[postgis-tickets] [PostGIS] #4666: Port shp2pgsql-gui to GTK 3
PostGIS trac at osgeo.org
Wed Apr 15 09:13:00 PDT 2020
 Reporter:  Bas Couwenberg  |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:
Component:  loader/dumper   |    Version:  3.0.x
 Keywords:                  |
 GTK 2 has been superseded by GTK 3 in 2011, but building the GUI still
 requires gtk-2.0:
 GUI: Build requested, checking for dependencies (GKT+2.0)
 checking for pkg-config... (cached) /usr/bin/x86_64-linux-gnu-pkg-config
 checking for GTK+ - version >= 2.8.0... Package gtk+-2.0 was not found in
 the pkg-config search path.
 Perhaps you should add the directory containing `gtk+-2.0.pc'
 to the PKG_CONFIG_PATH environment variable
 No package 'gtk+-2.0' found
 no
 *** Could not run GTK+ test program, checking why...
 *** The test program failed to compile or link. See the file config.log
 for the
 *** exact error that occured. This usually means GTK+ is incorrectly
 installed.
 Package gdk-2.0 was not found in the pkg-config search path.
 Perhaps you should add the directory containing `gdk-2.0.pc'
 No package 'gdk-2.0' found
 shp2pgsql-gui should be ported to support GTK 3.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4666>
