[postgis-tickets] [SCM] PostGIS branch master updated. b3fa5083d3d4d0457379775f6d40461926e012ad
Fri Jan 17 15:39:40 PST 2020
the project "PostGIS".
       via  b3fa5083d3d4d0457379775f6d40461926e012ad (commit)
      from  2073ffe7a98a502e564a0fdd0704cefe6a159989 (commit)
revisions in full, below.
commit b3fa5083d3d4d0457379775f6d40461926e012ad
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jan 17 18:39:30 2020 -0500
    add a what is new for 3.1 and minor fixes to spacing and example for grids
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index bce1aae..578edef 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -893,7 +893,7 @@ WHERE ST_Intersects(admin1.geom, hexes.geom)
 		</refsection>
 		<refsection>
 			<title>See Also</title>
-			<para><xref linkend="ST_TileEnvelope" /><xref linkend="ST_SquareGrid" /></para>
+			<para><xref linkend="ST_TileEnvelope" />, <xref linkend="ST_SquareGrid" /></para>
 		</refsection>
 	</refentry>
@@ -941,14 +941,14 @@ WHERE ST_Intersects(admin1.geom, hexes.geom)
  SELECT Count(*), squares.geom
  FROM pointtable pts
- JOIN ST_HexagonGrid(1000, bounds.geom) squares
+ JOIN ST_SquareGrid(1000, bounds.geom) squares
  GROUP BY squares.geom
 </programlisting>
 		</refsection>
 		<refsection>
-			<para><xref linkend="ST_TileEnvelope" /><xref linkend="ST_HexagonGrid" /></para>
+			<para><xref linkend="ST_TileEnvelope" />, <xref linkend="ST_HexagonGrid" /></para>
 		</refsection>
 	</refentry>
diff --git a/doc/xsl/postgis_aggs_mm.xml.xsl b/doc/xsl/postgis_aggs_mm.xml.xsl
index 5faff83..150dbc9 100644
--- a/doc/xsl/postgis_aggs_mm.xml.xsl
+++ b/doc/xsl/postgis_aggs_mm.xml.xsl
@@ -483,6 +483,107 @@
 	   <sect1 id="NewFunctions">
 			<title>New, Enhanced or changed PostGIS Functions</title>
+			<sect2 id="NewFunctions_3_1">
+				<title>PostGIS Functions new or enhanced in 3.1</title>
+				<para>The functions given below are PostGIS functions that were added or enhanced.</para>
+                <xsl:if test="//para[contains(text(),'Availability: 3.1')]">
+				<para>Functions new in PostGIS 3.1</para>
+				<itemizedlist>
+				<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
+					<xsl:for-each select='//refentry'>
+						<xsl:sort select="refnamediv/refname"/>
+						<xsl:variable name='comment'>
+							<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
+						</xsl:variable>
+						<xsl:variable name="refid">
+							<xsl:value-of select="@id" />
+						</xsl:variable>
+						<xsl:variable name="refname">
+							<xsl:value-of select="refnamediv/refname" />
+						</xsl:variable>
+				<!-- For each section if there is note about availability in this version -->
+							<xsl:for-each select="refsection">
+								<xsl:for-each select="para | */para">
+									<xsl:choose>
+										<xsl:when test="contains(.,'Availability: 3.1')">
+											<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /><xsl:text> </xsl:text> <xsl:value-of select="$comment" /></simpara></listitem>
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+                </xsl:if>
+				<xsl:if test="//para[contains(text(),'Enhanced: 3.1')]">
+				<para>Functions enhanced in PostGIS 3.1</para>
+				<itemizedlist>
+						</xsl:variable>
+						</xsl:variable>
+						</xsl:variable>
+									<xsl:choose>
+										<xsl:when test="contains(.,'Enhanced: 3.1')">
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+			</xsl:if>
+			<para>Functions changed in PostGIS 3.1</para>
+				<xsl:if test="//para[contains(text(),'Changed: 3.1')]">
+				<itemizedlist>
+						</xsl:variable>
+						</xsl:variable>
+						</xsl:variable>
+									<xsl:choose>
+										<xsl:when test="contains(.,'Changed: 3.1')">
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+				</xsl:if>
+			</sect2>
 			<sect2 id="NewFunctions_3_0">
 				<title>PostGIS Functions new or enhanced in 3.0</title>
Summary of changes:
 doc/reference_constructor.xml   |   6 +--
 doc/xsl/postgis_aggs_mm.xml.xsl | 101 ++++++++++++++++++++++++++++++++++++++++
 2 files changed, 104 insertions(+), 3 deletions(-)
hooks/post-receive
