[postgis-tickets] [SCM] PostGIS branch master updated. 939c30639e36c1d1c299bac589d38f369391b2ab
Thu Dec 12 07:56:12 PST 2019
the project "PostGIS".
       via  939c30639e36c1d1c299bac589d38f369391b2ab (commit)
      from  bbbd77d0b9504281ad19731316ae7dd0ad7d9f6f (commit)
revisions in full, below.
commit 939c30639e36c1d1c299bac589d38f369391b2ab
Author: Raúl Marín <git at rmr.ninja>
Date:   Thu Dec 12 16:11:34 2019 +0100
    ST_TileEnvelope: Improve precision by calculating the input bbox
    References #4600
    References #4602
    Closes https://github.com/postgis/postgis/pull/522
diff --git a/NEWS b/NEWS
index 10130b7..6139aa8 100644
--- a/NEWS
+++ b/NEWS
@@ -34,6 +34,7 @@ PostGIS 3.1.0
   - #4590, Fix pg_upgrade issue with st_linecrossingdirection (Raúl Marín)
   - #4592, Add missing CPPFLAGS in multiple Makefiles (Raúl Marín)
   - #4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
+  - #4600, Improve precision of ST_TileEnvelope (Raúl Marín)
 PostGIS 3.0.0
 2019/10/xx
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 1a02b0a..f866e49 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2059,6 +2059,7 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
 	   srid of the object is EPSG:3857. */
 	int32_t srid;
 	GBOX bbox;
+	LWGEOM *g = NULL;
 	POSTGIS_DEBUG(2, "ST_TileEnvelope called");
@@ -2067,9 +2068,17 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
 	y = PG_GETARG_INT32(2);
 	bounds = PG_GETARG_GSERIALIZED_P(3);
-	if(gserialized_get_gbox_p(bounds, &bbox) != LW_SUCCESS)
-		elog(ERROR, "%s: Empty bounds", __func__);
-	srid = gserialized_get_srid(bounds);
+	 * We deserialize the geometry and recalculate the bounding box here to get
+	 * 64b floating point precision. The serialized bbox has 32b float is not
+	 * precise enough with big numbers such as the ones used in the default
+	 * parameters, e.g: -20037508.3427892 is transformed into -20037510
+	g = lwgeom_from_gserialized(bounds);
+	if (lwgeom_calculate_gbox(g, &bbox) != LW_SUCCESS)
+		elog(ERROR, "%s: Unable to compute bbox", __func__);
+	srid = g->srid;
+	lwgeom_free(g);
 	margin = PG_GETARG_FLOAT8(4);
 	/* shrinking by more than 50% would eliminate the tile outright */
@@ -2099,7 +2108,7 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
 	 * 1 margin (100%) is the same as a single tile width
 	 * if the size of the tile with margins span more than the total number of tiles,
 	 * reset x1/x2 to the bounds
 	if ((1 + margin * 2) > worldTileSize)
 		x1 = bbox.xmin;
diff --git a/regress/core/regress_expected b/regress/core/regress_expected
index 4b3d7bc..f07b639 100644
--- a/regress/core/regress_expected
+++ b/regress/core/regress_expected
@@ -196,21 +196,21 @@ ERROR:  geometry contains non-closed rings
 226|t
 ERROR:  ST_TileEnvelope: Invalid tile zoom value, -1
 ERROR:  ST_TileEnvelope: Invalid tile y value, 1
-229|SRID=3857;POLYGON((-20037510 -20037510,-20037510 20037510,20037510 20037510,20037510 -20037510,-20037510 -20037510))
-230|SRID=3857;POLYGON((0 -2504688.75,0 0,2504688.75 0,2504688.75 -2504688.75,0 -2504688.75))
-231|SRID=3857;POLYGON((17532821.25 -20037510,17532821.25 -17532821.25,20037510 -17532821.25,20037510 -20037510,17532821.25 -20037510))
+229|SRID=3857;POLYGON((-20037508.342789 -20037508.342789,-20037508.342789 20037508.342789,20037508.342789 20037508.342789,20037508.342789 -20037508.342789,-20037508.342789 -20037508.342789))
+230|SRID=3857;POLYGON((0 -2504688.54284862,0 0,2504688.54284862 0,2504688.54284862 -2504688.54284862,0 -2504688.54284862))
+231|SRID=3857;POLYGON((17532819.7999404 -20037508.342789,17532819.7999404 -17532819.7999404,20037508.342789 -17532819.7999404,20037508.342789 -20037508.342789,17532819.7999404 -20037508.342789))
 232|POLYGON((0 -12.5,0 0,12.5 0,12.5 -12.5,0 -12.5))
 233|POLYGON((87.5 -100,87.5 -87.5,100 -87.5,100 -100,87.5 -100))
 234|POLYGON((-100 87.5,-100 100,-87.5 100,-87.5 87.5,-100 87.5))
 235|POLYGON((0 -12.5,0 0,25 0,25 -12.5,0 -12.5))
-236|SRID=3857;POLYGON((-20037510 -20037510,-20037510 20037510,20037510 20037510,20037510 -20037510,-20037510 -20037510))
-237|SRID=3857;POLYGON((-22041261 -2003751,-22041261 20037510,2003751 20037510,2003751 -2003751,-22041261 -2003751))
-238|SRID=3857;POLYGON((-15028132.5 -20037510,-15028132.5 -5009377.5,5009377.5 -5009377.5,5009377.5 -20037510,-15028132.5 -20037510))
+236|SRID=3857;POLYGON((-20037508.342789 -20037508.342789,-20037508.342789 20037508.342789,20037508.342789 20037508.342789,20037508.342789 -20037508.342789,-20037508.342789 -20037508.342789))
+237|SRID=3857;POLYGON((-22041259.1770679 -2003750.8342789,-22041259.1770679 20037508.342789,2003750.8342789 20037508.342789,2003750.8342789 -2003750.8342789,-22041259.1770679 -2003750.8342789))
+238|SRID=3857;POLYGON((-15028131.2570918 -20037508.342789,-15028131.2570918 -5009377.08569725,5009377.08569725 -5009377.08569725,5009377.08569725 -20037508.342789,-15028131.2570918 -20037508.342789))
 239|SRID=3857;POLYGON((0 0,0 0,0 0,0 0,0 0))
 ERROR:  ST_TileEnvelope: Margin must not be less than -50%, margin=-0.510000
-241|SRID=3857;POLYGON((-4007502 -4007502,-4007502 4007502,4007502 4007502,4007502 -4007502,-4007502 -4007502))
-250|SRID=3857;POLYGON((-8296781.484375 4852834.453125,-8296781.484375 4891970.21484375,-8257645.72265625 4891970.21484375,-8257645.72265625 4852834.453125,-8296781.484375 4852834.453125))
-251|SRID=3857;POLYGON((-8300695.06054688 4848920.87695312,-8300695.06054688 4895883.79101562,-8253732.14648438 4895883.79101562,-8253732.14648438 4848920.87695312,-8300695.06054688 4848920.87695312))
-252|SRID=3857;POLYGON((-8316349.36523438 4833266.57226562,-8316349.36523438 4911538.09570312,-8238077.84179688 4911538.09570312,-8238077.84179688 4833266.57226562,-8316349.36523438 4833266.57226562))
-253|SRID=3857;POLYGON((-8375053.0078125 4774562.9296875,-8375053.0078125 4970241.73828125,-8179374.19921875 4970241.73828125,-8179374.19921875 4774562.9296875,-8375053.0078125 4774562.9296875))
-254|SRID=3857;POLYGON((-8285040.75585938 4864575.18164062,-8285040.75585938 4880229.48632812,-8269386.45117188 4880229.48632812,-8269386.45117188 4864575.18164062,-8285040.75585938 4864575.18164062))
+241|SRID=3857;POLYGON((-4007501.6685578 -4007501.6685578,-4007501.6685578 4007501.6685578,4007501.6685578 4007501.6685578,4007501.6685578 -4007501.6685578,-4007501.6685578 -4007501.6685578))
+250|SRID=3857;POLYGON((-8296780.79818607 4852834.05176921,-8296780.79818607 4891969.81025122,-8257645.03970406 4891969.81025122,-8257645.03970406 4852834.05176921,-8296780.79818607 4852834.05176921))
+251|SRID=3857;POLYGON((-8300694.37403427 4848920.47592101,-8300694.37403427 4895883.38609942,-8253731.46385586 4895883.38609942,-8253731.46385586 4848920.47592101,-8300694.37403427 4848920.47592101))
+252|SRID=3857;POLYGON((-8316348.67742708 4833266.17252821,-8316348.67742708 4911537.68949223,-8238077.16046306 4911537.68949223,-8238077.16046306 4833266.17252821,-8316348.67742708 4833266.17252821))
+253|SRID=3857;POLYGON((-8375052.31515009 4774562.53480519,-8375052.31515009 4970241.32721524,-8179373.52274004 4970241.32721524,-8179373.52274004 4774562.53480519,-8375052.31515009 4774562.53480519))
+254|SRID=3857;POLYGON((-8285040.07064147 4864574.77931381,-8285040.07064147 4880229.08270662,-8269385.76724866 4880229.08270662,-8269385.76724866 4864574.77931381,-8285040.07064147 4864574.77931381))
Summary of changes:
 NEWS                             |  1 +
 postgis/lwgeom_functions_basic.c | 17 +++++++++++++----
 regress/core/regress_expected    | 24 ++++++++++++------------
 3 files changed, 26 insertions(+), 16 deletions(-)
hooks/post-receive
