[postgis-tickets] [PostGIS] #4667: Fails to build with GCC-10
PostGIS trac at osgeo.org
Fri Apr 17 04:53:30 PDT 2020
 Reporter:  Bas Couwenberg         |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:
Component:  build/upgrade/install  |    Version:  3.0.x
 Keywords:                         |
 As reported by Matthias Klose in [https://bugs.debian.org/957699 Debian
 Bug #957699]:
 > The package fails to build in a test rebuild on at least amd64 with
 > gcc-10/g++-10, but succeeds to build with gcc-9/g++-9. The
 > severity of this report will be raised before the bullseye release,
 > so nothing has to be done for the buster release.
 > The full build log can be found at:
 > http://people.debian.org/~doko/logs/gcc10-20200225/postgis_3.0.1+dfsg-
 1_unstable_gcc10.log
 > The last lines of the build log are at the end of this report.
 > To build with GCC 10, either set CC=gcc-10 CXX=g++-10 explicitly,
 > or install the gcc, g++, gfortran, ... packages from experimental.
 >   apt-get -t=experimental install g++
 > Common build failures are new warnings resulting in build failures with
 > -Werror turned on, or new/dropped symbols in Debian symbols files.
 > For other C/C++ related build failures see the porting guide at
 > http://gcc.gnu.org/gcc-10/porting_to.html
 > make -C cunit check
 > make[4]: Entering directory '/<<PKGBUILDDIR>>/libpgcommon/cunit'
 > make[4]: Nothing to be done for 'check'.
 > make[4]: Leaving directory '/<<PKGBUILDDIR>>/libpgcommon/cunit'
 > make[3]: Leaving directory '/<<PKGBUILDDIR>>/libpgcommon'
 > ---- Making check-unit in postgis
 > make[3]: Entering directory '/<<PKGBUILDDIR>>/postgis'
 > make[3]: Nothing to be done for 'check-unit'.
 > make[3]: Leaving directory '/<<PKGBUILDDIR>>/postgis'
 > ---- Making check-unit in regress
 > make[3]: Entering directory '/<<PKGBUILDDIR>>/regress'
 > make[3]: Leaving directory '/<<PKGBUILDDIR>>/regress'
 > ---- Making check-unit in raster
 > make[3]: Entering directory '/<<PKGBUILDDIR>>/raster'
 > make -C test check-unit
 > make[4]: Entering directory '/<<PKGBUILDDIR>>/raster/test'
 > make -C cunit check
 > make[5]: Entering directory '/<<PKGBUILDDIR>>/raster/test/cunit'
 > x86_64-linux-gnu-gcc -I.. -Wdate-time -D_FORTIFY_SOURCE=2
 -I../../../liblwgeom -I../../rt_core  -I/usr/include/gdal -I/usr/include
 -Wall -Wmissing-prototypes -std=gnu99 -g -O2 -fdebug-prefix-
 map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-
 security -fno-math-errno -fno-signed-zeros  -c -o cu_pixtype.o
 cu_pixtype.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_raster_basics.o
 cu_raster_basics.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_band_basics.o
 cu_band_basics.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_raster_wkb.o
 cu_raster_wkb.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_raster_geometry.o
 cu_raster_geometry.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_raster_misc.o
 cu_raster_misc.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_band_stats.o
 cu_band_stats.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_band_misc.o
 cu_band_misc.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_gdal.o cu_gdal.c
 cu_spatial_relationship.o cu_spatial_relationship.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_mapalgebra.o
 cu_mapalgebra.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_misc.o cu_misc.c
 security -fno-math-errno -fno-signed-zeros  -c -o cu_tester.o cu_tester.c
 > /bin/bash ../../../libtool --mode=link x86_64-linux-gnu-gcc
 security -fno-math-errno -fno-signed-zeros  -o cu_tester cu_pixtype.o
 cu_raster_basics.o cu_band_basics.o cu_raster_wkb.o cu_raster_geometry.o
 cu_raster_misc.o cu_band_stats.o cu_band_misc.o cu_gdal.o
 cu_spatial_relationship.o cu_mapalgebra.o cu_misc.o cu_tester.o
 ../../rt_core/librtcore.a ../../../liblwgeom/.libs/liblwgeom.a -L/usr/lib
 -lgdal -L/usr/lib/x86_64-linux-gnu -lgeos_c -lproj -lm  -Wl,-z,relro
 -Wl,-z,now -lcunit
 > libtool: link: x86_64-linux-gnu-gcc -I../../../liblwgeom -I../../rt_core
 -I/usr/include/gdal -I/usr/include -Wall -Wmissing-prototypes -std=gnu99
 -g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong
 -Wformat -Werror=format-security -fno-math-errno -fno-signed-zeros -o
 cu_tester cu_pixtype.o cu_raster_basics.o cu_band_basics.o cu_raster_wkb.o
 cu_raster_geometry.o cu_raster_misc.o cu_band_stats.o cu_band_misc.o
 cu_gdal.o cu_spatial_relationship.o cu_mapalgebra.o cu_misc.o cu_tester.o
 -Wl,-z -Wl,relro -Wl,-z -Wl,now  ../../rt_core/librtcore.a
 ../../../liblwgeom/.libs/liblwgeom.a -L/usr/lib -lgdal -L/usr/lib/x86_64
 -linux-gnu -lgeos_c /usr/lib/x86_64-linux-gnu/libproj.so -lm -lcunit
 > /usr/bin/ld: cu_raster_basics.o:./raster/test/cunit/cu_tester.h:21:
 multiple definition of `cu_error_msg';
 cu_pixtype.o:./raster/test/cunit/cu_tester.h:21: first defined here
 > /usr/bin/ld: cu_band_basics.o:./raster/test/cunit/cu_tester.h:21:
 > /usr/bin/ld: cu_raster_wkb.o:./raster/test/cunit/cu_tester.h:21:
 > /usr/bin/ld: cu_raster_geometry.o:./raster/test/cunit/cu_tester.h:21:
 > /usr/bin/ld: cu_raster_misc.o:./raster/test/cunit/cu_tester.h:21:
 > /usr/bin/ld: cu_band_stats.o:./raster/test/cunit/cu_tester.h:21:
 > /usr/bin/ld: cu_band_misc.o:./raster/test/cunit/cu_tester.h:21: multiple
 > /usr/bin/ld: cu_gdal.o:./raster/test/cunit/cu_tester.h:21: multiple
 > /usr/bin/ld:
 cu_spatial_relationship.o:./raster/test/cunit/cu_tester.h:21: multiple
 > /usr/bin/ld: cu_mapalgebra.o:./raster/test/cunit/cu_tester.h:21:
 > /usr/bin/ld: cu_misc.o:./raster/test/cunit/cu_tester.h:21: multiple
 > /usr/bin/ld: cu_tester.o:./raster/test/cunit/cu_tester.h:21: multiple
 > collect2: error: ld returned 1 exit status
 > make[5]: *** [Makefile:84: cu_tester] Error 1
 > make[5]: Leaving directory '/<<PKGBUILDDIR>>/raster/test/cunit'
 > make[4]: *** [Makefile:19: check-unit] Error 2
 > make[4]: Leaving directory '/<<PKGBUILDDIR>>/raster/test'
 > make[3]: *** [Makefile:66: check-unit] Error 2
 > make[3]: Leaving directory '/<<PKGBUILDDIR>>/raster'
 > make[2]: *** [GNUmakefile:20: check-unit] Error 1
 > make[2]: Leaving directory '/<<PKGBUILDDIR>>'
 > *** /tmp/pg_virtualenv.FPqNSR/log/postgresql-12-regress.log (last 100
 lines) ***
 > 2020-02-26 12:14:02.110 UTC [29435] LOG:  starting PostgreSQL 12.2
 (Debian 12.2-1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 9.2.1-28)
 9.2.1 20200203, 64-bit
 > 2020-02-26 12:14:02.110 UTC [29435] LOG:  listening on IPv6 address
 "::1", port 5432
 > 2020-02-26 12:14:02.110 UTC [29435] LOG:  listening on IPv4 address
 "127.0.0.1", port 5432
 > 2020-02-26 12:14:02.110 UTC [29435] LOG:  listening on Unix socket
 "/tmp/.s.PGSQL.5432"
 > 2020-02-26 12:14:02.119 UTC [29436] LOG:  database system was shut down
 at 2020-02-26 12:14:02 UTC
 > 2020-02-26 12:14:02.122 UTC [29435] LOG:  database system is ready to
 accept connections
 > Dropping cluster 12/regress ...
 > Can't exec "/bin/ps": No such file or directory at
 /usr/share/perl5/PgCommon.pm line 613.
 > Error: Could not exec /bin/ps
 > Error: This cluster is still running. Stop it or supply the --stop
 option
 > make[1]: *** [debian/rules:181: override_dh_auto_test] Error 2
 > make[1]: Leaving directory '/<<PKGBUILDDIR>>'
 > make: *** [debian/rules:84: build] Error 2
 > dpkg-buildpackage: error: debian/rules build subprocess returned exit
 status 2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4667>
