[postgis-tickets] [PostGIS] #4408: can't compile --with-wagyu under mingw64
PostGIS trac at osgeo.org
Fri May 31 17:25:13 PDT 2019
  Reporter:  robe     |      Owner:  Algunenano
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by Algunenano):
 The c++ std library seems to be detected correctly (-lstdc++) but Winnie
 seems to be using Gcc 4.8.3 to build the extension (using whatever was
 used to build postgres), not 8.1.
 Is that right?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4408#comment:5>
