[postgis-tickets] [PostGIS] #4626: Fails to build with libxml2 2.9.10 (uses xml2-config)
PostGIS trac at osgeo.org
Tue Jan 21 06:43:48 PST 2020
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.5.4
 Component:  postgis         |    Version:  2.5.x
Resolution:                  |   Keywords:
Comment (by Algunenano):
 The main repo is still building and distributing `xml2-config.in`, in fact
 I have libxml2 2.9.10 currently installed and it builds Postgis without
 issues.
 Bas, does this change come from upstream or from a change in Debian
 packaging? If it's the latter, then this isn't a bug but a feature request
 to support pkg-config for libxml2 (which is a good idea IMO).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4626#comment:2>
