[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-81-g7a9a699
Mon Apr 27 08:47:54 PDT 2020
the project "PostGIS".
       via  7a9a69951336ba87ce1aa216badd2be3fed60818 (commit)
      from  d25cf5eeadbaed50ca6c12c56c66904b017a3a45 (commit)
revisions in full, below.
commit 7a9a69951336ba87ce1aa216badd2be3fed60818
Author: Raúl Marín <git at rmr.ninja>
Date:   Mon Apr 27 17:47:16 2020 +0200
    SQL: Fix availability for ST_Hexagon and ST_Square
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 15313b4..62f8f19 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5978,7 +5978,7 @@ CREATE OR REPLACE FUNCTION ST_InterpolatePoint(Line geometry, Point geometry)
 -- Grid / Hexagon coverage functions
--- Availability: 3.0.0
+-- Availability: 3.1.0
 CREATE OR REPLACE FUNCTION ST_Hexagon(size float8, cell_i integer, cell_j integer, origin geometry DEFAULT 'POINT(0 0)')
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_Hexagon'
@@ -5986,7 +5986,7 @@ CREATE OR REPLACE FUNCTION ST_Hexagon(size float8, cell_i integer, cell_j intege
 	PARALLEL SAFE
 	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_Square(size float8, cell_i integer, cell_j integer, origin geometry DEFAULT 'POINT(0 0)')
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_Square'
@@ -5994,7 +5994,7 @@ CREATE OR REPLACE FUNCTION ST_Square(size float8, cell_i integer, cell_j integer
 	PARALLEL SAFE
 	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_HexagonGrid(size float8, bounds geometry, OUT geom geometry, OUT i integer, OUT j integer)
     RETURNS SETOF record
 	AS 'MODULE_PATHNAME', 'ST_ShapeGrid'
@@ -6002,7 +6002,7 @@ CREATE OR REPLACE FUNCTION ST_HexagonGrid(size float8, bounds geometry, OUT geom
 	PARALLEL SAFE
 	_COST_MEDIUM;
 CREATE OR REPLACE FUNCTION ST_SquareGrid(size float8, bounds geometry, OUT geom geometry, OUT i integer, OUT j integer)
Summary of changes:
 postgis/postgis.sql.in | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
