[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. e6a5f6cf2334a7936f220fccd7761c3521a0bc6d
Tue Oct 29 02:17:58 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  e6a5f6cf2334a7936f220fccd7761c3521a0bc6d (commit)
      from  4ae90beb56b677a8497ea2cdc26d1226933c8e4d (commit)
revisions in full, below.
commit e6a5f6cf2334a7936f220fccd7761c3521a0bc6d
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 29 10:17:18 2019 +0100
    Deprecate postgis_svn_version(), replaced by postgis_lib_revision()
diff --git a/NEWS b/NEWS
index 28bce06..bba30be 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,10 @@
 PostGIS 3.1.0
 2020/XX/XX
+* Deprecated signatures *
+  - Function postgis_svn_version() replaced by postgis_lib_revision()
+    (Sandro Santilli)
 * Breaking changes *
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index d3efd20..acc84cc 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -49,6 +49,7 @@ Datum postgis_version(PG_FUNCTION_ARGS);
 Datum postgis_liblwgeom_version(PG_FUNCTION_ARGS);
 Datum postgis_lib_version(PG_FUNCTION_ARGS);
 Datum postgis_svn_version(PG_FUNCTION_ARGS);
+Datum postgis_lib_revision(PG_FUNCTION_ARGS);
 Datum postgis_libxml_version(PG_FUNCTION_ARGS);
 Datum postgis_lib_build_date(PG_FUNCTION_ARGS);
 Datum LWGEOM_length2d_linestring(PG_FUNCTION_ARGS);
@@ -182,9 +183,21 @@ Datum postgis_lib_version(PG_FUNCTION_ARGS)
 	PG_RETURN_TEXT_P(result);
+ * Deprecated as of version 3.1.0 but needs to be kept
+ * around until 4.x as we use the same library filename
+ * for any 3.x.x version of PostGIS and we don't want to
+ * fail at loading the library due to missing symbol.
 PG_FUNCTION_INFO_V1(postgis_svn_version);
+	return postgis_lib_revision(fcinfo);
+PG_FUNCTION_INFO_V1(postgis_lib_revision);
 	static int rev = POSTGIS_SVN_REVISION;
 	char ver[32];
 	if (rev > 0)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index ac6cfd9..ddf7e41 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2757,7 +2757,7 @@ CREATE OR REPLACE FUNCTION postgis_lib_version() RETURNS text
 	LANGUAGE 'c' IMMUTABLE; -- a new lib will require a new session
 -- NOTE: from 1.1.0 to 1.5.x this was the same of postgis_lib_version()
--- NOTE: from 2.0.0 up it includes postgis_svn_revision()
+-- NOTE: from 2.0.0 up it includes postgis revision
 CREATE OR REPLACE FUNCTION postgis_scripts_released() RETURNS text
 	AS 'MODULE_PATHNAME'
@@ -2766,10 +2766,23 @@ CREATE OR REPLACE FUNCTION postgis_geos_version() RETURNS text
-CREATE OR REPLACE FUNCTION postgis_svn_version() RETURNS text
+--- Availability: 3.1.0
+CREATE OR REPLACE FUNCTION postgis_lib_revision() RETURNS text
+--- Availability: 2.0.0
+--- Deprecation in 3.1.0
+CREATE OR REPLACE FUNCTION postgis_svn_version()
+RETURNS text AS $$
+	SELECT @extschema at ._postgis_deprecate(
+		'postgis_svn_version', 'postgis_lib_revision', '3.1.0');
+	SELECT @extschema at .postgis_lib_revision();
+LANGUAGE 'sql' IMMUTABLE SECURITY INVOKER;
 CREATE OR REPLACE FUNCTION postgis_libxml_version() RETURNS text
@@ -2882,7 +2895,7 @@ CREATE OR REPLACE FUNCTION postgis_full_version() RETURNS text
 AS $$
 DECLARE
 	libver text;
-	svnver text;
+	librev text;
 	projver text;
 	geosver text;
 	sfcgalver text;
@@ -2934,7 +2947,7 @@ BEGIN
 	SELECT @extschema at .postgis_libxml_version() INTO libxmlver;
 	SELECT @extschema at .postgis_scripts_installed() INTO dbproc;
 	SELECT @extschema at .postgis_scripts_released() INTO relproc;
-	SELECT @extschema at .postgis_svn_version() INTO svnver;
+	SELECT @extschema at .postgis_lib_revision() INTO librev;
 	BEGIN
 		SELECT topology.postgis_topology_scripts_installed() INTO topo_scr_ver;
 	EXCEPTION
@@ -2966,8 +2979,8 @@ BEGIN
 	fullver = 'POSTGIS="' || libver;
-	IF  svnver IS NOT NULL THEN
-		fullver = fullver || ' r' || svnver;
+	IF  librev IS NOT NULL THEN
+		fullver = fullver || ' r' || librev;
 	END IF;
 	fullver = fullver || '"';
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 0839f60..ccbfea2 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -416,7 +416,9 @@ if ( $OPT_DUMPRESTORE )
 my $geosver =  sql("select postgis_geos_version()");
 my $projver = sql("select postgis_proj_version()");
-my $svnrev = sql("select postgis_svn_version()");
+# TODO: call postgis_lib_revision() instead of postgis_svn_version
+#       if $libver >= 3.1.0
+my $librev = sql("select postgis_svn_version()");
 my $libbuilddate = sql("select postgis_lib_build_date()");
 my $pgsqlver = sql("select version()");
 my $gdalver = sql("select postgis_gdal_version()") if $OPT_WITH_RASTER;
@@ -426,7 +428,7 @@ my $raster_scriptver = sql("select postgis_raster_scripts_installed()")
   if ( $OPT_WITH_RASTER );
 print "$pgsqlver\n";
-print "  Postgis $libver - r${svnrev} - $libbuilddate\n";
+print "  Postgis $libver - (${librev}) - $libbuilddate\n";
 print "  scripts ${scriptver}\n";
 print "  raster scripts ${raster_scriptver}\n" if ( $OPT_WITH_RASTER );
 print "  GEOS: $geosver\n" if $geosver;
Summary of changes:
 NEWS                             |  4 ++++
 postgis/lwgeom_functions_basic.c | 13 +++++++++++++
 postgis/postgis.sql.in           | 25 +++++++++++++++++++------
 regress/run_test.pl              |  6 ++++--
 4 files changed, 40 insertions(+), 8 deletions(-)
hooks/post-receive
