[postgis-tickets] [PostGIS] #4626: Fails to build with libxml2 2.9.10 (uses xml2-config)
PostGIS trac at osgeo.org
Tue Jan 21 06:35:02 PST 2020
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.5.4
 Component:  postgis         |    Version:  2.5.x
Resolution:                  |   Keywords:
Comment (by Algunenano):
 `libxml-2.0.pc` was apparently introduced in 2000, so it shouldn't be an
 issue to default to using it if `xml2-config` is not passed.
 This will also require changing how the libxml2 version is read to use
 `LIBXML_DOTTED_VERSION` instead. As far as I can see, that MACRO has
 existed at least since 2001.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4626#comment:1>
