[postgis-tickets] [PostGIS] #4531: extensions/postgis/sql/postgis--unpackaged--<current>.sql dirty builds
PostGIS trac at osgeo.org
Tue Oct 8 04:24:01 PDT 2019
 Reporter:  strk     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  high     |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 I have an old revision in my {{{ extensions/postgis/sql/postgis--
 unpackaged--3.0.0rc2dev.sql  }}} file, and even if that file gets
 _removed_ by {{{ make clean }}} it gets back with the old revision upon
 running {{{ make }}} again.
 It seems due to {{{ postgis_upgrade_for_extension.sql.in }}} not being
 removed by {{{ make clean }}} and keeping the old revision around.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4531>
