[postgis-tickets] [PostGIS] #4531: extensions/postgis/sql/postgis--unpackaged--<current>.sql dirty builds
PostGIS trac at osgeo.org
Tue Oct 8 04:30:40 PDT 2019
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by strk):
 It turns out that:
   1. `make clean` does not remove
 extensions/postgis/sql/postgis_upgrade_for_extension.sql.in
   2. `make -C extensions/postgis sql/postgis_upgrade_for_extension.sql.in`
 does not re-generate that file when it exists, even if the file it depends
 upon (`sql/postgis_for_extension.sql`) is not present.
   3. Calling `make -C extensions/postgis sql/postgis_for_extension.sql`
 creates the source file and unleashes the power of `make
 Pretty confusing, isn't it ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4531#comment:1>
