[postgis-tickets] [PostGIS] #4529: can't upgrade from unpackaged 3.0 to 3.0.0rc1 - debbie
PostGIS trac at osgeo.org
Mon Oct 7 09:06:51 PDT 2019
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 debbie is failing upgrading from unpackaged.  I didn't even know she did
 those tests.
 Though I can't make out what exactly failed
 08:54:45 if echo "-v --extension --upgrade-path=unpackaged3.0--3.0.0rc1" |
 grep -vq -- --upgrade; then \
 08:54:45        /usr/bin/perl ../../../regress/run_test.pl --upgrade
 --raster -v --extension --upgrade-path=unpackaged3.0--3.0.0rc1 check_gdal
 load_outdb check_raster_columns check_raster_overviews rt_io rt_bytea
 rt_wkb box3d rt_addband rt_band rt_tile rt_dimensions rt_scale
 rt_pixelsize rt_upperleft rt_rotation rt_georeference rt_set_properties
 rt_isempty rt_hasnoband rt_metadata rt_rastertoworldcoord
 rt_worldtorastercoord rt_convexhull rt_envelope rt_band_properties
 rt_set_band_properties rt_pixelaspolygons rt_pixelaspoints
 rt_pixelascentroids rt_setvalues_array rt_summarystats rt_count
 rt_histogram rt_quantile rt_valuecount rt_valuepercent rt_bandmetadata
 rt_pixelvalue rt_neighborhood rt_nearestvalue rt_pixelofvalue rt_polygon
 rt_setbandpath rt_utility rt_fromgdalraster rt_asgdalraster rt_astiff
 rt_asjpeg rt_aspng rt_reclass rt_gdalwarp rt_asraster rt_dumpvalues
 rt_makeemptycoverage rt_createoverview rt_mapalgebraexpr rt_mapalgebrafct
 rt_mapalgebraexpr_2raster rt_mapalgebrafct_2raster rt_mapalgebrafctngb
 rt_mapalgebrafctngb_userfunc rt_intersection rt_clip rt_mapalgebra
 rt_mapalgebra_expr rt_mapalgebra_mask rt_union rt_invdistweight4ma rt_4ma
 rt_setvalues_geomval rt_elevation_functions rt_colormap rt_grayscale
 rt_gist_relationships rt_intersects rt_samealignment rt_geos_relationships
 rt_iscoveragetile bug_test_car5 permitted_gdal_drivers tickets
 loader/Basic loader/Projected loader/BasicCopy loader/BasicFilename
 loader/BasicOutDB loader/Tiled10x10 loader/Tiled10x10Copy loader/Tiled8x8
 loader/TiledAuto loader/TiledAutoSkipNoData clean; \
 08:54:45 fi
 08:54:45 make: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.0/raster/test/regress'
 08:54:45 PASS: upgrade unpackaged3.0--3.0.0rc1
 08:54:45 Build step 'Execute shell' marked build as failure
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4529>
