[postgis-tickets] [PostGIS] #4619: ST_TileEnvelope test failure in 32 bit
PostGIS trac at osgeo.org
Wed Jan 15 02:47:12 PST 2020
  Reporter:  Algunenano  |      Owner:  Algunenano
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 3.0.1
 Component:  postgis     |    Version:  3.0.x
Resolution:  fixed       |   Keywords:
Changes (by Raúl Marín <git@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"3c069bf7d1d11625d810da07a635a8010718d99d/git"
 3c069bf7/git]:
 #!CommitTicketReference repository="git"
 revision="3c069bf7d1d11625d810da07a635a8010718d99d"
 Reduce output precision in ST_TileEnvelope test
 The output is slightly different in 32bit plaftorms
 Closes #4619
 Closes https://github.com/postgis/postgis/pull/534
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4619#comment:3>
