[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-82-gd178fcf
Mon Apr 27 14:55:11 PDT 2020
the project "PostGIS".
       via  d178fcfa46d1e1ff7039cdd2231ae63f37b2385f (commit)
      from  7a9a69951336ba87ce1aa216badd2be3fed60818 (commit)
revisions in full, below.
commit d178fcfa46d1e1ff7039cdd2231ae63f37b2385f
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Apr 27 15:42:40 2020 -0400
    Correct invalid SQL and make use of aliasing and LATERAL more explicit
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index e39761e..0fe9437 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -859,13 +859,14 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
 		<para>To do a point summary against a hexagonal tiling, generate a hexagon grid using the
 		extent of the points as the bounds, then spatially join to that grid.</para>
 		 <programlisting>WITH bounds AS (
- 	SELECT ST_SetSRID(ST_EstimatedExtent('pointtable', 'geom'), 3857) AS geom
+ 	SELECT ST_SetSRID(ST_EstimatedExtent('pointtable', 'geom'),3857) AS geom
  SELECT Count(*), hexes.geom
- FROM pointtable pts
- JOIN ST_HexagonGrid(1000, bounds.geom) hexes
- GROUP BY hexes.geom
-</programlisting>
+ FROM bounds CROSS JOIN
+ 	LATERAL ST_HexagonGrid(10000, bounds.geom) AS hexes
+ INNER JOIN  pointtable AS pts
+ 	ON ST_Intersects(pts.geom, hexes.geom)
+ GROUP BY hexes.geom;</programlisting>
 		</refsection>
 		<refsection>
@@ -880,13 +881,13 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
 			hexagons overlapping at the borders between states.</para>
 		 <programlisting>WITH hexes AS (
 	SELECT admin1.gid,
-	       (ST_HexagonGrid(100000, admin1.geom)).* AS hex
-	FROM admin1
+	      hex.geom
+	FROM admin1 CROSS JOIN ST_HexagonGrid(100000, admin1.geom) AS hex
 	WHERE adm0_a3 = 'USA'
 SELECT hexes.*
 FROM hexes
-JOIN admin1 USING (gid)
+INNER JOIN admin1 ON hexes.gid = admin1.gid
 WHERE ST_Intersects(admin1.geom, hexes.geom)
 </programlisting>
 		</refsection>
Summary of changes:
 doc/reference_constructor.xml | 17 +++++++++--------
 1 file changed, 9 insertions(+), 8 deletions(-)
hooks/post-receive
