[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-83-g430a5c3
Mon Apr 27 15:38:55 PDT 2020
the project "PostGIS".
       via  430a5c3feb64ffb7dddd01a1f417a39f0bed39eb (commit)
      from  d178fcfa46d1e1ff7039cdd2231ae63f37b2385f (commit)
revisions in full, below.
commit 430a5c3feb64ffb7dddd01a1f417a39f0bed39eb
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Apr 27 18:38:48 2020 -0400
    Minor formatting changes and consistent use of lateral
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 0fe9437..4303aa2 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -859,13 +859,13 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
 		<para>To do a point summary against a hexagonal tiling, generate a hexagon grid using the
 		extent of the points as the bounds, then spatially join to that grid.</para>
 		 <programlisting>WITH bounds AS (
- 	SELECT ST_SetSRID(ST_EstimatedExtent('pointtable', 'geom'),3857) AS geom
+ 		SELECT ST_SetSRID(ST_EstimatedExtent('pointtable', 'geom'),3857) AS geom
- SELECT Count(*), hexes.geom
- FROM bounds CROSS JOIN
- 	LATERAL ST_HexagonGrid(10000, bounds.geom) AS hexes
- INNER JOIN  pointtable AS pts
- 	ON ST_Intersects(pts.geom, hexes.geom)
+ SELECT COUNT(*), hexes.geom
+ FROM bounds
+ 	CROSS JOIN
+ 		LATERAL ST_HexagonGrid(10000, bounds.geom) AS hexes
+	INNER JOIN pointtable AS pts ON ST_Intersects(pts.geom, hexes.geom)
  GROUP BY hexes.geom;</programlisting>
 		</refsection>
@@ -880,14 +880,14 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
 		<para>Tiling states results in a hexagon coverage of each state, and multiple
 			hexagons overlapping at the borders between states.</para>
 		 <programlisting>WITH hexes AS (
-	SELECT admin1.gid,
-	      hex.geom
-	FROM admin1 CROSS JOIN ST_HexagonGrid(100000, admin1.geom) AS hex
+	SELECT admin1.gid, hex.geom
+	FROM admin1
+		CROSS JOIN LATERAL ST_HexagonGrid(100000, admin1.geom) AS hex
 	WHERE adm0_a3 = 'USA'
 SELECT hexes.*
 FROM hexes
-INNER JOIN admin1 ON hexes.gid = admin1.gid
+	INNER JOIN admin1 ON hexes.gid = admin1.gid
 WHERE ST_Intersects(admin1.geom, hexes.geom)
 </programlisting>
 		</refsection>
Summary of changes:
 doc/reference_constructor.xml | 20 ++++++++++----------
 1 file changed, 10 insertions(+), 10 deletions(-)
hooks/post-receive
