[postgis-tickets] [PostGIS] #4329: PostgreSQL 12 many regression failures Look like rounding
PostGIS trac at osgeo.org
Tue Feb 19 16:18:52 PST 2019
 Reporter:  robe         |      Owner:  pramsey
     Type:  defect       |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 2.5.2
Component:  postgis      |    Version:  trunk
 Keywords:  postgres 12  |
 I'm not sure how long this has been going on.  I suspect somewhere between
 Feb 11th and Feb 15th is when it started.
 Debbie has this with pg12 head
 I've disabled her 12 testing on PostGIS 2.5, but kept it on for 3.0
 Checking for shp2pgsql ... found
 Checking for pgsql2shp ... found
 TMPDIR is /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64
 Creating database 'postgis_reg'
 Loading PostGIS into 'postgis_reg'
   /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
 install/share/contrib/postgis/postgis.sql
 install/share/contrib/postgis/postgis_comments.sql
 install/share/contrib/postgis/postgis_proc_set_search_path.sql
 PostgreSQL 12devel on x86_64-pc-linux-gnu, compiled by gcc (Debian
 8.2.0-9) 8.2.0, 64-bit
   Postgis 3.0.0dev - r17261 - 2019-02-19 04:35:15
   scripts 3.0.0dev r17261
   GEOS: 3.7.2dev-CAPI-1.11.2 0cd06b20
   PROJ: Rel. 5.2.0, September 15th, 2018
 Running tests
  ../loader/Point .............. ok
  ../loader/PointM .............. ok
  ../loader/PointZ .............. ok
  ../loader/MultiPoint .............. ok
  ../loader/MultiPointM .............. ok
  ../loader/MultiPointZ .............. ok
  ../loader/Arc .............. ok
  ../loader/ArcM .............. ok
  ../loader/ArcZ .............. ok
  ../loader/Polygon .............. ok
  ../loader/PolygonM .............. ok
  ../loader/PolygonZ .............. ok
  ../loader/TSTPolygon ......... ok
  ../loader/TSIPolygon ......... ok
  ../loader/TSTIPolygon ......... ok
  ../loader/PointWithSchema ..... ok
  ../loader/NoTransPoint ......... ok
  ../loader/NotReallyMultiPoint ......... ok
  ../loader/MultiToSinglePoint ......... ok
  ../loader/ReprojectPts ........ ok
  ../loader/ReprojectPtsGeog ........ ok
  ../loader/Latin1 .... ok
  ../loader/Latin1-implicit .... ok
  ../loader/mfile .... ok
  ../dumper/literalsrid ....... ok
  ../dumper/realtable ....... ok
  affine .. ok
  bestsrid .. ok
  binary .. ok
  boundary .. ok
  chaikin .. ok
  filterm .. ok
  cluster .. ok
  concave_hull .. ok
  concave_hull_hard .. ok
  ctors .. ok
  curvetoline .. ok
  dump .. ok
  dumppoints .. ok
  empty .. ok
  estimatedextent .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_41_diff)
 --- estimatedextent_expected    2019-01-23 17:21:20.650097294 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_41_out
 2019-02-19 04:38:35.021379610 +0000
 @@ -6,17 +6,32 @@
  WARNING:  stats for "t.g" do not exist
  #877.2.deprecated|
 +WARNING:  stats for "t.g" do not exist
  #877.3||||
  #877.4|-10.15000|20.15000|-50.40000|30.40000
  #877.5|-10.15000|20.15000|-50.40000|30.40000
  WARNING:  stats for "c1.g" do not exist
 +WARNING:  stats for "c1.g" do not exist
  #3391.1||||
  WARNING:  stats for "c2.g" do not exist
 +WARNING:  stats for "c2.g" do not exist
  #3391.2||||
  WARNING:  stats for "p.g" do not exist
 +WARNING:  stats for "p.g" do not exist
  #3391.3||||
  #3391.4|0.00|1.00|0.00|1.00
  #3391.5||||
  #3391.6|0.00|1.00|0.00|1.00
  #3391.7|0.00|1.00|0.00|1.00
 @@ -26,15 +41,30 @@
  #3391.11|-1.00|0.00|-1.00|0.00
  #3391.12|-1.01|2.02|-1.01|2.02
  #3391.13||||
  #3391.14||||
  #3391.15||||
  #3391.16||||
  #3391.17|0.00|1.00|0.00|1.00
  #3391.18||||
  #3391.19|0.00|1.00|0.00|1.00
  #3391.20|0.00|1.00|0.00|1.00
  forcecurve .. ok
  geography .. ok
  geometric_median .. ok
  hausdorff .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_45_diff)
 --- hausdorff_expected  2018-10-19 23:06:41.113379730 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_45_out
 2019-02-19 04:38:35.293380987 +0000
 @@ -1,6 +1,6 @@
 -hausdorff_poly_poly|0.707106781186548
 +hausdorff_poly_poly|0.7071067811865476
  hausdorff_ls_ls|1
  hausdorff_ls_ls_2|2
  hausdorff_ls_mp|1
 -hausdorff_ls_ls_3|14.142135623731
 +hausdorff_ls_ls_3|14.142135623730951
  hausdorffdensify_ls_ls|70
  in_geohash .. ok
  in_gml .. ok
  in_kml .. ok
  in_encodedpolyline .. ok
  iscollection .. ok
  knn_recheck .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_51_diff)
 --- knn_recheck_expected        2018-10-19 23:06:41.065380052 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_51_out
 2019-02-19 04:38:57.481493351 +0000
 @@ -103,5 +103,5 @@
  #3nd-3|600001|9749|54.5453|54.5453
  #3nd-3|600001|10041|54.6233|54.6233
  #3573|8
 -#3418|0.331823813642119|0.331823813642119
 +#3418|0.33182381364211927|0.33182381364211927
  #3418|0.55|0.55
  legacy .. ok
  long_xact .. ok
  lwgeom_regress .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_54_diff)
 --- lwgeom_regress_expected     2018-10-19 23:06:41.121379675 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_54_out
 2019-02-19 04:38:58.309497543 +0000
 @@ -28,8 +28,8 @@
  ERROR:  Argument must be POINT geometries
  ERROR:  parse error - invalid geometry
  ST_Angle_4_pts|4.71238898038469
 -ST_Angle_4_pts|0.785398163397448
 -ST_Angle_3_pts|1.5707963267949
 +ST_Angle_4_pts|0.7853981633974483
 +ST_Angle_3_pts|1.5707963267948966
  ERROR:  Operation on mixed SRID geometries
  ERROR:  Empty geometry
  ST_Angle_2_lines|4.71238898038469
  measures .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_55_diff)
 --- measures_expected   2019-02-18 08:55:22.999999325 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_55_out
 2019-02-19 04:38:58.381497909 +0000
 @@ -1,9 +1,9 @@
  113|291
  114|140
  115|140
 -116|4.24264068711929
 -117|4.24264068711929
 -118|5.19615242270663
 +116|4.242640687119286
 +117|4.242640687119286
 +118|5.196152422706632
  134|0
  135|13
  136|13
 @@ -16,7 +16,7 @@
  st_maxdistance_134|0
  st_maxdistance_135|13
  st_maxdistance_136|13
 -st_maxdistance_dist|22.3606797749979|22.3606797749979
 +st_maxdistance_dist|22.360679774997898|22.360679774997898
  st_longestline_134|LINESTRING(1 2,1 2)
  st_longestline_135|LINESTRING(5 0,10 12)
  st_longestline_136|LINESTRING(0 0,5 12)
 @@ -25,14 +25,14 @@
 distancetest2|0|50|0.0000000000|0.0000000000|0.0000000000|0.0000000000|LINESTRING(-40
 -20,-10 20)|LINESTRING(-10 20,-40 -20)
  distancepoly1|1|50|LINESTRING(17 18,17 19)|LINESTRING(17 19,17
 18)|LINESTRING(29 39,-1 -1)|LINESTRING(-1 -1,29 39)
  distancepoly2|0|26.1725046566048|LINESTRING(17 14,17 14)|LINESTRING(17
 14,17 14)|LINESTRING(17 18,-1 -1)|LINESTRING(-1 -1,17 18)
 -distancepoly3|0|26.9072480941474|LINESTRING(17 19,17 19)|LINESTRING(17
 19,17 19)|LINESTRING(17 19,-1 -1)|LINESTRING(-1 -1,17 19)
 -distancepoly4|0|28.3196045170126|LINESTRING(16 19,16 19)|LINESTRING(16
 19,16 19)|LINESTRING(18 20,-1 -1)|LINESTRING(-1 -1,18 20)
 +distancepoly3|0|26.90724809414742|LINESTRING(17 19,17 19)|LINESTRING(17
 +distancepoly4|0|28.319604517012593|LINESTRING(16 19,16 19)|LINESTRING(16
  distancepoly5|0|26.1725046566048|LINESTRING(17 12,17 12)|LINESTRING(17
 12,17 12)|LINESTRING(17 18,-1 -1)|LINESTRING(-1 -1,17 18)
 -distancepoly6|0|32.5269119345812|LINESTRING(2 2,2 2)|LINESTRING(2 2,2
 2)|LINESTRING(2 2,25 25)|LINESTRING(25 25,2 2)
 -3dDistancetest1|6.40312423743285|6.40312423743285|f|f|LINESTRING(1 1 1,3
 2 7)|POINT(1 1 1)|LINESTRING(1 1 1,3 2 7)
 -3dDistancetest2|0|1.73205080756888|t|t|LINESTRING(1 1 1,1 1 1)|POINT(1 1
 1)|LINESTRING(1 1 1,0 0 0)
 +distancepoly6|0|32.526911934581186|LINESTRING(2 2,2 2)|LINESTRING(2 2,2
 +3dDistancetest1|6.4031242374328485|6.4031242374328485|f|f|LINESTRING(1 1
 1,3 2 7)|POINT(1 1 1)|LINESTRING(1 1 1,3 2 7)
 +3dDistancetest2|0|1.7320508075688772|t|t|LINESTRING(1 1 1,1 1 1)|POINT(1
 1 1)|LINESTRING(1 1 1,0 0 0)
  3dDistancetest3|4.09994192757944|6.48074069840786|t|f|LINESTRING(1 1
 1,0.61904761904762 -0.19047619047619 4.90476190476191)|POINT(1 1
 1)|LINESTRING(1 1 1,5 2 6)
 -3dDistancetest4|2|10.0498756211209|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1
 3)|LINESTRING(5 7 8,1 1 1)
 +3dDistancetest4|2|10.04987562112089|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1
  3dDistancetest5|2|10|t|f|LINESTRING(5 0 5,5 2 5)|POINT(5 0
 5)|LINESTRING(11 0 5,5 0 13)
  3dDistancetest6|0
  3dDistancetest7|0
  minimum_bounding_circle .. ok
  normalize .. ok
  operators .. ok
  orientation .. ok
  out_geometry .. ok
  out_geography .. ok
  polygonize .. ok
  polyhedralsurface .. ok
  postgis_type_name .. ok
  quantize_coordinates .. ok
  regress .. ok
  regress_bdpoly .. ok
  regress_buffer_params .. ok
  regress_gist_index_nd .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  regress_management .. ok
  regress_selectivity .. ok
  regress_lrs .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_74_diff)
 --- regress_lrs_expected        2018-12-03 21:53:22.510210503 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_74_out
 2019-02-19 04:39:03.129521953 +0000
 @@ -20,7 +20,7 @@
  #4155.1|MULTILINESTRING Z ((2 2 2,5 5 5))
  #4155.2|TIN Z EMPTY
  #4155.3|MULTIPOLYGON Z EMPTY
 -line_locate_point_1|0.528602749909894
 +line_locate_point_1|0.5286027499098938
  line_locate_point_2|1
  line_locate_point_3|0
  line_locate_point_4|0
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_proj .. ok
  relate .. ok
  remove_repeated_points .. ok
  removepoint .. ok
  reverse .. ok
  setpoint .. ok
  simplify .. ok
  simplifyvw .. ok
  size .. ok
  snaptogrid .. ok
  split .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  swapordinates .. ok
  summary .. ok
  temporal .. ok
  temporal_knn .. ok
  tickets .. ok
  twkb .. ok
  typmod .. ok
  wkb .. ok
  wkt .. ok
  wmsservers .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  delaunaytriangles .. ok
  clipbybox2d .. ok
  subdivide .. ok
  voronoi .. ok
  regress_brin_index .. ok
  regress_brin_index_3d .. ok
  regress_brin_index_geography .. ok
  minimum_clearance .. ok
  oriented_envelope .. ok
  frechet .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_124_diff)
 --- frechet_expected    2018-10-19 23:06:40.889381235 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_124_out
 2019-02-19 04:39:27.985647831 +0000
 @@ -1,5 +1,5 @@
  frechet_ls_ls|1
  frechet_ls_ls_2|2.23606797749979
  frechet_ls_mp|1
 -frechet_ls_ls_3|70.7106781186548
 +frechet_ls_ls_3|70.71067811865476
  frechetdensify_ls_ls|50
  in_geojson .. ok
  regress_spgist_index_2d .. ok
  regress_spgist_index_3d .. ok
  regress_spgist_index_nd .. ok
  mvt .. ok
  geobuf .. ok
  mvt_jsonb .. ok
  uninstall .  /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00
 -regress-install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4679)
 Run tests: 132
 Failed: 7
 make[2]: *** [Makefile:212: check] Error 7
 make[2]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.0/regress/core'
 make[1]: *** [Makefile:28: check] Error 2
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.0/regress'
 make: *** [GNUmakefile:20: check] Error 1
 I compiled PostgreSQL 12 and get same failures.
 at a glance looks like mostly rounding issues that perhaps buttoning up
 the tests with some grace for floats will solve.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4329>
