[postgis-tickets] [PostGIS] #4529: can't upgrade from unpackaged 3.0 to 3.0.0rc1 - debbie
PostGIS trac at osgeo.org
Mon Oct 7 16:12:39 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  low        |  Milestone:  PostGIS 3.0.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Changes (by robe):
 * owner:  strk => robe
 * priority:  blocker => low
 * component:  build/upgrade/install => buildbots
Comment:
 I'm going to switch this to low.  It seems that some of her upgrade runs
 succeed and when I go look at the failed ones 9.5 and 11, I can't find any
 extension files installed.
 So I suspect what's happening is because PostgreSQL group has high
 activity today, the postgresql build is wiping out the postgresql she's
 running on.  So a case of long standing issue of the carpet is being
 pulled from under her feet.
 The ones that succeed I see extension files installed. I confirmed that
 the ones where I don't see extension files, the tests running with
 extensions are succeeding.  Therefore there must be a point in time when
 those extension files exist.
 I'll keep an eye out but don't think it's worth holding up release for
 this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4529#comment:1>
