[postgis-tickets] [PostGIS] #4666: Port shp2pgsql-gui to GTK 3
PostGIS trac at osgeo.org
Wed Apr 15 09:20:56 PDT 2020
  Reporter:  Bas Couwenberg  |      Owner:  robe
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:
 Component:  loader/dumper   |    Version:  3.0.x
Resolution:                  |   Keywords:
Comment (by Bas Couwenberg):
 Patching `configure.ac` to use GTK 3 with the following patch results as
 expected in a build failure:
 Description: Use GTK 3 instead of GTK 2.
 Author: Bas Couwenberg <sebastic at debian.org>
 Bug: https://trac.osgeo.org/postgis/ticket/4666
 Index: postgis-3.0.1+dfsg/configure.ac
 --- postgis-3.0.1+dfsg.orig/configure.ac
 +++ postgis-3.0.1+dfsg/configure.ac
 @@ -1092,17 +1092,17 @@ fi
  dnl
 -dnl Detect GTK+2.0 for GUI
 +dnl Detect GTK+3.0 for GUI
  dnl
  AC_ARG_WITH([gui],
 -       [AS_HELP_STRING([--with-gui], [compile the data import GUI
 (requires GTK+2.0)])],
 +       [AS_HELP_STRING([--with-gui], [compile the data import GUI
 (requires GTK+3.0)])],
         [GUI="yes"], [GUI="no"])
  if test "x$GUI" = "xyes"; then
 -       AC_MSG_RESULT([GUI: Build requested, checking for dependencies
 (GKT+2.0)])
 +       AC_MSG_RESULT([GUI: Build requested, checking for dependencies
 (GKT+3.0)])
         dnl Try to find the GTK libs with pkgconfig
 -       AM_PATH_GTK_2_0([2.8.0], [GTK_BUILD="gui"], [GTK_BUILD=""])
 +       AM_PATH_GTK_3_0([3.0.0], [GTK_BUILD="gui"], [GTK_BUILD=""])
         dnl Add -mwindows to MinGW GUI build
         case $host in
 shp2pgsql-gui.c: In function 'pgui_raise_error_dialogue':
 shp2pgsql-gui.c:286:58: error: 'GTK_DIALOG_NO_SEPARATOR' undeclared (first
 use in this function); did you mean 'GTK_UI_MANAGER_SEPARATOR'?
   286 |                                       GTK_DIALOG_MODAL &
 GTK_DIALOG_NO_SEPARATOR & GTK_DIALOG_DESTROY_WITH_PARENT,
 shp2pgsql-gui.c:286:58: note: each undeclared identifier is reported only
 once for each function it appears in
 shp2pgsql-gui.c:287:39: warning: 'GtkStock' is deprecated [-Wdeprecated-
 declarations]
   287 |                                       GTK_STOCK_OK,
 GTK_RESPONSE_OK, NULL);
 shp2pgsql-gui.c:288:2: warning: implicit declaration of function
 'gtk_dialog_set_has_separator'; did you mean 'gtk_dialog_get_header_bar'?
 [-Wimplicit-function-declaration]
   288 |  gtk_dialog_set_has_separator(GTK_DIALOG(dialog), FALSE );
 In file included from /usr/include/glib-2.0/gobject/gobject.h:24,
                  from /usr/include/glib-2.0/gobject/gbinding.h:29,
                  from /usr/include/glib-2.0/glib-object.h:22,
                  from /usr/include/glib-2.0/gio/gioenums.h:28,
                  from /usr/include/glib-2.0/gio/giotypes.h:28,
                  from /usr/include/glib-2.0/gio/gio.h:26,
                  from /usr/include/gtk-3.0/gdk/gdkapplaunchcontext.h:28,
                  from /usr/include/gtk-3.0/gdk/gdk.h:32,
                  from /usr/include/gtk-3.0/gtk/gtk.h:30,
                  from shp2pgsql-gui.c:23:
 shp2pgsql-gui.c:290:66: error: 'GtkDialog' {aka 'struct _GtkDialog'} has
 no member named 'vbox'
   290 |  gtk_container_set_border_width(GTK_CONTAINER
 (GTK_DIALOG(dialog)->vbox), 15);
 /usr/include/glib-2.0/gobject/gtype.h:2301:57: note: in definition of
 macro '_G_TYPE_CIC'
  2301 |     ((ct*) g_type_check_instance_cast ((GTypeInstance*) ip, gt))
 /usr/include/gtk-3.0/gtk/gtkcontainer.h:38:42: note: in expansion of macro
 'G_TYPE_CHECK_INSTANCE_CAST'
    38 | #define GTK_CONTAINER(obj)
 (G_TYPE_CHECK_INSTANCE_CAST ((obj), GTK_TYPE_CONTAINER, GtkContainer))
 shp2pgsql-gui.c:290:33: note: in expansion of macro 'GTK_CONTAINER'
 shp2pgsql-gui.c:291:52: error: 'GtkDialog' {aka 'struct _GtkDialog'} has
   291 |  gtk_container_add(GTK_CONTAINER(GTK_DIALOG(dialog)->vbox),
 label);
 macro '_G_TYPE_CIC'
 shp2pgsql-gui.c:291:20: note: in expansion of macro 'GTK_CONTAINER'
 label);
 shp2pgsql-gui.c: In function 'pgui_action_handle_file_drop':
 shp2pgsql-gui.c:2063:20: error: dereferencing pointer to incomplete type
 'GtkSelectionData' {aka 'struct _GtkSelectionData'}
  2063 |  if (selection_data->data == NULL)
 shp2pgsql-gui.c: In function 'pgui_create_about_dialog':
 shp2pgsql-gui.c:2561:2: warning: implicit declaration of function
 'gtk_about_dialog_set_name'; did you mean 'gtk_about_dialog_set_logo'?
  2561 |  gtk_about_dialog_set_name(GTK_ABOUT_DIALOG(dialog_about),
 _("PostGIS Shapefile Import/Export Manager"));
 shp2pgsql-gui.c: In function 'pgui_create_filechooser_dialog':
 shp2pgsql-gui.c:2574:3: warning: 'GtkStock' is deprecated [-Wdeprecated-
 declarations]
  2574 |   GTK_FILE_CHOOSER_ACTION_OPEN, GTK_STOCK_CANCEL,
 GTK_RESPONSE_CLOSE, GTK_STOCK_OPEN, GTK_RESPONSE_ACCEPT, NULL);
 declarations]
 shp2pgsql-gui.c: In function 'pgui_create_folderchooser_dialog':
 shp2pgsql-gui.c:2601:3: warning: 'GtkStock' is deprecated [-Wdeprecated-
 declarations]
  2601 |   GTK_FILE_CHOOSER_ACTION_SELECT_FOLDER, GTK_STOCK_CANCEL,
 declarations]
 shp2pgsql-gui.c: In function 'pgui_create_progress_dialog':
 shp2pgsql-gui.c:2623:2: warning: 'GtkStock' is deprecated [-Wdeprecated-
 declarations]
  2623 |  dialog_progress = gtk_dialog_new_with_buttons(_("Working..."),
 GTK_WINDOW(window_main), GTK_DIALOG_DESTROY_WITH_PARENT, GTK_STOCK_CANCEL,
 GTK_RESPONSE_CANCEL, NULL);
 shp2pgsql-gui.c:2634:2: warning: 'gtk_table_new' is deprecated: Use
 'GtkGrid' instead [-Wdeprecated-declarations]
  2634 |  table_progress = gtk_table_new(2, 1, TRUE);
 In file included from /usr/include/gtk-3.0/gtk/gtk.h:280,
 /usr/include/gtk-3.0/gtk/deprecated/gtktable.h:119:12: note: declared here
   119 | GtkWidget* gtk_table_new       (guint  rows,
 shp2pgsql-gui.c:2636:2: warning: 'gtk_table_set_row_spacings' is
 deprecated: Use 'GtkGrid' instead [-Wdeprecated-declarations]
  2636 |  gtk_table_set_row_spacings(GTK_TABLE(table_progress), 5);
 /usr/include/gtk-3.0/gtk/deprecated/gtktable.h:159:9: note: declared here
   159 | void    gtk_table_set_row_spacings (GtkTable        *table,
 shp2pgsql-gui.c:2636:2: warning: 'gtk_table_get_type' is deprecated
 /usr/include/gtk-3.0/gtk/deprecated/gtktable.h:117:10: note: declared here
   117 | GType    gtk_table_get_type       (void) G_GNUC_CONST;
 shp2pgsql-gui.c:2637:2: warning: 'gtk_table_set_col_spacings' is
  2637 |  gtk_table_set_col_spacings(GTK_TABLE(table_progress), 10);
 /usr/include/gtk-3.0/gtk/deprecated/gtktable.h:164:9: note: declared here
   164 | void    gtk_table_set_col_spacings (GtkTable        *table,
 shp2pgsql-gui.c:2637:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2641:2: warning: 'gtk_table_attach_defaults' is
  2641 |  gtk_table_attach_defaults(GTK_TABLE(table_progress),
 label_progress, 0, 1, 0, 1);
 /usr/include/gtk-3.0/gtk/deprecated/gtktable.h:138:9: note: declared here
   138 | void    gtk_table_attach_defaults  (GtkTable        *table,
 shp2pgsql-gui.c:2641:2: warning: 'gtk_table_get_type' is deprecated
 /bin/bash ../libtool --mode=link \
   x86_64-linux-gnu-gcc -I ../liblwgeom  -Wall -Wmissing-prototypes
 -std=gnu99 -g -O2 -fdebug-prefix-map=/build/postgis-3.0.1+dfsg=. -fstack-
 protector-strong -Wformat -Werror=format-security -fno-math-errno -fno-
 signed-zeros  -fPIC -DPIC    shpopen.o dbfopen.o getopt.o shpcommon.o
 safileio.o pgsql2shp-core.o pgsql2shp-cli.o ../liblwgeom/liblwgeom.la
 -L/usr/lib/x86_64-linux-gnu -Wl,-z,relro -Wl,-z,now -L/usr/lib/llvm-10/lib
 -L/usr/lib/x86_64-linux-gnu/mit-krb5 -Wl,--as-needed -static
 ../liblwgeom/liblwgeom.la -lc -L/usr/lib/x86_64-linux-gnu -lpq  -o
 pgsql2shp
 shp2pgsql-gui.c:2645:2: warning: implicit declaration of function
 'gtk_progress_bar_set_orientation'; did you mean
 'gtk_progress_bar_set_fraction'? [-Wimplicit-function-declaration]
  2645 |  gtk_progress_bar_set_orientation(GTK_PROGRESS_BAR(progress),
 GTK_PROGRESS_LEFT_TO_RIGHT);
 shp2pgsql-gui.c:2645:63: error: 'GTK_PROGRESS_LEFT_TO_RIGHT' undeclared
 (first use in this function)
 shp2pgsql-gui.c:2647:2: warning: 'gtk_table_attach_defaults' is
  2647 |  gtk_table_attach_defaults(GTK_TABLE(table_progress), progress, 0,
 1, 1, 2);
 shp2pgsql-gui.c:2647:2: warning: 'gtk_table_get_type' is deprecated
 1, 1, 2);
 shp2pgsql-gui.c:2656:2: warning: implicit declaration of function
 'gtk_signal_connect'; did you mean 'g_signal_connect'? [-Wimplicit-
  2656 |  gtk_signal_connect(GTK_OBJECT(dialog_progress), "delete_event",
 GTK_SIGNAL_FUNC(pgui_action_progress_delete), NULL);
       |  g_signal_connect
 shp2pgsql-gui.c:2656:21: warning: implicit declaration of function
 'GTK_OBJECT'; did you mean 'ATK_OBJECT'? [-Wimplicit-function-declaration]
       |                     ATK_OBJECT
 shp2pgsql-gui.c:2656:66: warning: implicit declaration of function
 'GTK_SIGNAL_FUNC' [-Wimplicit-function-declaration]
 shp2pgsql-gui.c: In function 'pgui_create_options_dialog_add_label':
 shp2pgsql-gui.c:2664:2: warning: 'gtk_alignment_new' is deprecated
  2664 |  GtkWidget *align = gtk_alignment_new(alignment, 0.5, 0.0, 1.0);
 In file included from /usr/include/gtk-3.0/gtk/gtk.h:255,
 /usr/include/gtk-3.0/gtk/deprecated/gtkalignment.h:79:12: note: declared
 here
    79 | GtkWidget* gtk_alignment_new        (gfloat             xalign,
 shp2pgsql-gui.c:2666:2: warning: 'gtk_table_attach_defaults' is
  2666 |  gtk_table_attach_defaults(GTK_TABLE(table), align, 1, 3, row, row
 + 1);
 shp2pgsql-gui.c:2666:2: warning: 'gtk_table_get_type' is deprecated
 + 1);
 shp2pgsql-gui.c: In function 'pgui_create_loader_options_dialog':
 shp2pgsql-gui.c:2677:2: warning: 'GtkStock' is deprecated [-Wdeprecated-
 declarations]
  2677 |  dialog_loader_options = gtk_dialog_new_with_buttons(_("Import
 Options"), GTK_WINDOW(window_main), GTK_DIALOG_DESTROY_WITH_PARENT,
 GTK_STOCK_OK, GTK_RESPONSE_OK, NULL);
 shp2pgsql-gui.c:2683:2: warning: 'gtk_table_new' is deprecated: Use
  2683 |  table_options = gtk_table_new(7, 3, TRUE);
 shp2pgsql-gui.c:2685:2: warning: 'gtk_table_set_row_spacings' is
  2685 |  gtk_table_set_row_spacings(GTK_TABLE(table_options), 5);
 shp2pgsql-gui.c:2685:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2686:2: warning: 'gtk_table_set_col_spacings' is
  2686 |  gtk_table_set_col_spacings(GTK_TABLE(table_options), 10);
 shp2pgsql-gui.c:2686:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2691:2: warning: 'gtk_table_attach_defaults' is
  2691 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 entry_options_encoding, 0, 1, 0, 1 );
 shp2pgsql-gui.c:2691:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2695:2: warning: 'gtk_alignment_new' is deprecated
  2695 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2696:2: warning: 'gtk_table_attach_defaults' is
  2696 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 align_options_center, 0, 1, 1, 2 );
 shp2pgsql-gui.c:2696:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2701:2: warning: 'gtk_alignment_new' is deprecated
  2701 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2702:2: warning: 'gtk_table_attach_defaults' is
  2702 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 align_options_center, 0, 1, 2, 3 );
 shp2pgsql-gui.c:2702:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2707:2: warning: 'gtk_alignment_new' is deprecated
  2707 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2708:2: warning: 'gtk_table_attach_defaults' is
  2708 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 align_options_center, 0, 1, 3, 4 );
 shp2pgsql-gui.c:2708:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2713:2: warning: 'gtk_alignment_new' is deprecated
  2713 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2714:2: warning: 'gtk_table_attach_defaults' is
  2714 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 align_options_center, 0, 1, 4, 5 );
 shp2pgsql-gui.c:2714:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2719:2: warning: 'gtk_alignment_new' is deprecated
  2719 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 0.0 );
 here
 shp2pgsql-gui.c:2720:2: warning: 'gtk_table_attach_defaults' is
  2720 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 align_options_center, 0, 1, 5, 6 );
 shp2pgsql-gui.c:2720:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2725:2: warning: 'gtk_alignment_new' is deprecated
  2725 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2726:2: warning: 'gtk_table_attach_defaults' is
  2726 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 align_options_center, 0, 1, 6, 7 );
 shp2pgsql-gui.c:2726:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2731:2: warning: 'gtk_alignment_new' is deprecated
  2731 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2732:2: warning: 'gtk_table_attach_defaults' is
  2732 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 align_options_center, 0, 1, 7, 8 );
 shp2pgsql-gui.c:2732:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2737:62: error: 'GtkDialog' {aka 'struct _GtkDialog'} has
  2737 |
 gtk_box_pack_start(GTK_BOX(GTK_DIALOG(dialog_loader_options)->vbox),
 table_options, FALSE, FALSE, 0);
 macro '_G_TYPE_CIC'
 /usr/include/gtk-3.0/gtk/gtkbox.h:40:34: note: in expansion of macro
    40 | #define GTK_BOX(obj)            (G_TYPE_CHECK_INSTANCE_CAST
 ((obj), GTK_TYPE_BOX, GtkBox))
 shp2pgsql-gui.c:2737:21: note: in expansion of macro 'GTK_BOX'
  2737 |
 shp2pgsql-gui.c: In function 'pgui_create_dumper_options_dialog':
 shp2pgsql-gui.c:2749:2: warning: 'GtkStock' is deprecated [-Wdeprecated-
 declarations]
  2749 |  dialog_dumper_options = gtk_dialog_new_with_buttons(_("Export
 shp2pgsql-gui.c:2755:2: warning: 'gtk_table_new' is deprecated: Use
  2755 |  table_options = gtk_table_new(3, 3, TRUE);
 shp2pgsql-gui.c:2757:2: warning: 'gtk_table_set_row_spacings' is
  2757 |  gtk_table_set_row_spacings(GTK_TABLE(table_options), 5);
 shp2pgsql-gui.c:2757:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2758:2: warning: 'gtk_table_set_col_spacings' is
  2758 |  gtk_table_set_col_spacings(GTK_TABLE(table_options), 10);
 shp2pgsql-gui.c:2758:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2762:2: warning: 'gtk_alignment_new' is deprecated
  2762 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2763:2: warning: 'gtk_table_attach_defaults' is
  2763 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 align_options_center, 0, 1, 0, 1 );
 shp2pgsql-gui.c:2763:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2768:2: warning: 'gtk_alignment_new' is deprecated
  2768 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2769:2: warning: 'gtk_table_attach_defaults' is
  2769 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 shp2pgsql-gui.c:2769:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2774:2: warning: 'gtk_alignment_new' is deprecated
  2774 |  align_options_center = gtk_alignment_new( 0.5, 0.5, 0.0, 1.0 );
 here
 shp2pgsql-gui.c:2775:2: warning: 'gtk_table_attach_defaults' is
  2775 |  gtk_table_attach_defaults(GTK_TABLE(table_options),
 shp2pgsql-gui.c:2775:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2780:62: error: 'GtkDialog' {aka 'struct _GtkDialog'} has
  2780 |
 gtk_box_pack_start(GTK_BOX(GTK_DIALOG(dialog_dumper_options)->vbox),
 macro '_G_TYPE_CIC'
 shp2pgsql-gui.c:2780:21: note: in expansion of macro 'GTK_BOX'
  2780 |
 shp2pgsql-gui.c: In function 'pgui_create_tablechooser_dialog':
 shp2pgsql-gui.c:2799:5: warning: 'GtkStock' is deprecated [-Wdeprecated-
 declarations]
  2799 |     GTK_DIALOG_MODAL | GTK_DIALOG_DESTROY_WITH_PARENT,
 shp2pgsql-gui.c:2859:2: warning: 'gtk_table_new' is deprecated: Use
  2859 |  table_progress = gtk_table_new(1, 2, FALSE);
 shp2pgsql-gui.c:2861:2: warning: 'gtk_table_set_row_spacings' is
  2861 |  gtk_table_set_row_spacings(GTK_TABLE(table_progress), 0);
 shp2pgsql-gui.c:2861:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2862:2: warning: 'gtk_table_set_col_spacings' is
  2862 |  gtk_table_set_col_spacings(GTK_TABLE(table_progress), 0);
 shp2pgsql-gui.c:2862:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2865:2: warning: 'gtk_table_attach' is deprecated: Use
  2865 |  gtk_table_attach(GTK_TABLE(table_progress),
 checkbutton_chooser_geoonly, 0, 1, 0, 1, GTK_SHRINK, GTK_FILL, 0, 0);
 /usr/include/gtk-3.0/gtk/deprecated/gtktable.h:127:9: note: declared here
   127 | void    gtk_table_attach       (GtkTable        *table,
 shp2pgsql-gui.c:2865:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:2867:2: warning: 'gtk_table_attach' is deprecated: Use
  2867 |  gtk_table_attach(GTK_TABLE(table_progress), label, 1, 2, 0, 1,
 GTK_FILL, GTK_FILL, 5, 0);
 shp2pgsql-gui.c:2867:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c: In function 'pgui_create_import_file_table':
 shp2pgsql-gui.c:2892:2: warning: 'gtk_vbox_new' is deprecated: Use
 'gtk_box_new' instead [-Wdeprecated-declarations]
  2892 |  vbox_tree = gtk_vbox_new(FALSE, 15);
 In file included from /usr/include/gtk-3.0/gtk/gtk.h:286,
 /usr/include/gtk-3.0/gtk/deprecated/gtkvbox.h:61:13: note: declared here
    61 | GtkWidget * gtk_vbox_new      (gboolean homogeneous,
 shp2pgsql-gui.c: In function 'pgui_create_export_table_table':
 shp2pgsql-gui.c:3082:2: warning: 'gtk_vbox_new' is deprecated: Use
  3082 |  vbox_tree = gtk_vbox_new(FALSE, 15);
 shp2pgsql-gui.c: In function 'pgui_create_connection_window':
 shp2pgsql-gui.c:3217:2: warning: 'gtk_vbox_new' is deprecated: Use
  3217 |  vbox = gtk_vbox_new(FALSE, 15);
 shp2pgsql-gui.c:3223:2: warning: 'gtk_table_new' is deprecated: Use
  3223 |  table_pg = gtk_table_new(5, 3, TRUE);
 shp2pgsql-gui.c:3225:2: warning: 'gtk_table_set_col_spacings' is
  3225 |  gtk_table_set_col_spacings(GTK_TABLE(table_pg), 7);
 shp2pgsql-gui.c:3225:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:3226:2: warning: 'gtk_table_set_row_spacings' is
  3226 |  gtk_table_set_row_spacings(GTK_TABLE(table_pg), 3);
 shp2pgsql-gui.c:3226:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:3231:2: warning: 'gtk_table_attach_defaults' is
  3231 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), label, 0, 1, 0, 1
 shp2pgsql-gui.c:3231:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:3232:2: warning: 'gtk_table_attach_defaults' is
  3232 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), entry_pg_user, 1,
 3, 0, 1 );
 shp2pgsql-gui.c:3232:2: warning: 'gtk_table_get_type' is deprecated
 3, 0, 1 );
 shp2pgsql-gui.c:3238:2: warning: 'gtk_table_attach_defaults' is
  3238 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), label, 0, 1, 1, 2
 shp2pgsql-gui.c:3238:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:3239:2: warning: 'gtk_table_attach_defaults' is
  3239 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), entry_pg_pass, 1,
 3, 1, 2 );
 shp2pgsql-gui.c:3239:2: warning: 'gtk_table_get_type' is deprecated
 3, 1, 2 );
 shp2pgsql-gui.c:3245:2: warning: 'gtk_table_attach_defaults' is
  3245 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), label, 0, 1, 2, 3
 shp2pgsql-gui.c:3245:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:3246:2: warning: 'gtk_table_attach_defaults' is
  3246 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), entry_pg_host, 1,
 2, 2, 3 );
 shp2pgsql-gui.c:3246:2: warning: 'gtk_table_get_type' is deprecated
 2, 2, 3 );
 shp2pgsql-gui.c:3250:2: warning: 'gtk_table_attach_defaults' is
  3250 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), entry_pg_port, 2,
 3, 2, 3 );
 shp2pgsql-gui.c:3250:2: warning: 'gtk_table_get_type' is deprecated
 3, 2, 3 );
 shp2pgsql-gui.c:3255:2: warning: 'gtk_table_attach_defaults' is
  3255 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), label, 0, 1, 3, 4
 shp2pgsql-gui.c:3255:2: warning: 'gtk_table_get_type' is deprecated
 shp2pgsql-gui.c:3256:2: warning: 'gtk_table_attach_defaults' is
  3256 |  gtk_table_attach_defaults(GTK_TABLE(table_pg), entry_pg_db, 1, 3,
 3, 4 );
 shp2pgsql-gui.c:3256:2: warning: 'gtk_table_get_type' is deprecated
 3, 4 );
 shp2pgsql-gui.c: In function 'pgui_create_main_window':
 shp2pgsql-gui.c:3337:2: warning: 'gtk_hbox_new' is deprecated: Use
  3337 |  loader_hbox_buttons = gtk_hbox_new(TRUE, 15);
 In file included from /usr/include/gtk-3.0/gtk/gtk.h:262,
 /usr/include/gtk-3.0/gtk/deprecated/gtkhbox.h:63:13: note: declared here
    63 | GtkWidget * gtk_hbox_new      (gboolean homogeneous,
 shp2pgsql-gui.c:3367:2: warning: 'gtk_hbox_new' is deprecated: Use
  3367 |  dumper_hbox_buttons = gtk_hbox_new(TRUE, 15);
 shp2pgsql-gui.c:3409:2: warning: 'gtk_vbox_new' is deprecated: Use
  3409 |  vbox_main = gtk_vbox_new(FALSE, 10);
 shp2pgsql-gui.c:3413:2: warning: 'gtk_vbox_new' is deprecated: Use
  3413 |  vbox_loader = gtk_vbox_new(FALSE, 10);
 shp2pgsql-gui.c:3421:2: warning: 'gtk_vbox_new' is deprecated: Use
  3421 |  vbox_dumper = gtk_vbox_new(FALSE, 10);
 libtool: link: x86_64-linux-gnu-gcc -I ../liblwgeom -Wall -Wmissing-
 prototypes -std=gnu99 -g -O2 -fdebug-prefix-
 map=/build/postgis-3.0.1+dfsg=. -fstack-protector-strong -Wformat -Werror
 =format-security -fno-math-errno -fno-signed-zeros -fPIC -DPIC shpopen.o
 dbfopen.o getopt.o shpcommon.o safileio.o pgsql2shp-core.o pgsql2shp-cli.o
 -Wl,-z -Wl,relro -Wl,-z -Wl,now -Wl,--as-needed -o pgsql2shp
 -L/usr/lib/x86_64-linux-gnu -L/usr/lib/llvm-10/lib -L/usr/lib/x86_64
 -linux-gnu/mit-krb5 ../liblwgeom/.libs/liblwgeom.a -lgeos_c
 /usr/lib/x86_64-linux-gnu/libproj.so -ljson-c -lm -lSFCGAL -lgmpxx -lc
 -lpq -pthread
 make[3]: *** [Makefile:108: shp2pgsql-gui.o] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4666#comment:1>
