[postgis-tickets] [PostGIS] #4603: Windows build failing in shp2pgsql: XError in psSHP->sHooks.FWrite()
PostGIS trac at osgeo.org
Sun Jan 26 03:13:44 PST 2020
  Reporter:  Algunenano     |      Owner:  pramsey
      Type:  defect         |     Status:  new
  Priority:  high           |  Milestone:  PostGIS 3.1.0
 Component:  loader/dumper  |    Version:  master
Resolution:                 |   Keywords:
Comment (by robe):
 Okay as the error says "No Error".  It is failing
 Dumping: XError in psSHP->sHooks.FWrite() while writing object of 28 bytes
 to .shp file: No error
 Error writing shape 0
 The issue is in the shpopen.c file.  If I swap with the older it works
 fine.
 Also seems to work fine if I change this line
 if ( psSHP->sHooks.FWrite( pabyRec, nRecordSize, 1, psSHP->fpSHP ) ) < 1
 to
 if ( psSHP->sHooks.FWrite( pabyRec, nRecordSize, 1, psSHP->fpSHP ) ) < 0
 it's returning 0 so is being sent into that error loop
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4603#comment:4>
