[postgis-tickets] r17237 - Add generated file
Paul Ramsey pramsey at cleverelephant.ca
Mon Feb 11 09:18:56 PST 2019
Author: pramsey
Date: 2019-02-11 09:18:56 -0800 (Mon, 11 Feb 2019)
New Revision: 17237
   branches/2.5/liblwgeom/lwin_wkt_lex.c
Add generated file
Modified: branches/2.5/liblwgeom/lwin_wkt_lex.c
--- branches/2.5/liblwgeom/lwin_wkt_lex.c	2019-02-11 17:18:46 UTC (rev 17236)
+++ branches/2.5/liblwgeom/lwin_wkt_lex.c	2019-02-11 17:18:56 UTC (rev 17237)
@@ -863,12 +863,12 @@
 #include "lwin_wkt_parse.h"
 #include "lwgeom_log.h"
-static YY_BUFFER_STATE wkt_yy_buf_state;
+static YY_BUFFER_STATE wkt_yy_buf_state;
 * Handle errors due to unexpected junk in WKT strings.
-static void wkt_lexer_unknown()
+static void wkt_lexer_unknown()
 	/* Set the global error state */
 	global_parser_result.errcode = PARSER_ERROR_OTHER;
@@ -876,8 +876,8 @@
 	global_parser_result.errlocation = wkt_yylloc.last_column;
-* This macro is magically run after a rule is found but before the main
+* This macro is magically run after a rule is found but before the main
 * action is run. We use it to update the parse location information
 * so we can report on where things fail. Also optionally to dump
 * debugging info.
@@ -889,7 +889,7 @@
 	LWDEBUGF(5,"lex: %s", wkt_yytext); \
 	} while (0);
 #line 893 "lwin_wkt_lex.c"
 #define YY_NO_INPUT 1
 /* Suppress the default implementations. */
@@ -1172,16 +1172,16 @@
 	LWDEBUG(5,"DOUBLE");
 	wkt_yylval.doublevalue = atof(wkt_yytext);
 	yyless(wkt_yyleng-1);
-	return DOUBLE_TOK;
+	return DOUBLE_TOK;
 	YY_BREAK
 case 2:
 YY_RULE_SETUP
 #line 58 "lwin_wkt_lex.l"
 	LWDEBUG(5,"SRID");
-	wkt_yylval.integervalue = wkt_lexer_read_srid(wkt_yytext);
-	return SRID_TOK;
+	wkt_yylval.integervalue = wkt_lexer_read_srid(wkt_yytext);
+	return SRID_TOK;
 	YY_BREAK
 case 3:
@@ -1267,10 +1267,10 @@
 case 19:
 YY_RULE_SETUP
 #line 81 "lwin_wkt_lex.l"
 	LWDEBUG(5,"DIMENSIONALITY");
 	wkt_yylval.stringvalue = wkt_yytext;
-	return DIMENSIONALITY_TOK;
+	return DIMENSIONALITY_TOK;
 	YY_BREAK
 case 20:
@@ -1303,9 +1303,9 @@
 YY_RULE_SETUP
 #line 94 "lwin_wkt_lex.l"
 { /* Error out and stop parsing on unknown/unexpected characters */
-	LWDEBUG(5,"UNKNOWN");
+	LWDEBUG(5,"UNKNOWN");
 	wkt_lexer_unknown();
-	yyterminate();
+	yyterminate();
 	YY_BREAK
 case 26:
@@ -2280,17 +2280,18 @@
 * Set up the lexer!
-void wkt_lexer_init(char *src)
-	wkt_yy_buf_state = wkt_yy_scan_string(src);
+void wkt_lexer_init(char *src)
+	yy_init_globals();
+	wkt_yy_buf_state = wkt_yy_scan_string(src);
 * Clean up the lexer!
-void wkt_lexer_close()
-	wkt_yy_delete_buffer(wkt_yy_buf_state);
+void wkt_lexer_close()
+	wkt_yy_delete_buffer(wkt_yy_buf_state);
