[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 188c3573e7fc1911c7dbec65dd5987beec716f2a
Tue Oct 29 03:43:49 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  188c3573e7fc1911c7dbec65dd5987beec716f2a (commit)
       via  4c128c9f0a7c20c5e55c09890df4927ec3657552 (commit)
      from  e6a5f6cf2334a7936f220fccd7761c3521a0bc6d (commit)
revisions in full, below.
commit 188c3573e7fc1911c7dbec65dd5987beec716f2a
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 29 11:43:26 2019 +0100
    Drop authors.git, not more needed
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 96d3097..9aba0d0 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -169,12 +169,6 @@ fmt:
 commit:
 	$(MAKE) fmt && $(MAKE) clean && $(MAKE) check && svn commit
-authors.git: authors.svn
-	sed -e 's/:/ = /' authors.svn > authors.git
-svnrebase: authors.git
-	git svn rebase --authors-file authors.git
 postgis_revision.h:
 	$(PERL) utils/repo_revision.pl
diff --git a/authors.git b/authors.git
deleted file mode 100644
index 6dd0d75..0000000
--- a/authors.git
+++ /dev/null
@@ -1,33 +0,0 @@
-algunenano = Raúl Marín Rodríguez <rmrodriguez at carto.com>
-benjubb = Ben Jubb <benjubb at refractions.net>
-bergun = Baris Ergun <barisergun75 at gmail.com>
-bjornharrtell = Björn Harrtell <bjorn at wololo.org>
-chodgson = Chris Hodgson <chodgson at refractions.net>
-colivier = Olivier Courtin <olivier.courtin at oslandia.com>
-cvs = No Body <no at body.net>
-dbaston = Daniel Baston <dbaston at gmail.com>
-dblasby = David Blasby <dblasby at gmail.com>
-devrim = Devrim GÜNDÜZ <devrim at gunduz.org>
-dustymugs = Bborie Park <dustymugs at gmail.com>
-dzwarg = David Zwarg <dzwarg at azavea.com>
-jeffloun = Jeff Lounsbury <jeffloun at refractions.net>
-jorgearevalo = Jorge Arévalo <jorge.arevalo at deimos-space.com>
-kneufeld = Kevin Neufeld <kneufeld.ca at gmail.com>
-komzpa = Darafei Praliaskouski <me at komzpa.net>
-mcayland = Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
-mdavis = Martin Davis <mtnclimb at gmail.com>
-mleslie = Mark Leslie <mark.s.leslie at gmail.com>
-mloskot = Mateusz Loskot <mateusz at loskot.net>
-mschaber = Markus Schaber <markus at schabi.de>
-nbarker = Norman Barker <nbarker at ittvis.com>
-nicklas = Nicklas Avén <nicklas.aven at jordogskog.no>
-pracine = Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
-pramsey = Paul Ramsey <pramsey at cleverelephant.ca>
-rmason = Ralph Mason <ralph.mason at telogis.com>
-robe = Regina Obe <lr at pcorp.us>
-snowman = Stephen Frost <sfrost at snowman.net>
-strk = Sandro Santilli <strk at kbt.io>
-warmerdam = Frank Warmerdam <warmerdam at pobox.com>
-woodbri = Stephen Woodbridge <woodbri at swoodbridge.com>
-xingkth = Xing Lin <solo.lin at gmail.com>
-yecarrillo = Eduin Carrillo <yecarrillo at yahoo.com>
commit 4c128c9f0a7c20c5e55c09890df4927ec3657552
Date:   Tue Oct 29 11:27:40 2019 +0100
    Fix postgis revision string to be output of `git describe --always`
    Also rename POSTGIS_SVN_REVISION macro to POSTGIS_REVISION and fix
    code accordingly.
diff --git a/liblwgeom/lwgeom_api.c b/liblwgeom/lwgeom_api.c
index 161060e..64b74c9 100644
--- a/liblwgeom/lwgeom_api.c
+++ b/liblwgeom/lwgeom_api.c
@@ -32,6 +32,9 @@
 #include <assert.h>
 #include "../postgis_revision.h"
+#define xstr(s) str(s)
+#define str(s) #s
 const char *
 lwgeom_version()
@@ -40,7 +43,7 @@ lwgeom_version()
   if ( ! ptr )
     ptr = buf;
-    snprintf(ptr, 256, LIBLWGEOM_VERSION" r%d", POSTGIS_SVN_REVISION);
+    snprintf(ptr, 256, LIBLWGEOM_VERSION" " xstr(POSTGIS_REVISION));
   return ptr;
diff --git a/loader/pgsql2shp-cli.c b/loader/pgsql2shp-cli.c
index 7c5c064..803f0c2 100644
--- a/loader/pgsql2shp-cli.c
+++ b/loader/pgsql2shp-cli.c
@@ -19,13 +19,16 @@
 #include "pgsql2shp-core.h"
 #include "../postgis_config.h"
+#define str(s) #s
 static void
 usage(int status)
   /* TODO: if status != 0 print all to stderr */
-	printf(_( "RELEASE: %s (r%d)\n" ), POSTGIS_LIB_VERSION, POSTGIS_SVN_REVISION);
+	printf(_( "RELEASE: %s (%s)\n" ), POSTGIS_LIB_VERSION,
+		xstr(POSTGIS_REVISION));
 	printf(_("USAGE: pgsql2shp [<options>] <database> [<schema>.]<table>\n"
 	         "       pgsql2shp [<options>] <database> <query>\n"
 	         "\n"
diff --git a/loader/shp2pgsql-cli.c b/loader/shp2pgsql-cli.c
index 8ab1214..efaae13 100644
--- a/loader/shp2pgsql-cli.c
+++ b/loader/shp2pgsql-cli.c
@@ -17,10 +17,14 @@
 #include "shp2pgsql-core.h"
 #include "../liblwgeom/liblwgeom.h" /* for SRID_UNKNOWN */
+#define str(s) #s
 static void
 usage()
+		POSTGIS_LIB_VERSION, xstr(POSTGIS_REVISION));
 	printf(_( "USAGE: shp2pgsql [<options>] <shapefile> [[<schema>.]<table>]\n"
 	          "OPTIONS:\n" ));
 	printf(_( "  -s [<from>:]<srid> Set the SRID field. Defaults to %d.\n"
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index acc84cc..adc6d3f 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -39,6 +39,9 @@
 #include <string.h>
 #include <stdio.h>
+#define str(s) #s
 Datum LWGEOM_mem_size(PG_FUNCTION_ARGS);
 Datum LWGEOM_summary(PG_FUNCTION_ARGS);
 Datum LWGEOM_npoints(PG_FUNCTION_ARGS);
@@ -198,15 +201,15 @@ Datum postgis_svn_version(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(postgis_lib_revision);
 Datum postgis_lib_revision(PG_FUNCTION_ARGS)
-	static int rev = POSTGIS_SVN_REVISION;
+	static char *rev = xstr(POSTGIS_REVISION);
 	char ver[32];
-	if (rev > 0)
+	if (rev && rev[0] != '\0')
-		snprintf(ver, 32, "%d", rev);
+		snprintf(ver, 32, "%s", rev);
+		ver[31] = '\0';
 		PG_RETURN_TEXT_P(cstring_to_text(ver));
-	else
-		PG_RETURN_NULL();
+	else PG_RETURN_NULL();
 PG_FUNCTION_INFO_V1(postgis_lib_build_date);
@@ -223,7 +226,7 @@ Datum postgis_scripts_released(PG_FUNCTION_ARGS)
 	char ver[64];
 	text *result;
-	snprintf(ver, 64, "%s r%d", POSTGIS_LIB_VERSION, POSTGIS_SVN_REVISION);
+	snprintf(ver, 64, "%s %s", POSTGIS_LIB_VERSION, xstr(POSTGIS_REVISION));
 	ver[63] = '\0';
 	result = cstring_to_text(ver);
diff --git a/postgis/sqldefines.h.in b/postgis/sqldefines.h.in
index 058b2b1..95654a8 100644
--- a/postgis/sqldefines.h.in
+++ b/postgis/sqldefines.h.in
@@ -50,8 +50,8 @@
 #define _POSTGIS_SQL_SELECT_POSTGIS_BUILD_DATE 'SELECT ''@POSTGIS_BUILD_DATE@''::text AS version'
 #define _POSTGIS_SQL_SELECT_POSTGIS_PGSQL_VERSION 'SELECT ''@POSTGIS_PGSQL_VERSION@''::text AS version'
-#ifdef POSTGIS_SVN_REVISION
-#define _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION $$ SELECT '@POSTGIS_SCRIPTS_VERSION@'::text || ' r' || POSTGIS_SVN_REVISION::text AS version $$
+#ifdef POSTGIS_REVISION
+#define _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION $$ SELECT '@POSTGIS_SCRIPTS_VERSION@'::text || $rev$ POSTGIS_REVISION$rev$::text AS version $$
 #else
 #define _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION $$ SELECT '@POSTGIS_SCRIPTS_VERSION@'::text AS version $$
 #endif
diff --git a/raster/loader/raster2pgsql.c b/raster/loader/raster2pgsql.c
index 1b1199c..e7317c1 100644
--- a/raster/loader/raster2pgsql.c
+++ b/raster/loader/raster2pgsql.c
@@ -30,6 +30,9 @@
 #include "ogr_srs_api.h"
 #include <assert.h>
+#define str(s) #s
 static void
 loader_rt_error_handler(const char *fmt, va_list ap) {
 	static const char *label = "ERROR: ";
@@ -325,7 +328,7 @@ chartrim(const char *input, char *remove) {
 static void
 usage() {
-	printf(_("RELEASE: %s GDAL_VERSION=%d (r%d)\n"), POSTGIS_LIB_VERSION, POSTGIS_GDAL_VERSION, POSTGIS_SVN_REVISION);
+	printf(_("RELEASE: %s GDAL_VERSION=%d (%s)\n"), POSTGIS_LIB_VERSION, POSTGIS_GDAL_VERSION, xstr(POSTGIS_REVISION));
 	printf(_(
 		"USAGE: raster2pgsql [<options>] <raster>[ <raster>[ ...]] [[<schema>.]<table>]\n"
 		"  Multiple rasters can also be specified using wildcards (*,?).\n"
diff --git a/raster/rt_pg/rtpg_utility.c b/raster/rt_pg/rtpg_utility.c
index ef15dbb..017d265 100644
--- a/raster/rt_pg/rtpg_utility.c
+++ b/raster/rt_pg/rtpg_utility.c
@@ -34,6 +34,9 @@
 #include "../../postgis_config.h"
 #include "lwgeom_pg.h"
+#define str(s) #s
 #include "rtpostgis.h"
 Datum RASTER_lib_version(PG_FUNCTION_ARGS);
@@ -47,7 +50,7 @@ Datum RASTER_lib_version(PG_FUNCTION_ARGS)
     char ver[64];
     text *result;
     ver[63] = '\0';
diff --git a/utils/repo_revision.pl b/utils/repo_revision.pl
index bc092a7..9ee2597 100755
--- a/utils/repo_revision.pl
+++ b/utils/repo_revision.pl
@@ -12,10 +12,10 @@ my $target = 'local';
 $target = $ARGV[0] if $ARGV[0];
 # Read the svn revision number
-my $svn_rev = &read_rev($target);
+my $rev = &read_rev($target);
 # Write it
-&write_defn($svn_rev);
+&write_defn($rev);
 sub read_rev {
@@ -24,25 +24,7 @@ sub read_rev {
   #print STDERR "Target: $target\n";
-  my $svn_info;
-  if ( $target eq "local" ) {
-    if ( -d $top_srcdir."/.svn" ) {
-      #print STDERR "There's a ". $top_srcdir."/.svn dir\n";
-      $svn_info  = &read_rev_svn($target);
-    } elsif ( -e $top_srcdir."/.git" ) {
-      #print STDERR "There's a ". $top_srcdir."/.git dir\n";
-      $svn_info  = &read_rev_git();
-    } else {
-      print STDERR "Can't fetch local revision (neither .svn nor .git found)\n";
-      $svn_info = 0;
-  } else {
-  return $svn_info;
+	return &read_rev_git();
 sub read_rev_git {
@@ -53,18 +35,18 @@ sub read_rev_git {
   my $git_exe = `which git`;
   if ( ! $git_exe ) {
-    print STDERR "Can't fetch SVN revision: no git executable found\n";
-    return 0;
+    print STDERR "Can't determine revision: no git executable found\n";
+    return "";
   chop($git_exe);
-  my $cmd = "\"${git_exe}\" log --grep=git-svn -1 | grep git-svn | cut -d@ -f2 | cut -d' ' -f1";
+  my $cmd = "\"${git_exe}\" describe --always";
   #print STDERR "cmd: ${cmd}\n";
   my $rev  = `$cmd`;
   if ( ! $rev ) {
-    print STDERR "Can't fetch SVN revision from git log\n";
-    $rev = 0;
+    print STDERR "Can't determine revision from git log\n";
+    $rev = "";
   } else {
     chop($rev);
@@ -72,40 +54,6 @@ sub read_rev_git {
   return $rev;
-sub read_rev_svn {
-  my $target = shift;
-  # TODO: test on old systems, I think I saw some `which`
-  #       implementations returning "nothing found" or something
-  #       like that, making the later if ( ! $svn_exe ) always false
-  my $svn_exe = `which svn`;
-  if ( ! $svn_exe ) {
-    print STDERR "Can't fetch SVN revision: no svn executable found\n";
-    return 0;
-  chop($svn_exe);
-  my $svn_info;
-    $svn_info  = `"${svn_exe}" info`;
-  } else {
-    $svn_info  = `"${svn_exe}" info $target`;
-  my $rev;
-  if ( $svn_info =~ /Last Changed Rev: (\d+)/ ) {
-    $rev = $1;
-  } else {
-    print STDERR "Can't fetch SVN revision: no 'Loast Changed Rev' in `svn info` output\n";
-    $rev = 0;
-  return $rev;
 sub write_defn {
   my $rev = shift;
   my $oldrev = 0;
@@ -115,17 +63,17 @@ sub write_defn {
   if ( -f $rev_file ) {
     open(IN, "<$rev_file");
     my $oldrevline = <IN>;
-    if ( $oldrevline =~ /POSTGIS_SVN_REVISION (.*)/ ) {
+    if ( $oldrevline =~ /POSTGIS_REVISION (.*)/ ) {
       $oldrev = $1;
     close(IN);
-    if ( $rev == 0 or $rev == $oldrev ) {
+    if ( $rev eq "" or $rev eq $oldrev ) {
       print STDERR "Not updating existing rev file at $oldrev\n";
       return;
-  my $string = "#define POSTGIS_SVN_REVISION $rev\n";
+  my $string = "#define POSTGIS_REVISION $rev\n";
   open(OUT,">$rev_file");
   print OUT $string;
   close(OUT);
Summary of changes:
 GNUmakefile.in                   |  6 ----
 authors.git                      | 33 ------------------
 liblwgeom/lwgeom_api.c           |  5 ++-
 loader/pgsql2shp-cli.c           |  5 ++-
 loader/shp2pgsql-cli.c           |  6 +++-
 postgis/lwgeom_functions_basic.c | 15 ++++----
 postgis/sqldefines.h.in          |  4 +--
 raster/loader/raster2pgsql.c     |  5 ++-
 raster/rt_pg/rtpg_utility.c      |  5 ++-
 utils/repo_revision.pl           | 74 ++++++----------------------------------
 10 files changed, 43 insertions(+), 115 deletions(-)
 delete mode 100644 authors.git
hooks/post-receive
