[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 6a44fcb9885463754e60a05483099ab18d8bccfd
Thu Dec 12 08:02:06 PST 2019
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  6a44fcb9885463754e60a05483099ab18d8bccfd (commit)
      from  f443a7cda1aa0bc4c8df71cb80784850704e1c86 (commit)
revisions in full, below.
commit 6a44fcb9885463754e60a05483099ab18d8bccfd
Author: Raúl Marín <git at rmr.ninja>
Date:   Wed Dec 11 19:47:48 2019 +0100
    LWGEOM_addpoint: Accept -1 as a valid position
    References #4599
diff --git a/NEWS b/NEWS
index 0b9d466..f549ada 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ XXXX/XX/XX
   - #4558, Fix oversimplification of polygon inner rings (Raúl Marín)
   - #4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)
   - #4590, Fix pg_upgrade issue with st_linecrossingdirection (Raúl Marín)
+  - #4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
 PostGIS 3.0.0
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index d3efd20..60363fb 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2163,7 +2163,7 @@ Datum LWGEOM_addpoint(PG_FUNCTION_ARGS)
 	GSERIALIZED *pglwg1, *pglwg2, *result;
 	LWPOINT *point;
 	LWLINE *line, *linecopy;
-	int32 where = -1;
+	uint32_t uwhere = 0;
 	POSTGIS_DEBUGF(2, "%s called.", __func__);
@@ -2184,26 +2184,29 @@ Datum LWGEOM_addpoint(PG_FUNCTION_ARGS)
 	line = lwgeom_as_lwline(lwgeom_from_gserialized(pglwg1));
-	if (PG_NARGS() > 2)
+	if (PG_NARGS() <= 2)
-		where = PG_GETARG_INT32(2);
+		uwhere = line->points->npoints;
 	else
-		where = line->points->npoints;
-	if (where < 0 || where > (int32)line->points->npoints)
-		elog(ERROR, "Invalid offset");
-		PG_RETURN_NULL();
+		int32 where = PG_GETARG_INT32(2);
+		if (where == -1)
+		else if (where < 0 || where > (int32)line->points->npoints)
+			elog(ERROR, "Invalid offset");
+			PG_RETURN_NULL();
 	point = lwgeom_as_lwpoint(lwgeom_from_gserialized(pglwg2));
 	linecopy = lwgeom_as_lwline(lwgeom_clone_deep(lwline_as_lwgeom(line)));
 	lwline_free(line);
-	if (lwline_add_lwpoint(linecopy, point, (uint32_t)where) == LW_FAILURE)
+	if (lwline_add_lwpoint(linecopy, point, uwhere) == LW_FAILURE)
 		elog(ERROR, "Point insert failed");
 		PG_RETURN_NULL();
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index adb64fb..4e1b3e0 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1284,3 +1284,7 @@ union all
 select '#4399', 'ST_GeoHash', ST_GeoHash(geom)::text from geom
 union all
 select '#4399', 'ST_AsGeoJSON', ST_AsGeoJSON(geom)::text from geom;
+SELECT '#4599-1', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3)));
+SELECT '#4599-2', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3), 0));
+SELECT '#4599-3', ST_AsEWKT(ST_AddPoint(ST_GeomFromEWKT('LINESTRING(0 0 1, 1 1 1)'), ST_MakePoint(1, 2, 3), -1));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index e821f1c..4b34ba7 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -424,3 +424,6 @@ ERROR:  BOX2D_construct: args can not be empty points
 #4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}
 #4399|ST_AsGeoJSON|{"type":"GeometryCollection","geometries":[{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}]}
 #4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[]]}
+#4599-1|LINESTRING(0 0 1,1 1 1,1 2 3)
+#4599-2|LINESTRING(1 2 3,0 0 1,1 1 1)
+#4599-3|LINESTRING(0 0 1,1 1 1,1 2 3)
Summary of changes:
 NEWS                             |  1 +
 postgis/lwgeom_functions_basic.c | 25 ++++++++++++++-----------
 regress/core/tickets.sql         |  4 ++++
 regress/core/tickets_expected    |  3 +++
 4 files changed, 22 insertions(+), 11 deletions(-)
hooks/post-receive
