[postgis-tickets] r17236 - Add lexer initialization
Paul Ramsey pramsey at cleverelephant.ca
Mon Feb 11 09:18:47 PST 2019
Author: pramsey
Date: 2019-02-11 09:18:46 -0800 (Mon, 11 Feb 2019)
New Revision: 17236
   branches/2.5/liblwgeom/lwin_wkt_lex.l
References #4017
Modified: branches/2.5/liblwgeom/lwin_wkt_lex.l
--- branches/2.5/liblwgeom/lwin_wkt_lex.l	2019-02-11 17:17:16 UTC (rev 17235)
+++ branches/2.5/liblwgeom/lwin_wkt_lex.l	2019-02-11 17:18:46 UTC (rev 17236)
@@ -8,12 +8,12 @@
 #include "lwin_wkt_parse.h"
 #include "lwgeom_log.h"
-static YY_BUFFER_STATE wkt_yy_buf_state;
+static YY_BUFFER_STATE wkt_yy_buf_state;
 * Handle errors due to unexpected junk in WKT strings.
-static void wkt_lexer_unknown()
+static void wkt_lexer_unknown()
 	/* Set the global error state */
 	global_parser_result.errcode = PARSER_ERROR_OTHER;
@@ -21,8 +21,8 @@
 	global_parser_result.errlocation = wkt_yylloc.last_column;
-* This macro is magically run after a rule is found but before the main
+* This macro is magically run after a rule is found but before the main
 * action is run. We use it to update the parse location information
 * so we can report on where things fail. Also optionally to dump
 * debugging info.
@@ -34,7 +34,7 @@
 	LWDEBUGF(5,"lex: %s", wkt_yytext); \
 	} while (0);
 %option prefix="wkt_yy"
@@ -52,13 +52,13 @@
 	LWDEBUG(5,"DOUBLE");
 	wkt_yylval.doublevalue = atof(wkt_yytext);
 	yyless(wkt_yyleng-1);
-	return DOUBLE_TOK;
+	return DOUBLE_TOK;
-SRID=-?[0-9]+ {
+SRID=-?[0-9]+ {
 	LWDEBUG(5,"SRID");
-	wkt_yylval.integervalue = wkt_lexer_read_srid(wkt_yytext);
-	return SRID_TOK;
+	wkt_yylval.integervalue = wkt_lexer_read_srid(wkt_yytext);
+	return SRID_TOK;
 GEOMETRYCOLLECTION { return COLLECTION_TOK; }
@@ -78,10 +78,10 @@
 POINT { return POINT_TOK; }
 EMPTY { return EMPTY_TOK; }
-Z|M|ZM {
+Z|M|ZM {
 	LWDEBUG(5,"DIMENSIONALITY");
 	wkt_yylval.stringvalue = wkt_yytext;
-	return DIMENSIONALITY_TOK;
+	return DIMENSIONALITY_TOK;
 \( { LWDEBUG(5,"LBRACKET"); return LBRACKET_TOK; }
@@ -92,9 +92,9 @@
 [ \t\n\r]+ { /* ignore whitespace */ LWDEBUG(5,"WHITESPACE"); }
 . { /* Error out and stop parsing on unknown/unexpected characters */
-	LWDEBUG(5,"UNKNOWN");
+	LWDEBUG(5,"UNKNOWN");
 	wkt_lexer_unknown();
-	yyterminate();
+	yyterminate();
@@ -117,16 +117,17 @@
 * Set up the lexer!
-void wkt_lexer_init(char *src)
-	wkt_yy_buf_state = wkt_yy_scan_string(src);
+void wkt_lexer_init(char *src)
+	yy_init_globals();
+	wkt_yy_buf_state = wkt_yy_scan_string(src);
 * Clean up the lexer!
-void wkt_lexer_close()
-	wkt_yy_delete_buffer(wkt_yy_buf_state);
+void wkt_lexer_close()
+	wkt_yy_delete_buffer(wkt_yy_buf_state);
