[postgis-tickets] [PostGIS] #4329: PostgreSQL 12 many regression failures rounding and extra warning output (was: PostgreSQL 12 many regression failures Look like rounding)
PostGIS trac at osgeo.org
Tue Feb 19 16:21:42 PST 2019
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.2
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:  postgres 12
Description changed by robe:
Old description:
> I'm not sure how long this has been going on.  I suspect somewhere
> between Feb 11th and Feb 15th is when it started.
> Debbie has this with pg12 head
> I've disabled her 12 testing on PostGIS 2.5, but kept it on for 3.0
> Checking for shp2pgsql ... found
> Checking for pgsql2shp ... found
> TMPDIR is /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64
> Creating database 'postgis_reg'
> Loading PostGIS into 'postgis_reg'
>   /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
> install/share/contrib/postgis/postgis.sql
> install/share/contrib/postgis/postgis_comments.sql
> install/share/contrib/postgis/postgis_proc_set_search_path.sql
> PostgreSQL 12devel on x86_64-pc-linux-gnu, compiled by gcc (Debian
> 8.2.0-9) 8.2.0, 64-bit
>   Postgis 3.0.0dev - r17261 - 2019-02-19 04:35:15
>   scripts 3.0.0dev r17261
>   GEOS: 3.7.2dev-CAPI-1.11.2 0cd06b20
>   PROJ: Rel. 5.2.0, September 15th, 2018
> Running tests
>  ../loader/Point .............. ok
>  ../loader/PointM .............. ok
>  ../loader/PointZ .............. ok
>  ../loader/MultiPoint .............. ok
>  ../loader/MultiPointM .............. ok
>  ../loader/MultiPointZ .............. ok
>  ../loader/Arc .............. ok
>  ../loader/ArcM .............. ok
>  ../loader/ArcZ .............. ok
>  ../loader/Polygon .............. ok
>  ../loader/PolygonM .............. ok
>  ../loader/PolygonZ .............. ok
>  ../loader/TSTPolygon ......... ok
>  ../loader/TSIPolygon ......... ok
>  ../loader/TSTIPolygon ......... ok
>  ../loader/PointWithSchema ..... ok
>  ../loader/NoTransPoint ......... ok
>  ../loader/NotReallyMultiPoint ......... ok
>  ../loader/MultiToSinglePoint ......... ok
>  ../loader/ReprojectPts ........ ok
>  ../loader/ReprojectPtsGeog ........ ok
>  ../loader/Latin1 .... ok
>  ../loader/Latin1-implicit .... ok
>  ../loader/mfile .... ok
>  ../dumper/literalsrid ....... ok
>  ../dumper/realtable ....... ok
>  affine .. ok
>  bestsrid .. ok
>  binary .. ok
>  boundary .. ok
>  chaikin .. ok
>  filterm .. ok
>  cluster .. ok
>  concave_hull .. ok
>  concave_hull_hard .. ok
>  ctors .. ok
>  curvetoline .. ok
>  dump .. ok
>  dumppoints .. ok
>  empty .. ok
>  estimatedextent .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_41_diff)
> --- estimatedextent_expected    2019-01-23 17:21:20.650097294 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_41_out
> 2019-02-19 04:38:35.021379610 +0000
> @@ -6,17 +6,32 @@
>  WARNING:  stats for "t.g" do not exist
>  #877.2.deprecated|
> +WARNING:  stats for "t.g" do not exist
>  #877.3||||
>  #877.4|-10.15000|20.15000|-50.40000|30.40000
>  #877.5|-10.15000|20.15000|-50.40000|30.40000
>  WARNING:  stats for "c1.g" do not exist
> +WARNING:  stats for "c1.g" do not exist
>  #3391.1||||
>  WARNING:  stats for "c2.g" do not exist
> +WARNING:  stats for "c2.g" do not exist
>  #3391.2||||
>  WARNING:  stats for "p.g" do not exist
> +WARNING:  stats for "p.g" do not exist
>  #3391.3||||
>  #3391.4|0.00|1.00|0.00|1.00
>  #3391.5||||
>  #3391.6|0.00|1.00|0.00|1.00
>  #3391.7|0.00|1.00|0.00|1.00
> @@ -26,15 +41,30 @@
>  #3391.11|-1.00|0.00|-1.00|0.00
>  #3391.12|-1.01|2.02|-1.01|2.02
>  #3391.13||||
>  #3391.14||||
>  #3391.15||||
>  #3391.16||||
>  #3391.17|0.00|1.00|0.00|1.00
>  #3391.18||||
>  #3391.19|0.00|1.00|0.00|1.00
>  #3391.20|0.00|1.00|0.00|1.00
>  forcecurve .. ok
>  geography .. ok
>  geometric_median .. ok
>  hausdorff .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_45_diff)
> --- hausdorff_expected  2018-10-19 23:06:41.113379730 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_45_out
> 2019-02-19 04:38:35.293380987 +0000
> @@ -1,6 +1,6 @@
> -hausdorff_poly_poly|0.707106781186548
> +hausdorff_poly_poly|0.7071067811865476
>  hausdorff_ls_ls|1
>  hausdorff_ls_ls_2|2
>  hausdorff_ls_mp|1
> -hausdorff_ls_ls_3|14.142135623731
> +hausdorff_ls_ls_3|14.142135623730951
>  hausdorffdensify_ls_ls|70
>  in_geohash .. ok
>  in_gml .. ok
>  in_kml .. ok
>  in_encodedpolyline .. ok
>  iscollection .. ok
>  knn_recheck .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_51_diff)
> --- knn_recheck_expected        2018-10-19 23:06:41.065380052 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_51_out
> 2019-02-19 04:38:57.481493351 +0000
> @@ -103,5 +103,5 @@
>  #3nd-3|600001|9749|54.5453|54.5453
>  #3nd-3|600001|10041|54.6233|54.6233
>  #3573|8
> -#3418|0.331823813642119|0.331823813642119
> +#3418|0.33182381364211927|0.33182381364211927
>  #3418|0.55|0.55
>  legacy .. ok
>  long_xact .. ok
>  lwgeom_regress .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_54_diff)
> --- lwgeom_regress_expected     2018-10-19 23:06:41.121379675 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_54_out
> 2019-02-19 04:38:58.309497543 +0000
> @@ -28,8 +28,8 @@
>  ERROR:  Argument must be POINT geometries
>  ERROR:  parse error - invalid geometry
>  ST_Angle_4_pts|4.71238898038469
> -ST_Angle_4_pts|0.785398163397448
> -ST_Angle_3_pts|1.5707963267949
> +ST_Angle_4_pts|0.7853981633974483
> +ST_Angle_3_pts|1.5707963267948966
>  ERROR:  Operation on mixed SRID geometries
>  ERROR:  Empty geometry
>  ST_Angle_2_lines|4.71238898038469
>  measures .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_55_diff)
> --- measures_expected   2019-02-18 08:55:22.999999325 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_55_out
> 2019-02-19 04:38:58.381497909 +0000
> @@ -1,9 +1,9 @@
>  113|291
>  114|140
>  115|140
> -116|4.24264068711929
> -117|4.24264068711929
> -118|5.19615242270663
> +116|4.242640687119286
> +117|4.242640687119286
> +118|5.196152422706632
>  134|0
>  135|13
>  136|13
> @@ -16,7 +16,7 @@
>  st_maxdistance_134|0
>  st_maxdistance_135|13
>  st_maxdistance_136|13
> -st_maxdistance_dist|22.3606797749979|22.3606797749979
> +st_maxdistance_dist|22.360679774997898|22.360679774997898
>  st_longestline_134|LINESTRING(1 2,1 2)
>  st_longestline_135|LINESTRING(5 0,10 12)
>  st_longestline_136|LINESTRING(0 0,5 12)
> @@ -25,14 +25,14 @@
> distancetest2|0|50|0.0000000000|0.0000000000|0.0000000000|0.0000000000|LINESTRING(-40
> -20,-10 20)|LINESTRING(-10 20,-40 -20)
>  distancepoly1|1|50|LINESTRING(17 18,17 19)|LINESTRING(17 19,17
> 18)|LINESTRING(29 39,-1 -1)|LINESTRING(-1 -1,29 39)
>  distancepoly2|0|26.1725046566048|LINESTRING(17 14,17 14)|LINESTRING(17
> 14,17 14)|LINESTRING(17 18,-1 -1)|LINESTRING(-1 -1,17 18)
> -distancepoly3|0|26.9072480941474|LINESTRING(17 19,17 19)|LINESTRING(17
> 19,17 19)|LINESTRING(17 19,-1 -1)|LINESTRING(-1 -1,17 19)
> -distancepoly4|0|28.3196045170126|LINESTRING(16 19,16 19)|LINESTRING(16
> 19,16 19)|LINESTRING(18 20,-1 -1)|LINESTRING(-1 -1,18 20)
> +distancepoly3|0|26.90724809414742|LINESTRING(17 19,17 19)|LINESTRING(17
> +distancepoly4|0|28.319604517012593|LINESTRING(16 19,16 19)|LINESTRING(16
>  distancepoly5|0|26.1725046566048|LINESTRING(17 12,17 12)|LINESTRING(17
> 12,17 12)|LINESTRING(17 18,-1 -1)|LINESTRING(-1 -1,17 18)
> -distancepoly6|0|32.5269119345812|LINESTRING(2 2,2 2)|LINESTRING(2 2,2
> 2)|LINESTRING(2 2,25 25)|LINESTRING(25 25,2 2)
> -3dDistancetest1|6.40312423743285|6.40312423743285|f|f|LINESTRING(1 1 1,3
> 2 7)|POINT(1 1 1)|LINESTRING(1 1 1,3 2 7)
> -3dDistancetest2|0|1.73205080756888|t|t|LINESTRING(1 1 1,1 1 1)|POINT(1 1
> 1)|LINESTRING(1 1 1,0 0 0)
> +distancepoly6|0|32.526911934581186|LINESTRING(2 2,2 2)|LINESTRING(2 2,2
> +3dDistancetest1|6.4031242374328485|6.4031242374328485|f|f|LINESTRING(1 1
> 1,3 2 7)|POINT(1 1 1)|LINESTRING(1 1 1,3 2 7)
> +3dDistancetest2|0|1.7320508075688772|t|t|LINESTRING(1 1 1,1 1 1)|POINT(1
> 1 1)|LINESTRING(1 1 1,0 0 0)
>  3dDistancetest3|4.09994192757944|6.48074069840786|t|f|LINESTRING(1 1
> 1,0.61904761904762 -0.19047619047619 4.90476190476191)|POINT(1 1
> 1)|LINESTRING(1 1 1,5 2 6)
> -3dDistancetest4|2|10.0498756211209|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1
> 3)|LINESTRING(5 7 8,1 1 1)
> +3dDistancetest4|2|10.04987562112089|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1
> 1 3)|LINESTRING(5 7 8,1 1 1)
>  3dDistancetest5|2|10|t|f|LINESTRING(5 0 5,5 2 5)|POINT(5 0
> 5)|LINESTRING(11 0 5,5 0 13)
>  3dDistancetest6|0
>  3dDistancetest7|0
>  minimum_bounding_circle .. ok
>  normalize .. ok
>  operators .. ok
>  orientation .. ok
>  out_geometry .. ok
>  out_geography .. ok
>  polygonize .. ok
>  polyhedralsurface .. ok
>  postgis_type_name .. ok
>  quantize_coordinates .. ok
>  regress .. ok
>  regress_bdpoly .. ok
>  regress_buffer_params .. ok
>  regress_gist_index_nd .. ok
>  regress_index .. ok
>  regress_index_nulls .. ok
>  regress_management .. ok
>  regress_selectivity .. ok
>  regress_lrs .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_74_diff)
> --- regress_lrs_expected        2018-12-03 21:53:22.510210503 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_74_out
> 2019-02-19 04:39:03.129521953 +0000
> @@ -20,7 +20,7 @@
>  #4155.1|MULTILINESTRING Z ((2 2 2,5 5 5))
>  #4155.2|TIN Z EMPTY
>  #4155.3|MULTIPOLYGON Z EMPTY
> -line_locate_point_1|0.528602749909894
> +line_locate_point_1|0.5286027499098938
>  line_locate_point_2|1
>  line_locate_point_3|0
>  line_locate_point_4|0
>  regress_ogc .. ok
>  regress_ogc_cover .. ok
>  regress_ogc_prep .. ok
>  regress_proj .. ok
>  relate .. ok
>  remove_repeated_points .. ok
>  removepoint .. ok
>  reverse .. ok
>  setpoint .. ok
>  simplify .. ok
>  simplifyvw .. ok
>  size .. ok
>  snaptogrid .. ok
>  split .. ok
>  sql-mm-serialize .. ok
>  sql-mm-circularstring .. ok
>  sql-mm-compoundcurve .. ok
>  sql-mm-curvepoly .. ok
>  sql-mm-general .. ok
>  sql-mm-multicurve .. ok
>  sql-mm-multisurface .. ok
>  swapordinates .. ok
>  summary .. ok
>  temporal .. ok
>  temporal_knn .. ok
>  tickets .. ok
>  twkb .. ok
>  typmod .. ok
>  wkb .. ok
>  wkt .. ok
>  wmsservers .. ok
>  offsetcurve .. ok
>  relatematch .. ok
>  isvaliddetail .. ok
>  sharedpaths .. ok
>  snap .. ok
>  node .. ok
>  unaryunion .. ok
>  clean .. ok
>  relate_bnr .. ok
>  delaunaytriangles .. ok
>  clipbybox2d .. ok
>  subdivide .. ok
>  voronoi .. ok
>  regress_brin_index .. ok
>  regress_brin_index_3d .. ok
>  regress_brin_index_geography .. ok
>  minimum_clearance .. ok
>  oriented_envelope .. ok
>  frechet .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_124_diff)
> --- frechet_expected    2018-10-19 23:06:40.889381235 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_124_out
> 2019-02-19 04:39:27.985647831 +0000
> @@ -1,5 +1,5 @@
>  frechet_ls_ls|1
>  frechet_ls_ls_2|2.23606797749979
>  frechet_ls_mp|1
> -frechet_ls_ls_3|70.7106781186548
> +frechet_ls_ls_3|70.71067811865476
>  frechetdensify_ls_ls|50
>  in_geojson .. ok
>  regress_spgist_index_2d .. ok
>  regress_spgist_index_3d .. ok
>  regress_spgist_index_nd .. ok
>  mvt .. ok
>  geobuf .. ok
>  mvt_jsonb .. ok
>  uninstall .  /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00
> -regress-install/share/contrib/postgis/uninstall_postgis.sql
> . ok (4679)
> Run tests: 132
> Failed: 7
> make[2]: *** [Makefile:212: check] Error 7
> make[2]: Leaving directory
> '/var/lib/jenkins/workspace/postgis/branches/3.0/regress/core'
> make[1]: *** [Makefile:28: check] Error 2
> make[1]: Leaving directory
> '/var/lib/jenkins/workspace/postgis/branches/3.0/regress'
> make: *** [GNUmakefile:20: check] Error 1
> I compiled PostgreSQL 12 and get same failures.
> at a glance looks like mostly rounding issues that perhaps buttoning up
> the tests with some grace for floats will solve.
New description:
 I'm not sure how long this has been going on.  I suspect somewhere between
 All look like rounding except for the estimatedextent. I can't tell if
 it's in 12 whatever we have is running 4 times instead of once or just
 some artifact of the WARNING system in 12 that it outputs the warning 4
 times.
 Running tests
  affine .. ok
  bestsrid .. ok
  binary .. ok
  boundary .. ok
  chaikin .. ok
  filterm .. ok
  cluster .. ok
  concave_hull .. ok
  ctors .. ok
  curvetoline .. ok
  dump .. ok
  dumppoints .. ok
  empty .. ok
 @@ -6,17 +6,32 @@
  #877.2.deprecated|
  #877.3||||
  #3391.1||||
  #3391.2||||
  #3391.3||||
  #3391.5||||
 @@ -26,15 +41,30 @@
  #3391.13||||
  #3391.14||||
  #3391.15||||
  #3391.16||||
  #3391.18||||
  forcecurve .. ok
  geography .. ok
 @@ -1,6 +1,6 @@
  hausdorff_ls_ls|1
  hausdorff_ls_ls_2|2
  hausdorff_ls_mp|1
  in_geohash .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
 @@ -103,5 +103,5 @@
  #3573|8
  #3418|0.55|0.55
  legacy .. ok
  long_xact .. ok
 @@ -28,8 +28,8 @@
 @@ -1,9 +1,9 @@
  113|291
  114|140
  115|140
  134|0
  135|13
  136|13
 @@ -16,7 +16,7 @@
 @@ -25,14 +25,14 @@
 +3dDistancetest4|2|10.04987562112089|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1
  3dDistancetest6|0
  3dDistancetest7|0
  normalize .. ok
  operators .. ok
  orientation .. ok
  out_geometry .. ok
  out_geography .. ok
  polygonize .. ok
  regress .. ok
  regress_index .. ok
 @@ -20,7 +20,7 @@
  #4155.2|TIN Z EMPTY
  regress_ogc .. ok
  regress_proj .. ok
  relate .. ok
  removepoint .. ok
  reverse .. ok
  setpoint .. ok
  simplify .. ok
  simplifyvw .. ok
  size .. ok
  snaptogrid .. ok
  split .. ok
  swapordinates .. ok
  summary .. ok
  temporal .. ok
  temporal_knn .. ok
  tickets .. ok
  twkb .. ok
  typmod .. ok
  wkb .. ok
  wkt .. ok
  wmsservers .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  clipbybox2d .. ok
  subdivide .. ok
  voronoi .. ok
 @@ -1,5 +1,5 @@
  frechet_ls_ls|1
  frechet_ls_mp|1
  in_geojson .. ok
  mvt .. ok
  geobuf .. ok
  mvt_jsonb .. ok
 . ok (4679)
 Run tests: 132
 Failed: 7
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4329#comment:1>
