[postgis-tickets] [SCM] PostGIS branch master updated. 07fa25e445e99075682fcf0191fb1b62d59e9446
Mon Jan 20 02:33:44 PST 2020
the project "PostGIS".
       via  07fa25e445e99075682fcf0191fb1b62d59e9446 (commit)
       via  f89db5ac34462073be8cfb835a2ea9256ea42cf6 (commit)
      from  b3fa5083d3d4d0457379775f6d40461926e012ad (commit)
revisions in full, below.
commit 07fa25e445e99075682fcf0191fb1b62d59e9446
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Jan 17 17:22:42 2020 +0100
    Prevent stack overflow when parsing WKB
    References #4621
    Closes https://github.com/postgis/postgis/pull/536
diff --git a/NEWS b/NEWS
index 28e2b7c..d862af0 100644
--- a/NEWS
+++ b/NEWS
@@ -43,6 +43,7 @@ PostGIS 3.1.0
   - #4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
   - #4600, Improve precision of ST_TileEnvelope (Raúl Marín)
   - #4608, PG12: Fix several bugs in the index support function (Raúl Marín)
+  - #4621, Prevent stack overflow when parsing WKB (Raúl Marín)
 PostGIS 3.0.0
diff --git a/liblwgeom/cunit/cu_in_wkb.c b/liblwgeom/cunit/cu_in_wkb.c
index 72fd0e8..4bd9bd5 100644
--- a/liblwgeom/cunit/cu_in_wkb.c
+++ b/liblwgeom/cunit/cu_in_wkb.c
@@ -267,6 +267,14 @@ test_wkb_fuzz(void)
 			    0x00, 0x00, 0x11, 0x20, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0x00};
 	g = lwgeom_from_wkb(wkb4, 22, LW_PARSER_CHECK_NONE);
 	lwgeom_free(g);
+	/* OSS-FUZZ: https://trac.osgeo.org/postgis/ticket/4621 */
+	uint32_t big_size = 20000000;
+	uint8_t *wkb5 = lwalloc(big_size);
+	memset(wkb5, 0x01, big_size);
+	g = lwgeom_from_wkb(wkb5, big_size, LW_PARSER_CHECK_NONE);
+	lwgeom_free(g);
+	lwfree(wkb5);
diff --git a/liblwgeom/lwin_wkb.c b/liblwgeom/lwin_wkb.c
index 423601f..02b6eec 100644
--- a/liblwgeom/lwin_wkb.c
+++ b/liblwgeom/lwin_wkb.c
@@ -30,6 +30,9 @@
 #include <math.h>
 #include <limits.h>
+/** Max depth in a geometry. Matches the default YYINITDEPTH for WKT */
+#define LW_PARSER_MAX_DEPTH 200
 * Used for passing the parse state between the parsing functions.
@@ -45,6 +48,7 @@ typedef struct
 	int8_t has_m;       /* M? */
 	int8_t has_srid;    /* SRID? */
 	int8_t error;       /* An error was found (not enough bytes to read) */
+	uint8_t depth;      /* Current recursion level (to prevent stack overflows). Maxes at LW_PARSER_MAX_DEPTH */
 	const uint8_t *pos; /* Current parse position */
 } wkb_parse_state;
@@ -685,6 +689,13 @@ static LWCOLLECTION* lwcollection_from_wkb_state(wkb_parse_state *s)
 	if ( s->lwtype == POLYHEDRALSURFACETYPE )
 		s->check |= LW_PARSER_CHECK_ZCLOSURE;
+	s->depth++;
+	if (s->depth >= LW_PARSER_MAX_DEPTH)
+		lwcollection_free(col);
+		lwerror("Geometry has too many chained collections");
+		return NULL;
 	for ( i = 0; i < ngeoms; i++ )
 		geom = lwgeom_from_wkb_state(s);
@@ -696,6 +707,7 @@ static LWCOLLECTION* lwcollection_from_wkb_state(wkb_parse_state *s)
 			return NULL;
+	s->depth--;
 	return col;
@@ -823,6 +835,7 @@ LWGEOM* lwgeom_from_wkb(const uint8_t *wkb, const size_t wkb_size, const char ch
 	s.has_srid = LW_FALSE;
 	s.error = LW_FALSE;
 	s.pos = wkb;
+	s.depth = 1;
 	if (!wkb || !wkb_size)
 		return NULL;
commit f89db5ac34462073be8cfb835a2ea9256ea42cf6
Date:   Mon Jan 20 11:32:23 2020 +0100
    NEWS typo
index 3af0b21..28e2b7c 100644
--- a/NEWS
+++ b/NEWS
@@ -16,7 +16,7 @@ PostGIS 3.1.0
   - #2972, Add quiet mode (-q) to pgsql2shp (Kristian Thy)
   - #4617, Add configure switch `--without-phony-revision` (Raúl Marín)
   - #3057, Optional value params for Force3D*, Force4D functions (Kristian Thy)
-  - ST_HexagonGrid and ST_SquareGrid, set returning funcitons to
+  - ST_HexagonGrid and ST_SquareGrid, set returning functions to
     generate tilings of the plane (Paul Ramsey)
 * Enhancements *
Summary of changes:
 NEWS                        |  3 ++-
 liblwgeom/cunit/cu_in_wkb.c |  8 ++++++++
 liblwgeom/lwin_wkb.c        | 13 +++++++++++++
 3 files changed, 23 insertions(+), 1 deletion(-)
hooks/post-receive
