:  table "g" does not exist, skipping
+gj01|1|{"type":"Point","coordinates":[42,42]}
+gj01|2|{"type":"LineString","coordinates":[[42,42],[45,45]]}
+gj01|3|{"type":"Polygon","coordinates":[[[42,42],[45,45],[45,42],[42,42]]]}
+gj01|4|{"type":"GeometryCollection","geometries":[{"type":"Point","coordinates":[42,42]}]}
+gj01|5|{"type":"Point","coordinates":[]}
+gj01|6|
+gj01|7|{"type":"GeometryCollection","geometries":[{"type":"Point","coordinates":[]},{"type":"Point","coordinates":[1,2]}]}
+gj02|1|{"type": "Feature", "geometry": {"type":"Point","coordinates":[42,42]}, "properties": {"i": 1, "f": 1.1, "t": "one", "d": "2001-01-01"}}
+gj02|2|{"type": "Feature", "geometry": {"type":"LineString","coordinates":[[42,42],[45,45]]}, "properties": {"i": 2, "f": 2.2, "t": "two", "d": "2002-02-02"}}
+gj02|3|{"type": "Feature", "geometry": {"type":"Polygon","coordinates":[[[42,42],[45,45],[45,42],[42,42]]]}, "properties": {"i": 3, "f": 3.3, "t": "three", "d": "2003-03-03"}}
+gj02|4|{"type": "Feature", "geometry": {"type":"GeometryCollection","geometries":[{"type":"Point","coordinates":[42,42]}]}, "properties": {"i": 4, "f": 4.4, "t": "four", "d": "2004-04-04"}}
+gj02|5|{"type": "Feature", "geometry": {"type":"Point","coordinates":[]}, "properties": {"i": 5, "f": 5.5, "t": "five", "d": "2005-05-05"}}
+gj02|6|{"type": "Feature", "geometry": {"type": null}, "properties": {"i": 6, "f": 6.6, "t": "six", "d": "2006-06-06"}}
+gj02|7|{"type": "Feature", "geometry": {"type":"GeometryCollection","geometries":[{"type":"Point","coordinates":[]},{"type":"Point","coordinates":[1,2]}]}, "properties": {"i": 7, "f": 7.7, "t": "seven", "d": "2007-07-07"}}
+gj03|1|{"g":{"type":"Point","coordinates":[42,42]},"i":1,"f":1.1,"t":"one","d":"2001-01-01"}
+gj03|2|{"g":{"type":"LineString","coordinates":[[42,42],[45,45]]},"i":2,"f":2.2,"t":"two","d":"2002-02-02"}
+gj03|3|{"g":{"type":"Polygon","coordinates":[[[42,42],[45,45],[45,42],[42,42]]]},"i":3,"f":3.3,"t":"three","d":"2003-03-03"}
+gj03|4|{"g":{"type":"GeometryCollection","geometries":[{"type":"Point","coordinates":[42,42]}]},"i":4,"f":4.4,"t":"four","d":"2004-04-04"}
+gj03|5|{"g":{"type":"Point","coordinates":[]},"i":5,"f":5.5,"t":"five","d":"2005-05-05"}
+gj03|6|{"g":null,"i":6,"f":6.6,"t":"six","d":"2006-06-06"}
+gj03|7|{"g":{"type":"GeometryCollection","geometries":[{"type":"Point","coordinates":[]},{"type":"Point","coordinates":[1,2]}]},"i":7,"f":7.7,"t":"seven","d":"2007-07-07"}
+gj04|1|{"d": "2001-01-01", "f": 1.1, "g": {"type": "Point", "coordinates": [42, 42]}, "i": 1, "t": "one"}
+gj04|2|{"d": "2002-02-02", "f": 2.2, "g": {"type": "LineString", "coordinates": [[42, 42], [45, 45]]}, "i": 2, "t": "two"}
+gj04|3|{"d": "2003-03-03", "f": 3.3, "g": {"type": "Polygon", "coordinates": [[[42, 42], [45, 45], [45, 42], [42, 42]]]}, "i": 3, "t": "three"}
+gj04|4|{"d": "2004-04-04", "f": 4.4, "g": {"type": "GeometryCollection", "geometries": [{"type": "Point", "coordinates": [42, 42]}]}, "i": 4, "t": "four"}
+gj04|5|{"d": "2005-05-05", "f": 5.5, "g": {"type": "Point", "coordinates": []}, "i": 5, "t": "five"}
+gj04|6|{"d": "2006-06-06", "f": 6.6, "g": null, "i": 6, "t": "six"}
+gj04|7|{"d": "2007-07-07", "f": 7.7, "g": {"type": "GeometryCollection", "geometries": [{"type": "Point", "coordinates": []}, {"type": "Point", "coordinates": [1, 2]}]}, "i": 7, "t": "seven"}
