[postgis-tickets] [PostGIS] #4603: Windows build failing in shp2pgsql: XError in psSHP->sHooks.FWrite()
PostGIS trac at osgeo.org
Tue Jan 28 05:35:45 PST 2020
  Reporter:  Algunenano     |      Owner:  pramsey
      Type:  defect         |     Status:  new
  Priority:  high           |  Milestone:  PostGIS 3.1.0
 Component:  loader/dumper  |    Version:  master
Resolution:                 |   Keywords:
Comment (by robe):
 actually I may be mistaken.  about it working with that since the
 regression tests still seem to be failing - though it is outputing to .shp
 file now. I'm going to compare between old and new outptu to see wha tis
 failing.  I suspect its a maybe the bytes allocated for writing isn't
 enough.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4603#comment:5>
