[postgis-tickets] [PostGIS] #4626: Fails to build with libxml2 2.9.10 (uses xml2-config)
PostGIS trac at osgeo.org
Mon Jan 20 21:05:57 PST 2020
 Reporter:  Bas Couwenberg  |      Owner:  pramsey
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 2.5.4
Component:  postgis         |    Version:  2.5.x
 Keywords:                  |
 As reported by Mattia Rizzolo in [https://bugs.debian.org/949426 Debian
 Bug #949426]:
 > your package is using `xml2-config` to detect and use libxml2.  I'm
 > removing that script, so please update your build system to use
 > pkg-config instead.
 > The libxml2 package in experimental already doesn't ship the xml2-config
 > script.
 > Attached is the full build log, hopefully relevant excerpt follows:
 > checking for xml2-config... no
 > configure: error: could not find xml2-config from libxml2 within the
 current path. You may need to try re-running configure with a --with-
 xml2config parameter.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4626>
