[postgis-tickets] [PostGIS] #4408: can't compile --with-wagyu under mingw64
PostGIS trac at osgeo.org
Fri May 31 16:15:31 PDT 2019
  Reporter:  robe     |      Owner:  Algunenano
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 Sadly winnie has same issue
 https://winnie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/9078/consoleFull
 ../deps/wagyu/libwagyu.la(lwgeom_wagyu.o):lwgeom_wagyu.cpp:(.text$_ZSt20get_temporary_bufferIPN6mapbox8geometry5wagyu13local_minimumIiEEESt4pairIPT_xEx[_ZSt20get_temporary_bufferIPN6mapbox8geometry5wagyu13local_minimumIiEEESt4pairIPT_xEx]+0x4c):
 undefined reference to `std::nothrow'
 ../deps/wagyu/libwagyu.la(lwgeom_wagyu.o):lwgeom_wagyu.cpp:(.text$_ZSt23return_temporary_bufferIPN6mapbox8geometry5wagyu13local_minimumIiEEEvPT_[_ZSt23return_temporary_bufferIPN6mapbox8geometry5wagyu13local_minimumIiEEEvPT_]+0xf):
 C:/ming64gcc48/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.8.3/../../../../x86_64-w64-mingw32/bin/ld.exe:
 ../deps/wagyu/libwagyu.la(lwgeom_wagyu.o): bad reloc address 0xf in
 section
 `.text$_ZSt23return_temporary_bufferIPN6mapbox8geometry5wagyu13local_minimumIiEEEvPT_[_ZSt23return_temporary_bufferIPN6mapbox8geometry5wagyu13local_minimumIiEEEvPT_]'
 collect2.exe: error: ld returned 1 exit status
 E:/jenkins/postgresql/rel/pg11w64gcc48/lib/pgxs/src/makefiles/../../src/Makefile.shlib:381:
 recipe for target 'postgis-3.dll' failed
 make[1]: *** [postgis-3.dll] Error 1
 make[1]: Leaving directory '/projects/postgis/branches/3.0/postgis'
 GNUmakefile:20: recipe for target 'all' failed
 make: *** [all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4408#comment:4>
