[postgis-tickets] [SCM] PostGIS branch master updated. 1152d813c0dbd00b61506908d8c0d78902a8ea43
Tue Jan 14 11:00:41 PST 2020
the project "PostGIS".
       via  1152d813c0dbd00b61506908d8c0d78902a8ea43 (commit)
      from  2ee8e58e5f2401951cd9cd9765274100c324376d (commit)
revisions in full, below.
commit 1152d813c0dbd00b61506908d8c0d78902a8ea43
Author: Kristian Thy <thy at 42.dk>
Date:   Wed Jan 8 10:19:47 2020 +0100
    Optional value params for Force3D*, Force4D functions
    Changes internal signature of lwgeom_force_* functions.
    Closes #3057
    Closes https://github.com/postgis/postgis/pull/531
    Signed-off-by: Raúl Marín <git at rmr.ninja>
diff --git a/NEWS b/NEWS
index 27229a2..8e792b4 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,7 @@ PostGIS 3.1.0
   - #4601, Add ST_TileEnvelope margin argument (Yuri Astrakhan)
   - #2972, Add quiet mode (-q) to pgsql2shp (Kristian Thy)
   - #4617, Add configure switch `--without-phony-revision` (Raúl Marín)
+  - #3057, Optional value params for Force3D*, Force4D functions (Kristian Thy)
 * Enhancements *
   - #4539, Unify libm includes (Raúl Marín)
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index ca08002..7e52ea2 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -254,6 +254,7 @@ SELECT  ST_AsEWKT(ST_Force2D('POLYGON((0 0 2,0 5 2,5 0 2,0 0 2),(1 1 2,3 1 2,1 3
 		  <funcprototype>
 			<funcdef>geometry <function>ST_Force3D</function></funcdef>
 			<paramdef><type>geometry </type> <parameter>geomA</parameter></paramdef>
+			<paramdef><type>float </type> <parameter>Zvalue = 0.0</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -261,10 +262,11 @@ SELECT  ST_AsEWKT(ST_Force2D('POLYGON((0 0 2,0 5 2,5 0 2,0 0 2),(1 1 2,3 1 2,1 3
 	  <refsection>
 		<title>Description</title>
-		<para>Forces the geometries into XYZ mode.  This is an alias for ST_Force_3DZ. If a geometry has no Z component, then a 0 Z coordinate is tacked on.</para>
+        <para>Forces the geometries into XYZ mode. This is an alias for ST_Force3DZ. If a geometry has no Z component, then a <parameter>Zvalue</parameter> Z coordinate is tacked on.</para>
 		<para>Enhanced: 2.0.0 support for Polyhedral surfaces was introduced.</para>
 		<para>Changed: 2.1.0. Up to 2.0.x this was called ST_Force_3D.</para>
+		<para>Changed: 3.1.0. Added support for supplying a non-zero Z value.</para>
 		<para>&P_support;</para>
 		<para>&curve_support;</para>
 		<para>&Z_support;</para>
@@ -310,6 +312,7 @@ SELECT  ST_AsEWKT(ST_Force3D('POLYGON((0 0,0 5,5 0,0 0),(1 1,3 1,1 3,1 1))'));
 		  <funcprototype>
 			<funcdef>geometry <function>ST_Force3DZ</function></funcdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -317,10 +320,11 @@ SELECT  ST_AsEWKT(ST_Force3D('POLYGON((0 0,0 5,5 0,0 0),(1 1,3 1,1 3,1 1))'));
 	  <refsection>
-		<para>Forces the geometries into XYZ mode.  This is a synonym for ST_Force3DZ. If a geometry has no Z component, then a 0 Z coordinate is tacked on.</para>
+		<para>Forces the geometries into XYZ mode. If a geometry has no Z component, then a <parameter>Zvalue</parameter> Z coordinate is tacked on.</para>
 		<para>Changed: 2.1.0. Up to 2.0.x this was called ST_Force_3DZ.</para>
@@ -366,6 +370,7 @@ SELECT  ST_AsEWKT(ST_Force3DZ('POLYGON((0 0,0 5,5 0,0 0),(1 1,3 1,1 3,1 1))'));
 		  <funcprototype>
 			<funcdef>geometry <function>ST_Force3DM</function></funcdef>
+			<paramdef><type>float </type> <parameter>Mvalue = 0.0</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -373,10 +378,11 @@ SELECT  ST_AsEWKT(ST_Force3DZ('POLYGON((0 0,0 5,5 0,0 0),(1 1,3 1,1 3,1 1))'));
 	  <refsection>
-		<para>Forces the geometries into XYM mode.  If a geometry has no M component, then a 0 M coordinate is tacked on.  If it has a Z component, then Z is removed</para>
+		<para>Forces the geometries into XYM mode. If a geometry has no M component, then a <parameter>Mvalue</parameter> M coordinate is tacked on.  If it has a Z component, then Z is removed</para>
-		  <para>Changed: 2.1.0. Up to 2.0.x this was called ST_Force_3DM.</para>
+		<para>Changed: 2.1.0. Up to 2.0.x this was called ST_Force_3DM.</para>
+		<para>Changed: 3.1.0. Added support for supplying a non-zero M value.</para>
 	  </refsection>
@@ -421,6 +427,8 @@ SELECT  ST_AsEWKT(ST_Force3DM('POLYGON((0 0 1,0 5 1,5 0 1,0 0 1),(1 1 1,3 1 1,1
 		  <funcprototype>
 			<funcdef>geometry <function>ST_Force4D</function></funcdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -428,9 +436,10 @@ SELECT  ST_AsEWKT(ST_Force3DM('POLYGON((0 0 1,0 5 1,5 0 1,0 0 1),(1 1 1,3 1 1,1
 	  <refsection>
-		<para>Forces the geometries into XYZM mode.  0 is tacked on for missing Z and M dimensions. </para>
+		<para>Forces the geometries into XYZM mode. <parameter>Zvalue</parameter> and <parameter>Mvalue</parameter> is tacked on for missing Z and M dimensions, respectively. </para>
-		  <para>Changed: 2.1.0. Up to 2.0.x this was called ST_Force_4D.</para>
+		<para>Changed: 2.1.0. Up to 2.0.x this was called ST_Force_4D.</para>
+		<para>Changed: 3.1.0. Added support for supplying non-zero Z and M values.</para>
 	  </refsection>
diff --git a/liblwgeom/cunit/Makefile.in b/liblwgeom/cunit/Makefile.in
index 2780e11..008821b 100644
--- a/liblwgeom/cunit/Makefile.in
+++ b/liblwgeom/cunit/Makefile.in
@@ -50,6 +50,7 @@ OBJS=	\
 	cu_stringbuffer.o \
 	cu_triangulate.o \
 	cu_homogenize.o \
+	cu_force_dims.o \
 	cu_force_sfs.o \
 	cu_out_twkb.o \
 	cu_out_wkt.o \
diff --git a/liblwgeom/cunit/cu_force_dims.c b/liblwgeom/cunit/cu_force_dims.c
new file mode 100644
index 0000000..68a6862
--- /dev/null
+++ b/liblwgeom/cunit/cu_force_dims.c
@@ -0,0 +1,118 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * Copyright (C) 2008 Paul Ramsey
+ * Copyright (C) 2020 Kristian Thy <thy at 42.dk>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU General Public Licence. See the COPYING file.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include "CUnit/Basic.h"
+#include "liblwgeom_internal.h"
+#include "cu_tester.h"
+static void
+test_force_2d(void)
+	LWGEOM *geom;
+	LWGEOM *geom2d;
+	char *wkt_out;
+	geom = lwgeom_from_wkt("CIRCULARSTRINGM(-5 0 4,0 5 3,5 0 2,10 -5 1,15 0 0)", LW_PARSER_CHECK_NONE);
+	geom2d = lwgeom_force_2d(geom);
+	wkt_out = lwgeom_to_ewkt(geom2d);
+	CU_ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0,0 5,5 0,10 -5,15 0)", wkt_out);
+	lwgeom_free(geom);
+	lwgeom_free(geom2d);
+	lwfree(wkt_out);
+	    "GEOMETRYCOLLECTION(POINT(0 0 0),LINESTRING(1 1 1,2 2 2),POLYGON((0 0 1,0 1 1,1 1 1,1 0 1,0 0 1)),CURVEPOLYGON(CIRCULARSTRING(0 0 0,1 1 1,2 2 2,1 1 1,0 0 0)))",
+	    LW_PARSER_CHECK_NONE);
+	    "GEOMETRYCOLLECTION(POINT(0 0),LINESTRING(1 1,2 2),POLYGON((0 0,0 1,1 1,1 0,0 0)),CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 2,1 1,0 0)))",
+	    wkt_out);
+	lwfree(wkt_out);
+static void
+test_force_3dm(void)
+	LWGEOM *geom;
+	LWGEOM *geom3dm;
+	char *wkt_out;
+	geom = lwgeom_from_wkt("CIRCULARSTRING(-5 0 4,0 5 3,5 0 2,10 -5 1,15 0 0)", LW_PARSER_CHECK_NONE);
+	geom3dm = lwgeom_force_3dm(geom, 1);
+	wkt_out = lwgeom_to_ewkt(geom3dm);
+	CU_ASSERT_STRING_EQUAL("CIRCULARSTRINGM(-5 0 1,0 5 1,5 0 1,10 -5 1,15 0 1)", wkt_out);
+	lwgeom_free(geom3dm);
+	lwfree(wkt_out);
+static void
+test_force_3dz(void)
+	LWGEOM *geom;
+	LWGEOM *geom3dz;
+	char *wkt_out;
+	geom = lwgeom_from_wkt("CIRCULARSTRING(-5 0,0 5,5 0,10 -5,15 0)", LW_PARSER_CHECK_NONE);
+	geom3dz = lwgeom_force_3dz(geom, -99);
+	wkt_out = lwgeom_to_ewkt(geom3dz);
+	CU_ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0 -99,0 5 -99,5 0 -99,10 -5 -99,15 0 -99)", wkt_out);
+	lwgeom_free(geom3dz);
+	lwfree(wkt_out);
+	geom3dz = lwgeom_force_3dz(geom, 0.0);
+	CU_ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0 0,0 5 0,5 0 0,10 -5 0,15 0 0)", wkt_out);
+	lwfree(wkt_out);
+static void
+test_force_4d(void)
+	LWGEOM *geom;
+	LWGEOM *geom4d;
+	char *wkt_out;
+	geom = lwgeom_from_wkt("POINT(1 2)", LW_PARSER_CHECK_NONE);
+	geom4d = lwgeom_force_4d(geom, 3, 4);
+	wkt_out = lwgeom_to_ewkt(geom4d);
+	CU_ASSERT_STRING_EQUAL("POINT(1 2 3 4)", wkt_out);
+	lwgeom_free(geom4d);
+	lwfree(wkt_out);
+** Used by the test harness to register the tests in this file.
+void force_dims_suite_setup(void);
+void
+force_dims_suite_setup(void)
+	CU_pSuite suite = CU_add_suite("force_dims", NULL, NULL);
+	PG_ADD_TEST(suite, test_force_2d);
+	PG_ADD_TEST(suite, test_force_3dm);
+	PG_ADD_TEST(suite, test_force_3dz);
+	PG_ADD_TEST(suite, test_force_4d);
diff --git a/liblwgeom/cunit/cu_misc.c b/liblwgeom/cunit/cu_misc.c
index d1f76eb..8cb483e 100644
--- a/liblwgeom/cunit/cu_misc.c
+++ b/liblwgeom/cunit/cu_misc.c
@@ -18,29 +18,6 @@
-static void test_misc_force_2d(void)
-	LWGEOM *geom;
-	LWGEOM *geom2d;
-	char *wkt_out;
-	geom = lwgeom_from_wkt("CIRCULARSTRINGM(-5 0 4,0 5 3,5 0 2,10 -5 1,15 0 0)", LW_PARSER_CHECK_NONE);
-	geom2d = lwgeom_force_2d(geom);
-	wkt_out = lwgeom_to_ewkt(geom2d);
-	CU_ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0,0 5,5 0,10 -5,15 0)",wkt_out);
-	lwgeom_free(geom);
-	lwgeom_free(geom2d);
-	lwfree(wkt_out);
-	geom = lwgeom_from_wkt("GEOMETRYCOLLECTION(POINT(0 0 0),LINESTRING(1 1 1,2 2 2),POLYGON((0 0 1,0 1 1,1 1 1,1 0 1,0 0 1)),CURVEPOLYGON(CIRCULARSTRING(0 0 0,1 1 1,2 2 2,1 1 1,0 0 0)))", LW_PARSER_CHECK_NONE);
-	CU_ASSERT_STRING_EQUAL("GEOMETRYCOLLECTION(POINT(0 0),LINESTRING(1 1,2 2),POLYGON((0 0,0 1,1 1,1 0,0 0)),CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 2,1 1,0 0)))",wkt_out);
-	lwfree(wkt_out);
 static void test_misc_simplify(void)
 	LWGEOM *geom;
@@ -265,7 +242,6 @@ void misc_suite_setup(void);
 	CU_pSuite suite = CU_add_suite("miscellaneous", NULL, NULL);
-	PG_ADD_TEST(suite, test_misc_force_2d);
 	PG_ADD_TEST(suite, test_misc_simplify);
 	PG_ADD_TEST(suite, test_misc_count_vertices);
 	PG_ADD_TEST(suite, test_misc_area);
diff --git a/liblwgeom/cunit/cu_tester.c b/liblwgeom/cunit/cu_tester.c
index 605386a..ac979da 100644
--- a/liblwgeom/cunit/cu_tester.c
+++ b/liblwgeom/cunit/cu_tester.c
@@ -35,6 +35,7 @@ extern void algorithms_suite_setup();
 extern void buildarea_suite_setup();
 extern void clean_suite_setup();
 extern void clip_by_rect_suite_setup();
+extern void force_dims_suite_setup(void);
 extern void force_sfs_suite_setup(void);
 extern void geodetic_suite_setup(void);
 extern void geos_suite_setup(void);
@@ -86,6 +87,7 @@ PG_SuiteSetup setupfuncs[] =
 	buildarea_suite_setup,
 	clean_suite_setup,
 	clip_by_rect_suite_setup,
+	force_dims_suite_setup,
 	force_sfs_suite_setup,
 	geodetic_suite_setup,
 	geos_suite_setup,
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 516cfaa..b6c4475 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1066,9 +1066,9 @@ extern POINTARRAY *ptarray_substring(POINTARRAY *pa, double d1, double d2,
 * Strip out the Z/M components of an #LWGEOM
 extern LWGEOM* lwgeom_force_2d(const LWGEOM *geom);
-extern LWGEOM* lwgeom_force_3dz(const LWGEOM *geom);
-extern LWGEOM* lwgeom_force_3dm(const LWGEOM *geom);
-extern LWGEOM* lwgeom_force_4d(const LWGEOM *geom);
+extern LWGEOM* lwgeom_force_3dz(const LWGEOM *geom, double zval);
+extern LWGEOM* lwgeom_force_3dm(const LWGEOM *geom, double mval);
+extern LWGEOM* lwgeom_force_4d(const LWGEOM *geom, double zval, double mval);
 extern LWGEOM* lwgeom_set_effective_area(const LWGEOM *igeom, int set_area, double area);
 extern LWGEOM* lwgeom_chaikin(const LWGEOM *igeom, int n_iterations, int preserve_endpoint);
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index c98eaa9..e47d6d4 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -180,12 +180,12 @@
 * Force dims
-LWGEOM* lwgeom_force_dims(const LWGEOM *lwgeom, int hasz, int hasm);
-LWPOINT* lwpoint_force_dims(const LWPOINT *lwpoint, int hasz, int hasm);
-LWLINE* lwline_force_dims(const LWLINE *lwline, int hasz, int hasm);
-LWPOLY* lwpoly_force_dims(const LWPOLY *lwpoly, int hasz, int hasm);
-LWCOLLECTION* lwcollection_force_dims(const LWCOLLECTION *lwcol, int hasz, int hasm);
-POINTARRAY* ptarray_force_dims(const POINTARRAY *pa, int hasz, int hasm);
+LWGEOM* lwgeom_force_dims(const LWGEOM *lwgeom, int hasz, int hasm, double zval, double mval);
+LWPOINT* lwpoint_force_dims(const LWPOINT *lwpoint, int hasz, int hasm, double zval, double mval);
+LWLINE* lwline_force_dims(const LWLINE *lwline, int hasz, int hasm, double zval, double mval);
+LWPOLY* lwpoly_force_dims(const LWPOLY *lwpoly, int hasz, int hasm, double zval, double mval);
+LWCOLLECTION* lwcollection_force_dims(const LWCOLLECTION *lwcol, int hasz, int hasm, double zval, double mval);
+POINTARRAY* ptarray_force_dims(const POINTARRAY *pa, int hasz, int hasm, double zval, double mval);
  * Swap ordinate values o1 and o2 on a given POINTARRAY
diff --git a/liblwgeom/lwcollection.c b/liblwgeom/lwcollection.c
index 20b4b5e..e64d723 100644
--- a/liblwgeom/lwcollection.c
+++ b/liblwgeom/lwcollection.c
@@ -483,7 +483,7 @@ lwcollection_extract(LWCOLLECTION* col, int type)
 LWCOLLECTION*
-lwcollection_force_dims(const LWCOLLECTION *col, int hasz, int hasm)
+lwcollection_force_dims(const LWCOLLECTION *col, int hasz, int hasm, double zval, double mval)
 	LWCOLLECTION *colout;
@@ -499,7 +499,7 @@ lwcollection_force_dims(const LWCOLLECTION *col, int hasz, int hasm)
 		geoms = lwalloc(sizeof(LWGEOM*) * col->ngeoms);
 		for( i = 0; i < col->ngeoms; i++ )
-			geoms[i] = lwgeom_force_dims(col->geoms[i], hasz, hasm);
+			geoms[i] = lwgeom_force_dims(col->geoms[i], hasz, hasm, zval, mval);
 		colout = lwcollection_construct(col->type, col->srid, NULL, col->ngeoms, geoms);
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index a9fbfd4..ddcf11d 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -774,42 +774,42 @@ lwgeom_segmentize2d(const LWGEOM *lwgeom, double dist)
 LWGEOM*
-	return lwgeom_force_dims(geom, 0, 0);
+	return lwgeom_force_dims(geom, 0, 0, 0, 0);
 LWGEOM*
-lwgeom_force_3dz(const LWGEOM *geom)
+lwgeom_force_3dz(const LWGEOM *geom, double zval)
-	return lwgeom_force_dims(geom, 1, 0);
+	return lwgeom_force_dims(geom, 1, 0, zval, 0);
 LWGEOM*
-lwgeom_force_3dm(const LWGEOM *geom)
+lwgeom_force_3dm(const LWGEOM *geom, double mval)
-	return lwgeom_force_dims(geom, 0, 1);
+	return lwgeom_force_dims(geom, 0, 1, 0, mval);
 LWGEOM*
-lwgeom_force_4d(const LWGEOM *geom)
+lwgeom_force_4d(const LWGEOM *geom, double zval, double mval)
-	return lwgeom_force_dims(geom, 1, 1);
+	return lwgeom_force_dims(geom, 1, 1, zval, mval);
 LWGEOM*
-lwgeom_force_dims(const LWGEOM *geom, int hasz, int hasm)
+lwgeom_force_dims(const LWGEOM *geom, int hasz, int hasm, double zval, double mval)
 	if (!geom)
 		return NULL;
 	switch(geom->type)
 		case POINTTYPE:
-			return lwpoint_as_lwgeom(lwpoint_force_dims((LWPOINT*)geom, hasz, hasm));
+			return lwpoint_as_lwgeom(lwpoint_force_dims((LWPOINT*)geom, hasz, hasm, zval, mval));
 		case CIRCSTRINGTYPE:
 		case LINETYPE:
 		case TRIANGLETYPE:
-			return lwline_as_lwgeom(lwline_force_dims((LWLINE*)geom, hasz, hasm));
+			return lwline_as_lwgeom(lwline_force_dims((LWLINE*)geom, hasz, hasm, zval, mval));
 		case POLYGONTYPE:
-			return lwpoly_as_lwgeom(lwpoly_force_dims((LWPOLY*)geom, hasz, hasm));
+			return lwpoly_as_lwgeom(lwpoly_force_dims((LWPOLY*)geom, hasz, hasm, zval, mval));
 		case COMPOUNDTYPE:
 		case CURVEPOLYTYPE:
 		case MULTICURVETYPE:
@@ -820,7 +820,7 @@ lwgeom_force_dims(const LWGEOM *geom, int hasz, int hasm)
 		case POLYHEDRALSURFACETYPE:
 		case TINTYPE:
 		case COLLECTIONTYPE:
-			return lwcollection_as_lwgeom(lwcollection_force_dims((LWCOLLECTION*)geom, hasz, hasm));
+			return lwcollection_as_lwgeom(lwcollection_force_dims((LWCOLLECTION*)geom, hasz, hasm, zval, mval));
 		default:
 			lwerror("lwgeom_force_2d: unsupported geom type: %s", lwtype_name(geom->type));
 			return NULL;
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 672870d..6106e81 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -5046,7 +5046,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
       POINT4D p4d;
       LWPOINT *prjpt;
       /* add Z to "prj" */
-      tmp = lwgeom_force_3dz(prj);
+      tmp = lwgeom_force_3dz(prj, 0);
       prjpt = lwgeom_as_lwpoint(tmp);
       getPoint4d_p(point->point, 0, &p4d);
       z = p4d.z;
diff --git a/liblwgeom/lwline.c b/liblwgeom/lwline.c
index 4406b07..af5b67e 100644
--- a/liblwgeom/lwline.c
+++ b/liblwgeom/lwline.c
@@ -483,7 +483,7 @@ lwline_is_trajectory(const LWLINE *line)
 LWLINE*
-lwline_force_dims(const LWLINE *line, int hasz, int hasm)
+lwline_force_dims(const LWLINE *line, int hasz, int hasm, double zval, double mval)
 	POINTARRAY *pdims = NULL;
 	LWLINE *lineout;
@@ -495,7 +495,7 @@ lwline_force_dims(const LWLINE *line, int hasz, int hasm)
 	else
-		pdims = ptarray_force_dims(line->points, hasz, hasm);
+		pdims = ptarray_force_dims(line->points, hasz, hasm, zval, mval);
 		lineout = lwline_construct(line->srid, NULL, pdims);
 	lineout->type = line->type;
diff --git a/liblwgeom/lwpoint.c b/liblwgeom/lwpoint.c
index 0656863..3f28c06 100644
--- a/liblwgeom/lwpoint.c
+++ b/liblwgeom/lwpoint.c
@@ -268,7 +268,7 @@ lwpoint_same(const LWPOINT *p1, const LWPOINT *p2)
 LWPOINT*
-lwpoint_force_dims(const LWPOINT *point, int hasz, int hasm)
+lwpoint_force_dims(const LWPOINT *point, int hasz, int hasm, double zval, double mval)
 	LWPOINT *pointout;
@@ -281,7 +281,7 @@ lwpoint_force_dims(const LWPOINT *point, int hasz, int hasm)
 	else
 		/* Always we duplicate the ptarray and return */
-		pdims = ptarray_force_dims(point->point, hasz, hasm);
+		pdims = ptarray_force_dims(point->point, hasz, hasm, zval, mval);
 		pointout = lwpoint_construct(point->srid, NULL, pdims);
 	pointout->type = point->type;
diff --git a/liblwgeom/lwpoly.c b/liblwgeom/lwpoly.c
index 7ebf739..e35fe2e 100644
--- a/liblwgeom/lwpoly.c
+++ b/liblwgeom/lwpoly.c
@@ -391,7 +391,7 @@ lwpoly_from_lwlines(const LWLINE *shell,
 LWPOLY*
-lwpoly_force_dims(const LWPOLY *poly, int hasz, int hasm)
+lwpoly_force_dims(const LWPOLY *poly, int hasz, int hasm, double zval, double mval)
 	LWPOLY *polyout;
@@ -407,7 +407,7 @@ lwpoly_force_dims(const LWPOLY *poly, int hasz, int hasm)
 		rings = lwalloc(sizeof(POINTARRAY*) * poly->nrings);
 		for( i = 0; i < poly->nrings; i++ )
-			rings[i] = ptarray_force_dims(poly->rings[i], hasz, hasm);
+			rings[i] = ptarray_force_dims(poly->rings[i], hasz, hasm, zval, mval);
 		polyout = lwpoly_construct(poly->srid, NULL, poly->nrings, rings);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 1a12fca..3e95cec 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1032,7 +1032,7 @@ ptarray_isccw(const POINTARRAY *pa)
 POINTARRAY*
-ptarray_force_dims(const POINTARRAY *pa, int hasz, int hasm)
+ptarray_force_dims(const POINTARRAY *pa, int hasz, int hasm, double zval, double mval)
 	/* TODO handle zero-length point arrays */
 	uint32_t i;
@@ -1045,9 +1045,9 @@ ptarray_force_dims(const POINTARRAY *pa, int hasz, int hasm)
 		getPoint4d_p(pa, i, &pt);
 		if( hasz && ! in_hasz )
-			pt.z = 0.0;
+			pt.z = zval;
 		if( hasm && ! in_hasm )
-			pt.m = 0.0;
+			pt.m = mval;
 		ptarray_append_point(pa_out, &pt, LW_TRUE);
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 5fa2f39..c365162 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -395,13 +395,14 @@ Datum LWGEOM_force_3dz(PG_FUNCTION_ARGS)
 	GSERIALIZED *pg_geom_in = PG_GETARG_GSERIALIZED_P(0);
 	GSERIALIZED *pg_geom_out;
 	LWGEOM *lwg_in, *lwg_out;
+	double z = PG_NARGS() < 2 ? 0 : PG_GETARG_FLOAT8(1);
 	/* already 3d */
 	if (gserialized_ndims(pg_geom_in) == 3 && gserialized_has_z(pg_geom_in))
 		PG_RETURN_POINTER(pg_geom_in);
 	lwg_in = lwgeom_from_gserialized(pg_geom_in);
-	lwg_out = lwgeom_force_3dz(lwg_in);
+	lwg_out = lwgeom_force_3dz(lwg_in, z);
 	pg_geom_out = geometry_serialize(lwg_out);
 	lwgeom_free(lwg_out);
 	lwgeom_free(lwg_in);
@@ -417,13 +418,14 @@ Datum LWGEOM_force_3dm(PG_FUNCTION_ARGS)
+	double m = PG_NARGS() < 2 ? 0 : PG_GETARG_FLOAT8(1);
 	/* already 3d */
 	if (gserialized_ndims(pg_geom_in) == 3 && gserialized_has_m(pg_geom_in))
-	lwg_out = lwgeom_force_3dm(lwg_in);
+	lwg_out = lwgeom_force_3dm(lwg_in, m);
@@ -439,13 +441,15 @@ Datum LWGEOM_force_4d(PG_FUNCTION_ARGS)
+	double z = PG_NARGS() < 3 ? 0 : PG_GETARG_FLOAT8(1);
+	double m = PG_NARGS() < 3 ? 0 : PG_GETARG_FLOAT8(2);
 	/* already 4d */
 	if (gserialized_ndims(pg_geom_in) == 4)
-	lwg_out = lwgeom_force_4d(lwg_in);
+	lwg_out = lwgeom_force_4d(lwg_in, z, m);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index ded515c..15311ed 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1312,28 +1312,32 @@ CREATE OR REPLACE FUNCTION ST_Force2D(geometry)
 	_COST_LOW;
 -- Availability: 2.1.0
-CREATE OR REPLACE FUNCTION ST_Force3DZ(geometry)
+-- Changed: 3.1.0 - add zvalue=0.0 parameter
+CREATE OR REPLACE FUNCTION ST_Force3DZ(geom geometry, zvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dz'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
-CREATE OR REPLACE FUNCTION ST_Force3D(geometry)
+CREATE OR REPLACE FUNCTION ST_Force3D(geom geometry, zvalue float8 default 0.0)
 	RETURNS geometry
-	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dz'
-	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	AS 'SELECT @extschema at .ST_Force3DZ($1, $2)'
+	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
-CREATE OR REPLACE FUNCTION ST_Force3DM(geometry)
+-- Changed: 3.1.0 - add mvalue=0.0 parameter
+CREATE OR REPLACE FUNCTION ST_Force3DM(geom geometry, mvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dm'
 	_COST_LOW;
-CREATE OR REPLACE FUNCTION ST_Force4D(geometry)
+-- Changed: 3.1.0 - add zvalue=0.0 and mvalue=0.0 parameters
+CREATE OR REPLACE FUNCTION ST_Force4D(geom geometry, zvalue float8 default 0.0, mvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_4d'
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 8780c90..0a5f266 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -194,6 +194,14 @@ SELECT _postgis_drop_function_if_needed
     'zoom integer, x integer, y integer, bounds geometry DEFAULT ''0102000020110F00000200000052107C45F81B73C152107C45F81B73C152107C45F81B734152107C45F81B7341''::geometry'
+-- FUNCTION ST_Force3D, ST_Force3DZ, ST_Force3DM, ST_Force4DZ changed to add defaults in 3.1
+-- These signatures were superseeded
+DROP FUNCTION IF EXISTS ST_Force3D(geometry); -- Does not conflict
+DROP FUNCTION IF EXISTS ST_Force3DZ(geometry); -- Does not conflict
+DROP FUNCTION IF EXISTS ST_Force3DM(geometry); -- Does not conflict
+DROP FUNCTION IF EXISTS ST_Force4D(geometry); -- Does not conflict
 -- FUNCTION st_askml changed to add defaults in 3.0 / r17357
 DROP FUNCTION IF EXISTS st_askml(geometry, integer); -- Does not conflict
diff --git a/regress/core/lwgeom_regress.sql b/regress/core/lwgeom_regress.sql
index 077a0e1..988b81e 100644
--- a/regress/core/lwgeom_regress.sql
+++ b/regress/core/lwgeom_regress.sql
@@ -98,6 +98,15 @@ SELECT ST_MemSize(ST_collect(ST_Force2d(ST_force4d(ST_force3dm(ST_force3dz(ST_fo
 DROP TABLE test_data;
+SELECT '#3057', ST_AsEWKT(ST_Force3D(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry)));
+SELECT '#3057', ST_AsEWKT(ST_Force3D(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry), 1));
+SELECT '#3057', ST_AsEWKT(ST_Force3DZ(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry)));
+SELECT '#3057', ST_AsEWKT(ST_Force3DZ(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry), 1));
+SELECT '#3057', ST_AsEWKT(ST_Force3DM(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry)));
+SELECT '#3057', ST_AsEWKT(ST_Force3DM(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry), 2));
+SELECT '#3057', ST_AsEWKT(ST_Force4D(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry)));
+SELECT '#3057', ST_AsEWKT(ST_Force4D(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry), 1, 2));
 SELECT '#3069', ST_Summary(PostGIS_Noop('SRID=4326;POINT(1 1)'::geometry));
 SELECT '#3069', ST_Summary(PostGIS_Noop('SRID=4326;LINESTRING(1 1,0 0)'::geometry));
 SELECT '#3069', replace(ST_Summary(PostGIS_Noop('SRID=4326;MULTIPOINT(1 1)'::geometry)),E'\n',' ');
diff --git a/regress/core/lwgeom_regress_expected b/regress/core/lwgeom_regress_expected
index 696bbb0..dd88331 100644
--- a/regress/core/lwgeom_regress_expected
+++ b/regress/core/lwgeom_regress_expected
@@ -5,6 +5,14 @@ BOX3D(0 0.1 -55,11 12 12)
 20464
 15824
 11184
+#3057|SRID=4326;POINT(1 1 0)
+#3057|SRID=4326;POINT(1 1 1)
+#3057|SRID=4326;POINTM(1 1 0)
+#3057|SRID=4326;POINTM(1 1 2)
+#3057|SRID=4326;POINT(1 1 0 0)
+#3057|SRID=4326;POINT(1 1 1 2)
 #3069|Point[S]
 #3069|LineString[S] with 2 points
 #3069|MultiPoint[S] with 1 element:   Point[S]
Summary of changes:
 NEWS                                 |   1 +
 doc/reference_editor.xml             |  21 +++++--
 liblwgeom/cunit/Makefile.in          |   1 +
 liblwgeom/cunit/cu_force_dims.c      | 118 +++++++++++++++++++++++++++++++++++
 liblwgeom/cunit/cu_misc.c            |  24 -------
 liblwgeom/cunit/cu_tester.c          |   2 +
 liblwgeom/liblwgeom.h.in             |   6 +-
 liblwgeom/liblwgeom_internal.h       |  12 ++--
 liblwgeom/lwcollection.c             |   4 +-
 liblwgeom/lwgeom.c                   |  24 +++----
 liblwgeom/lwgeom_topo.c              |   2 +-
 liblwgeom/lwline.c                   |   4 +-
 liblwgeom/lwpoint.c                  |   4 +-
 liblwgeom/lwpoly.c                   |   4 +-
 liblwgeom/ptarray.c                  |   6 +-
 postgis/lwgeom_functions_basic.c     |  10 ++-
 postgis/postgis.sql.in               |  16 +++--
 postgis/postgis_before_upgrade.sql   |   8 +++
 regress/core/lwgeom_regress.sql      |   9 +++
 regress/core/lwgeom_regress_expected |   8 +++
 20 files changed, 212 insertions(+), 72 deletions(-)
 create mode 100644 liblwgeom/cunit/cu_force_dims.c
hooks/post-receive
