[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 54814344ab353f07e47f9d34f5498ca860ba9ab6
Mon Jan 20 02:35:38 PST 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  54814344ab353f07e47f9d34f5498ca860ba9ab6 (commit)
      from  b73f67376145d96c9f5bb2c31bc407dd6e311746 (commit)
revisions in full, below.
commit 54814344ab353f07e47f9d34f5498ca860ba9ab6
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Jan 17 17:22:42 2020 +0100
    Prevent stack overflow when parsing WKB
    References #4621
diff --git a/NEWS b/NEWS
index 2bab8e8..cdf854e 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,7 @@ XXXX/XX/XX
   - #4596, The script to generate nation_script_load.sh is missing
            a trailing quote (Bill Mill)
   - #4608, PG12: Fix several bugs in the index support function (Raúl Marín)
+  - #4621, Prevent stack overflow when parsing WKB (Raúl Marín)
 PostGIS 3.0.0
 2019/10/20
diff --git a/liblwgeom/cunit/cu_in_wkb.c b/liblwgeom/cunit/cu_in_wkb.c
index d928c6f..825a6f5 100644
--- a/liblwgeom/cunit/cu_in_wkb.c
+++ b/liblwgeom/cunit/cu_in_wkb.c
@@ -261,6 +261,14 @@ test_wkb_fuzz(void)
 	uint8_t wkb3[9] = {0x01, 0x03, 0x00, 0x00, 0x10, 0x8d, 0x55, 0xf3, 0xff};
 	g = lwgeom_from_wkb(wkb3, 9, LW_PARSER_CHECK_NONE);
 	lwgeom_free(g);
+	/* OSS-FUZZ: https://trac.osgeo.org/postgis/ticket/4621 */
+	uint32_t big_size = 20000000;
+	uint8_t *wkb5 = lwalloc(big_size);
+	memset(wkb5, 0x01, big_size);
+	g = lwgeom_from_wkb(wkb5, big_size, LW_PARSER_CHECK_NONE);
+	lwgeom_free(g);
+	lwfree(wkb5);
diff --git a/liblwgeom/lwin_wkb.c b/liblwgeom/lwin_wkb.c
index 074b424..1013ab8 100644
--- a/liblwgeom/lwin_wkb.c
+++ b/liblwgeom/lwin_wkb.c
@@ -30,6 +30,9 @@
 #include <math.h>
 #include <limits.h>
+/** Max depth in a geometry. Matches the default YYINITDEPTH for WKT */
+#define LW_PARSER_MAX_DEPTH 200
 * Used for passing the parse state between the parsing functions.
@@ -45,6 +48,7 @@ typedef struct
 	int8_t has_m;       /* M? */
 	int8_t has_srid;    /* SRID? */
 	int8_t error;       /* An error was found (not enough bytes to read) */
+	uint8_t depth;      /* Current recursion level (to prevent stack overflows). Maxes at LW_PARSER_MAX_DEPTH */
 	const uint8_t *pos; /* Current parse position */
 } wkb_parse_state;
@@ -688,6 +692,13 @@ static LWCOLLECTION* lwcollection_from_wkb_state(wkb_parse_state *s)
 	if ( s->lwtype == POLYHEDRALSURFACETYPE )
 		s->check |= LW_PARSER_CHECK_ZCLOSURE;
+	s->depth++;
+	if (s->depth >= LW_PARSER_MAX_DEPTH)
+		lwcollection_free(col);
+		lwerror("Geometry has too many chained collections");
+		return NULL;
 	for ( i = 0; i < ngeoms; i++ )
 		geom = lwgeom_from_wkb_state(s);
@@ -699,6 +710,7 @@ static LWCOLLECTION* lwcollection_from_wkb_state(wkb_parse_state *s)
 			return NULL;
+	s->depth--;
 	return col;
@@ -826,6 +838,7 @@ LWGEOM* lwgeom_from_wkb(const uint8_t *wkb, const size_t wkb_size, const char ch
 	s.has_srid = LW_FALSE;
 	s.error = LW_FALSE;
 	s.pos = wkb;
+	s.depth = 1;
 	if (!wkb || !wkb_size)
 		return NULL;
Summary of changes:
 NEWS                        |  1 +
 liblwgeom/cunit/cu_in_wkb.c |  8 ++++++++
 liblwgeom/lwin_wkb.c        | 13 +++++++++++++
 3 files changed, 22 insertions(+)
hooks/post-receive
