[postgis-tickets] r17418 - Add json casts to doc, set json cast precision
Paul Ramsey pramsey at cleverelephant.ca
Tue Apr 30 09:45:35 PDT 2019
Author: pramsey
Date: 2019-04-30 09:45:35 -0700 (Tue, 30 Apr 2019)
New Revision: 17418
   trunk/doc/reference_output.xml
   trunk/doc/reference_type.xml
   trunk/postgis/lwgeom_export.c
to defaults used in other functions
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml	2019-04-29 16:16:56 UTC (rev 17417)
+++ trunk/doc/reference_output.xml	2019-04-30 16:45:35 UTC (rev 17418)
@@ -329,22 +329,22 @@
 		<funcsynopsis>
 			<funcprototype>
 				<funcdef>text <function>ST_AsGeoJSON</function></funcdef>
-				<paramdef><type>record </type> <parameter>feature</parameter></paramdef>
-				<paramdef choice="opt"><type>text </type> <parameter>geomcolumnname</parameter></paramdef>
+				<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
 				<paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits=15</parameter></paramdef>
-				<paramdef choice="opt"><type>boolean </type> <parameter>prettyprint=false</parameter></paramdef>
+				<paramdef choice="opt"><type>integer </type> <parameter>options=0</parameter></paramdef>
 			</funcprototype>
 			<funcprototype>
-				<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
+				<paramdef><type>geography </type> <parameter>geog</parameter></paramdef>
 			</funcprototype>
 			<funcprototype>
-				<paramdef><type>geography </type> <parameter>geog</parameter></paramdef>
+				<paramdef><type>record </type> <parameter>feature</parameter></paramdef>
+				<paramdef choice="opt"><type>text </type> <parameter>geomcolumnname</parameter></paramdef>
-				<paramdef choice="opt"><type>integer </type> <parameter>options=0</parameter></paramdef>
+				<paramdef choice="opt"><type>boolean </type> <parameter>prettyprint=false</parameter></paramdef>
 			</funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -377,12 +377,6 @@
 				</listitem>
 			  </itemizedlist>
 			</para>
-			<para>Version 1: ST_AsGeoJSON(geom) / maxdecimaldigits=15 version=1 options=0</para>
-			<para>Version 2: ST_AsGeoJSON(geom, maxdecimaldigits) / version=1 options=0</para>
-			<para>Version 3: ST_AsGeoJSON(geom, maxdecimaldigits, options) / version=1</para>
-			<para>Version 4: ST_AsGeoJSON(gj_version, geom) / maxdecimaldigits=15 options=0</para>
-			<para>Version 5: ST_AsGeoJSON(gj_version, geom, maxdecimaldigits) / options=0</para>
-			<para>Version 6: ST_AsGeoJSON(gj_version, geom, maxdecimaldigits, options)</para>
 			<para>Availability: 1.3.4</para>
 			<para>Availability: 1.5.0 geography support was introduced.</para>
Modified: trunk/doc/reference_type.xml
--- trunk/doc/reference_type.xml	2019-04-29 16:16:56 UTC (rev 17417)
+++ trunk/doc/reference_type.xml	2019-04-30 16:45:35 UTC (rev 17418)
@@ -143,6 +143,14 @@
 				<entry>text</entry>
 				<entry>automatic</entry>
 			  </row>
+			  <row>
+				<entry>json</entry>
+				<entry>automatic</entry>
+			  </row>
+			  <row>
+				<entry>jsonb</entry>
+			  </row>
 			</tbody>
 		</tgroup>
 		</informaltable>
Modified: trunk/postgis/lwgeom_export.c
--- trunk/postgis/lwgeom_export.c	2019-04-29 16:16:56 UTC (rev 17417)
+++ trunk/postgis/lwgeom_export.c	2019-04-30 16:45:35 UTC (rev 17418)
@@ -431,7 +431,7 @@
 	GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P(0);
 	LWGEOM *lwgeom = lwgeom_from_gserialized(geom);
-	char *geojson = lwgeom_to_geojson(lwgeom, NULL, 9, 0);
+	char *geojson = lwgeom_to_geojson(lwgeom, NULL, 15, 0);
 	text *result = cstring_to_text(geojson);
 	lwgeom_free(lwgeom);
 	pfree(geojson);
@@ -444,7 +444,7 @@
 	PG_RETURN_DATUM(DirectFunctionCall1(jsonb_in, PointerGetDatum(geojson)));
