[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-106-g9e5df19
Fri May 8 08:49:01 PDT 2020
the project "PostGIS".
       via  9e5df19ed0a3fca351fa6c72ea8ca702fb64da2e (commit)
      from  575ae8580b36b093c90fb6fdde7c00c16cf2e755 (commit)
revisions in full, below.
commit 9e5df19ed0a3fca351fa6c72ea8ca702fb64da2e
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri May 8 16:18:06 2020 +0200
    Update wagyu to 0.5.0
    Closes https://github.com/postgis/postgis/pull/563
    Closes #4620
diff --git a/LICENSE.TXT b/LICENSE.TXT
index 8578dd5..b70a7af 100644
--- a/LICENSE.TXT
+++ b/LICENSE.TXT
@@ -3,7 +3,7 @@ PostGIS Licensing
 This file attempts to include all licenses that apply within the PostGIS
 source tree, in particular any that are supposed to be exposed to the end
-user for credit requirements for instance.
+user for credit requirements for instance.
 PostGIS General
@@ -44,7 +44,8 @@ license. Copyright (c) 2005-2018, Troy D. Hanson.
 -- deps/wagyu (see LICENSE.README in folder) includes code released under the
 ISC license (copyrighted by Mapbox) and the Boost Software License (copyrighted
-by Angus Johnson and Mapbox).
+by Angus Johnson and Mapbox). Copyright for "almost_equal.hpp" file is held by
+Google Inc and its license is listed at the top of that file.
 The documentation for PostGIS is under a creative commons share-alike
 3.0 license.  http://creativecommons.org/licenses/by-sa/3.0/
@@ -58,4 +59,4 @@ Data used in documentation falls in one of the following categories
   utilizes ImageMagick) as described
   http://trac.osgeo.org/postgis/wiki/DevWikiDocNewFeature
 - PostGIS raster output functions such as the ST_AsPNG etc.
-- raster/vector data from MassGIS: http://www.mass.gov/mgis/laylist.htm
+- raster/vector data from MassGIS: http://www.mass.gov/mgis/laylist.htm
diff --git a/NEWS b/NEWS
index 1a84412..7203935 100644
--- a/NEWS
+++ b/NEWS
@@ -19,6 +19,7 @@ Only tickets not included in 3.1.0alpha1
   - #4672, Cache getSRSbySRID and getSRIDbySRS (Raúl Marín)
   - #4676, Avoid decompressing toasted geometries to read only the header (Raúl Marín)
            Optimize cast to Postgresql point type (Raúl Marín)
+  - #4620, Update internal wagyu to 0.5.0 (Raúl Marín)
 * Bug fixes *
   - #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
diff --git a/deps/wagyu/README.md b/deps/wagyu/README.md
index 94a0eda..d5e0461 100644
--- a/deps/wagyu/README.md
+++ b/deps/wagyu/README.md
@@ -25,3 +25,4 @@ It is integrated in the project as an static library inside postgis.so, so it do
   - 2019-02-05 - [Wagyu] Library extraction from https://github.com/mapbox/wagyu
   - 2019-02-05 - [geometry.hpp] Library extraction from https://github.com/mapbox/geometry.hpp
+  - 2020-05-08 - [Wagyu] Update to 0.5.0
diff --git a/deps/wagyu/include/mapbox/geometry/wagyu/active_bound_list.hpp b/deps/wagyu/include/mapbox/geometry/wagyu/active_bound_list.hpp
index dc113ee..d3a6ec2 100644
--- a/deps/wagyu/include/mapbox/geometry/wagyu/active_bound_list.hpp
+++ b/deps/wagyu/include/mapbox/geometry/wagyu/active_bound_list.hpp
@@ -90,11 +90,11 @@ struct bound_insert_location {
         auto const& bound1 = *b;
         if (values_are_equal(bound2.current_x, bound1.current_x)) {
             if (bound2.current_edge->top.y > bound1.current_edge->top.y) {
-                return static_cast<double>(bound2.current_edge->top.x) <
-                       get_current_x(*(bound1.current_edge), bound2.current_edge->top.y);
+                return less_than(static_cast<double>(bound2.current_edge->top.x),
+                                 get_current_x(*(bound1.current_edge), bound2.current_edge->top.y));
             } else {
-                return static_cast<double>(bound1.current_edge->top.x) >
-                       get_current_x(*(bound2.current_edge), bound1.current_edge->top.y);
+                return greater_than(static_cast<double>(bound1.current_edge->top.x),
+                                    get_current_x(*(bound2.current_edge), bound1.current_edge->top.y));
         } else {
             return bound2.current_x < bound1.current_x;
diff --git a/deps/wagyu/include/mapbox/geometry/wagyu/almost_equal.hpp b/deps/wagyu/include/mapbox/geometry/wagyu/almost_equal.hpp
new file mode 100644
index 0000000..71ef122
--- /dev/null
+++ b/deps/wagyu/include/mapbox/geometry/wagyu/almost_equal.hpp
@@ -0,0 +1,277 @@
+// Copyright 2005, Google Inc.
+// All rights reserved.
+// Redistribution and use in source and binary forms, with or without
+// modification, are permitted provided that the following conditions are
+// met:
+//     * Redistributions of source code must retain the above copyright
+// notice, this list of conditions and the following disclaimer.
+//     * Redistributions in binary form must reproduce the above
+// copyright notice, this list of conditions and the following disclaimer
+// in the documentation and/or other materials provided with the
+// distribution.
+//     * Neither the name of Google Inc. nor the names of its
+// contributors may be used to endorse or promote products derived from
+// this software without specific prior written permission.
+// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+// Authors: wan at google.com (Zhanyong Wan), eefacm at gmail.com (Sean Mcafee)
+// The Google C++ Testing Framework (Google Test)
+// This template class serves as a compile-time function from size to
+// type.  It maps a size in bytes to a primitive type with that
+// size. e.g.
+//   TypeWithSize<4>::UInt
+// is typedef-ed to be unsigned int (unsigned integer made up of 4
+// bytes).
+// Such functionality should belong to STL, but I cannot find it
+// there.
+// Google Test uses this class in the implementation of floating-point
+// comparison.
+// For now it only handles UInt (unsigned int) as that's all Google Test
+// needs.  Other types can be easily added in the future if need
+// arises.
+namespace mapbox {
+namespace geometry {
+namespace wagyu {
+namespace util {
+template <size_t size>
+class TypeWithSize {
+public:
+    // This prevents the user from using TypeWithSize<N> with incorrect
+    // values of N.
+    typedef void UInt;
+// The specialization for size 4.
+template <>
+class TypeWithSize<4> {
+public:
+    // unsigned int has size 4 in both gcc and MSVC.
+    // As base/basictypes.h doesn't compile on Windows, we cannot use
+    // uint32, uint64, and etc here.
+    typedef int Int;
+    typedef unsigned int UInt;
+// The specialization for size 8.
+template <>
+class TypeWithSize<8> {
+public:
+#if GTEST_OS_WINDOWS
+    typedef __int64 Int;
+    typedef unsigned __int64 UInt;
+#else
+    typedef long long Int;           // NOLINT
+    typedef unsigned long long UInt; // NOLINT
+#endif // GTEST_OS_WINDOWS
+// This template class represents an IEEE floating-point number
+// (either single-precision or double-precision, depending on the
+// template parameters).
+// The purpose of this class is to do more sophisticated number
+// comparison.  (Due to round-off error, etc, it's very unlikely that
+// two floating-points will be equal exactly.  Hence a naive
+// comparison by the == operation often doesn't work.)
+// Format of IEEE floating-point:
+//   The most-significant bit being the leftmost, an IEEE
+//   floating-point looks like
+//     sign_bit exponent_bits fraction_bits
+//   Here, sign_bit is a single bit that designates the sign of the
+//   number.
+//   For float, there are 8 exponent bits and 23 fraction bits.
+//   For double, there are 11 exponent bits and 52 fraction bits.
+//   More details can be found at
+//   http://en.wikipedia.org/wiki/IEEE_floating-point_standard.
+// Template parameter:
+//   RawType: the raw floating-point type (either float or double)
+template <typename RawType>
+class FloatingPoint {
+public:
+    // Defines the unsigned integer type that has the same size as the
+    // floating point number.
+    typedef typename TypeWithSize<sizeof(RawType)>::UInt Bits;
+    // Constants.
+    // # of bits in a number.
+    static const size_t kBitCount = 8 * sizeof(RawType);
+    // # of fraction bits in a number.
+    static const size_t kFractionBitCount = std::numeric_limits<RawType>::digits - 1;
+    // # of exponent bits in a number.
+    static const size_t kExponentBitCount = kBitCount - 1 - kFractionBitCount;
+    // The mask for the sign bit.
+    static const Bits kSignBitMask = static_cast<Bits>(1) << (kBitCount - 1);
+    // The mask for the fraction bits.
+    static const Bits kFractionBitMask = ~static_cast<Bits>(0) >> (kExponentBitCount + 1);
+    // The mask for the exponent bits.
+    static const Bits kExponentBitMask = ~(kSignBitMask | kFractionBitMask);
+    // How many ULP's (Units in the Last Place) we want to tolerate when
+    // comparing two numbers.  The larger the value, the more error we
+    // allow.  A 0 value means that two numbers must be exactly the same
+    // to be considered equal.
+    // The maximum error of a single floating-point operation is 0.5
+    // units in the last place.  On Intel CPU's, all floating-point
+    // calculations are done with 80-bit precision, while double has 64
+    // bits.  Therefore, 4 should be enough for ordinary use.
+    // See the following article for more details on ULP:
+    // http://www.cygnus-software.com/papers/comparingfloats/comparingfloats.htm.
+    static const size_t kMaxUlps = 4;
+    // Constructs a FloatingPoint from a raw floating-point number.
+    // On an Intel CPU, passing a non-normalized NAN (Not a Number)
+    // around may change its bits, although the new value is guaranteed
+    // to be also a NAN.  Therefore, don't expect this constructor to
+    // preserve the bits in x when x is a NAN.
+    explicit FloatingPoint(const RawType& x) : u_(x) {
+    // Static methods
+    // Reinterprets a bit pattern as a floating-point number.
+    // This function is needed to test the AlmostEquals() method.
+    static RawType ReinterpretBits(const Bits bits) {
+        FloatingPoint fp(0);
+        fp.u_.bits_ = bits;
+        return fp.u_.value_;
+    // Returns the floating-point number that represent positive infinity.
+    static RawType Infinity() {
+        return ReinterpretBits(kExponentBitMask);
+    // Non-static methods
+    // Returns the bits that represents this number.
+    const Bits& bits() const {
+        return u_.bits_;
+    // Returns the exponent bits of this number.
+    Bits exponent_bits() const {
+        return kExponentBitMask & u_.bits_;
+    // Returns the fraction bits of this number.
+    Bits fraction_bits() const {
+        return kFractionBitMask & u_.bits_;
+    // Returns the sign bit of this number.
+    Bits sign_bit() const {
+        return kSignBitMask & u_.bits_;
+    // Returns true iff this is NAN (not a number).
+    bool is_nan() const {
+        // It's a NAN if the exponent bits are all ones and the fraction
+        // bits are not entirely zeros.
+        return (exponent_bits() == kExponentBitMask) && (fraction_bits() != 0);
+    // Returns true iff this number is at most kMaxUlps ULP's away from
+    // rhs.  In particular, this function:
+    //   - returns false if either number is (or both are) NAN.
+    //   - treats really large numbers as almost equal to infinity.
+    //   - thinks +0.0 and -0.0 are 0 DLP's apart.
+    bool AlmostEquals(const FloatingPoint& rhs) const {
+        // The IEEE standard says that any comparison operation involving
+        // a NAN must return false.
+        if (is_nan() || rhs.is_nan())
+            return false;
+        return DistanceBetweenSignAndMagnitudeNumbers(u_.bits_, rhs.u_.bits_) <= kMaxUlps;
+private:
+    // The data type used to store the actual floating-point number.
+    union FloatingPointUnion {
+        explicit FloatingPointUnion(RawType val) : value_(val) {
+        RawType value_; // The raw floating-point number.
+        Bits bits_;     // The bits that represent the number.
+    // Converts an integer from the sign-and-magnitude representation to
+    // the biased representation.  More precisely, let N be 2 to the
+    // power of (kBitCount - 1), an integer x is represented by the
+    // unsigned number x + N.
+    // For instance,
+    //   -N + 1 (the most negative number representable using
+    //          sign-and-magnitude) is represented by 1;
+    //   0      is represented by N; and
+    //   N - 1  (the biggest number representable using
+    //          sign-and-magnitude) is represented by 2N - 1.
+    // Read http://en.wikipedia.org/wiki/Signed_number_representations
+    // for more details on signed number representations.
+    static Bits SignAndMagnitudeToBiased(const Bits& sam) {
+        if (kSignBitMask & sam) {
+            // sam represents a negative number.
+            return ~sam + 1;
+        } else {
+            // sam represents a positive number.
+            return kSignBitMask | sam;
+    // Given two numbers in the sign-and-magnitude representation,
+    // returns the distance between them as an unsigned number.
+    static Bits DistanceBetweenSignAndMagnitudeNumbers(const Bits& sam1, const Bits& sam2) {
+        const Bits biased1 = SignAndMagnitudeToBiased(sam1);
+        const Bits biased2 = SignAndMagnitudeToBiased(sam2);
+        return (biased1 >= biased2) ? (biased1 - biased2) : (biased2 - biased1);
+    FloatingPointUnion u_;
+} // namespace util
+} // namespace wagyu
+} // namespace geometry
+} // namespace mapbox
diff --git a/deps/wagyu/include/mapbox/geometry/wagyu/interrupt.hpp b/deps/wagyu/include/mapbox/geometry/wagyu/interrupt.hpp
index 083cf36..d4d68ae 100644
--- a/deps/wagyu/include/mapbox/geometry/wagyu/interrupt.hpp
+++ b/deps/wagyu/include/mapbox/geometry/wagyu/interrupt.hpp
@@ -9,7 +9,7 @@
 #ifdef USE_WAGYU_INTERRUPT
 namespace {
-bool WAGYU_INTERRUPT_REQUESTED = false;
+thread_local bool WAGYU_INTERRUPT_REQUESTED = false;
 namespace mapbox {
diff --git a/deps/wagyu/include/mapbox/geometry/wagyu/process_horizontal.hpp b/deps/wagyu/include/mapbox/geometry/wagyu/process_horizontal.hpp
index 5dbbe54..ecd6691 100644
--- a/deps/wagyu/include/mapbox/geometry/wagyu/process_horizontal.hpp
+++ b/deps/wagyu/include/mapbox/geometry/wagyu/process_horizontal.hpp
@@ -54,7 +54,7 @@ active_bound_list_itr<T> process_horizontal_left_to_right(T scanline_y,
             ++hp_itr;
-        if ((*bnd)->current_x > static_cast<double>((*horz_bound)->current_edge->top.x)) {
+        if (greater_than((*bnd)->current_x, static_cast<double>((*horz_bound)->current_edge->top.x))) {
             break;
@@ -75,7 +75,7 @@ active_bound_list_itr<T> process_horizontal_left_to_right(T scanline_y,
         // OK, so far we're still in range of the horizontal Edge  but make sure
         // we're at the last of consec. horizontals when matching with eMaxPair
         if (is_maxima_edge && bnd == bound_max_pair) {
-            if ((*horz_bound)->ring) {
+            if ((*horz_bound)->ring && (*bound_max_pair)->ring) {
                 add_local_maximum_point(*(*horz_bound), *(*bound_max_pair), (*horz_bound)->current_edge->top, rings,
                                         active_bounds);
@@ -159,7 +159,7 @@ active_bound_list_itr<T> process_horizontal_right_to_left(T scanline_y,
             ++hp_itr;
-        if ((*bnd)->current_x < static_cast<double>((*horz_bound)->current_edge->top.x)) {
+        if (less_than((*bnd)->current_x, static_cast<double>((*horz_bound)->current_edge->top.x))) {
             break;
@@ -180,7 +180,7 @@ active_bound_list_itr<T> process_horizontal_right_to_left(T scanline_y,
                                         active_bounds);
diff --git a/deps/wagyu/include/mapbox/geometry/wagyu/ring_util.hpp b/deps/wagyu/include/mapbox/geometry/wagyu/ring_util.hpp
index 8aa3950..64d3a13 100644
--- a/deps/wagyu/include/mapbox/geometry/wagyu/ring_util.hpp
+++ b/deps/wagyu/include/mapbox/geometry/wagyu/ring_util.hpp
@@ -74,18 +74,17 @@ struct hot_pixel_sorter {
-// Due to the nature of floating point calculations
-// and the high likely hood of values around X.5, we
-// need to fudge what is X.5 some for our rounding.
-const double rounding_offset = 1e-12;
-const double rounding_offset_y = 5e-13;
 template <typename T>
 T round_towards_min(double val) {
     // 0.5 rounds to 0
     // 0.0 rounds to 0
     // -0.5 rounds to -1
-    return static_cast<T>(std::ceil(val - 0.5 + rounding_offset));
+    double half = std::floor(val) + 0.5;
+    if (values_are_equal(val, half)) {
+        return static_cast<T>(std::floor(val));
+    } else {
+        return static_cast<T>(std::llround(val));
@@ -93,7 +92,12 @@ T round_towards_max(double val) {
     // 0.5 rounds to 1
     // 0.0 rounds to 0
     // -0.5 rounds to 0
-    return static_cast<T>(std::floor(val + 0.5 + rounding_offset));
+        return static_cast<T>(std::ceil(val));
+    } else {
@@ -117,8 +121,8 @@ inline T get_edge_min_x(edge<T> const& edge, const T current_y) {
         if (current_y == edge.bot.y) {
             return edge.bot.x;
         } else {
-            double return_val = static_cast<double>(edge.bot.x) +
-                                edge.dx * (static_cast<double>(current_y - edge.bot.y) + 0.5 - rounding_offset_y);
+            double return_val =
+                static_cast<double>(edge.bot.x) + edge.dx * (static_cast<double>(current_y - edge.bot.y) + 0.5);
             T value = round_towards_min<T>(return_val);
             return value;
@@ -146,8 +150,8 @@ inline T get_edge_max_x(edge<T> const& edge, const T current_y) {
             return edge.bot.x;
         } else {
             T value = round_towards_max<T>(return_val);
             return value;
diff --git a/deps/wagyu/include/mapbox/geometry/wagyu/util.hpp b/deps/wagyu/include/mapbox/geometry/wagyu/util.hpp
index f8acdb4..974afc4 100644
--- a/deps/wagyu/include/mapbox/geometry/wagyu/util.hpp
+++ b/deps/wagyu/include/mapbox/geometry/wagyu/util.hpp
@@ -4,6 +4,7 @@
 #include <mapbox/geometry/point.hpp>
 #include <mapbox/geometry/polygon.hpp>
+#include <mapbox/geometry/wagyu/almost_equal.hpp>
 #include <mapbox/geometry/wagyu/point.hpp>
 namespace mapbox {
@@ -30,18 +31,26 @@ double area(mapbox::geometry::linear_ring<T> const& poly) {
     return -a * 0.5;
-inline bool value_is_zero(double val) {
-    return std::fabs(val) < (5.0 * std::numeric_limits<double>::epsilon());
+inline bool values_are_equal(double x, double y) {
+    return util::FloatingPoint<double>(x).AlmostEquals(util::FloatingPoint<double>(y));
-inline bool values_are_equal(double x, double y) {
-    return value_is_zero(x - y);
+inline bool value_is_zero(double val) {
+    return values_are_equal(val, static_cast<double>(0.0));
 inline bool greater_than_or_equal(double x, double y) {
     return x > y || values_are_equal(x, y);
+inline bool greater_than(double x, double y) {
+    return (!values_are_equal(x, y) && x > y);
+inline bool less_than(double x, double y) {
+    return (!values_are_equal(x, y) && x < y);
 bool slopes_equal(mapbox::geometry::point<T> const& pt1,
                   mapbox::geometry::point<T> const& pt2,
diff --git a/deps/wagyu/include/mapbox/geometry/wagyu/wagyu.hpp b/deps/wagyu/include/mapbox/geometry/wagyu/wagyu.hpp
index 4401418..157e36e 100644
--- a/deps/wagyu/include/mapbox/geometry/wagyu/wagyu.hpp
+++ b/deps/wagyu/include/mapbox/geometry/wagyu/wagyu.hpp
@@ -17,8 +17,8 @@
 #include <mapbox/geometry/wagyu/vatti.hpp>
 #define WAGYU_MAJOR_VERSION 0
-#define WAGYU_MINOR_VERSION 4
-#define WAGYU_PATCH_VERSION 3
+#define WAGYU_MINOR_VERSION 5
+#define WAGYU_PATCH_VERSION 0
 #define WAGYU_VERSION (WAGYU_MAJOR_VERSION * 100000) + (WAGYU_MINOR_VERSION * 100) + (WAGYU_PATCH_VERSION)
diff --git a/regress/core/mvt.sql b/regress/core/mvt.sql
index 0476e44..d0513ca 100644
--- a/regress/core/mvt.sql
+++ b/regress/core/mvt.sql
@@ -707,7 +707,7 @@ SELECT '#4348Reversed2', ST_NPoints(ST_AsMVTGeom(
     2048,
     8,
     true
-    ))  BETWEEN 2150 AND 2250;
+    ))  BETWEEN 2140 AND 2250;
 SELECT '#4348Point', ST_AsMVTGeom(
     ST_GeomFromTWKB('\x06002309ee39cc89e70dc491e30348347411ce01c40110ce02b001c602033c3d48139a015a8e011b281e3e900176151426500382012fba011cf2028e019e027a8e015ac6022a2a0f3a9602b602420d3722185e536c2dca01620ce604f203be01e2018c01fa01141901404adc010eaa0124002304057a437087012c6f17533e1b4a08ba023daa0187017ea7011861314aa30173b801570d241c274655088501580e2d230303ae01768401205e1774340b3c5ebe01445219e001a301067dc6014bd4031ef4068e011855005ec606b2018802c6019001259a03a001183f1542cc01547c9e0120113e342a60dc012e5296011d2834369802689202da01141dba018c0148079c02c8014a0c08460c39ae046ade020fdc02420024361b80033c6a220224360fc4014a1fac02d004ec01218e011098014686017c6aaf01f5011191011c8b01423014b20162a001202b940357e40254a002b401240fbf02b301df013b8d0119b1024a49f1018e028b020041be010106f201920103038f019e020508a00304c502ca0347c6012a0834161d90025a88049a02fe03d202f602a002c601de019001c40216ec012b6e89016e51370135270021b801270e1c1e210668dc01094e3cb8017c50b8010594015a92010f003598018d0102453e3b96011fa4025c141f251d3a41a802df
 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
 191018b013bad0250bb016d71e3010afb014d8f0187016f1559326f0a93019601b7028a05f9072c1d1a240849ba013e7609ad01150149328b017e8b018405b60245c801bc0187036fb401bf015b224d3719234e8903bd0194014b4088012b7fb101a70136221a213551227d55e7010181021f020c57588b01c801e5011cd70288038b032d0407492738370f8b017f568902b801e701e402a302e4068503f608f102f806cf01aa0cc901a60725cc0612ca0272b604940396021e04363451281e4431ca0215d4028b018c01280c37e602734631165b9c02d1028102b905ae01ef021543ac01e7010347556b546d6f648502c1019702c7057191039301a101398d012bd9035332c50224850137cf01d5056f052f46a001a8014ab60233086b9d019c0186022201229c014d52e9027a2b2d528301129d02159c0251820104d902252c21ac04e701bc0136ba0213a6012b1a0b82017dd401531a06486f5eab0101d7019b017f21ef020ead0eaf04d001f306300a8008d306f205a904222b068901660406a806b806348001581c5e281517511ea70172fb02ad010a13f1019c010f31bd024b3544df015247a8019502250b8e01d501dc02ff029c03df02e0049303ba058502ce0371da0357bc05178403486c98012f722a1101703c1a0862a00158ae012bec01ab01e203c501b20397038e0584019a
 07bc02a409cc04f604a003034e64aa01503824132852a201188e02b001222a339a01429301aa0116f101900a880187059e024a45f60324101a338c014013348201506b9202ff019c014b07313327cb0133012738ab019101a201a20161a6010c9201355e323a9e01037c5c2ec0024c6e840152de14b0010dff0100ec01c502114e810aae010a1e9a02139902f4012ba001e00471d5038401251e6c0f7b380e17159c013152c002bb0112480c451a481609217e2162f202d3025c1f5918625c1738da017730340f052854211c70a70124061aa6013112489b037af205c3018a02fe02c20255bd02468501bd01a80145cc019f018c0261aa04017455b403ab01ec0308ac013115e601b3025ec0025516ed01e809bb023290028e02068302112f8702581b8a032b86045246326f306c940190016169675e1aea02399c02668e02e2014fa601f3012f88024258af01ac026c47b201b2015697015754cf01820227be013cd801a6016ebc011642850182019d013dae0152ca02c502b0029e0143624a595a44112236031f2e242bb801840119221e1f40309701d60181038f0220414d70b803b402dc04ae020c1b4b1d142fa2015dd6012e729001d202cf01d6011b8801284a580b2c370e2024151258621532430a4405022e650e0022ea01212cb2023107128a011ab40130050e6e9e02210d42300
 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
 106fe0154e801c00663b601ce06f20dc20eea07d901ac02f809d007ab03e502c201f901ec04e003779e01d2019202b30191028c01a5018002e002e2019f018501c1015e4b96011c8a01c6019702cc01203c5b545b574866a301764ad00359a8078e010e34a504365192010317f2044492012b8f0116cd01f001bf019e011553de027b9801591f4c20af018c042503301023b001371a2b4b0b733e394736029c0153010841dd021c32020442410e029c013230157a70de0247705a9801017e605e6cec01a20237fe01b701cc022ff80117b6019201b0031fb206ff04a701e101fc02d701548201f4023f22d4018502281bfe01c6099a01fc0cea021429ac03c0010d1c600800220c1d60061519382f1d0b1225c103dd05b7019901e9051bd10133074d4c1019172643980407f60238f601a001ac02c0031b1e4c7a43751a1b94016c2130342a151e4319ce01a2012e2f8401581d488c018e0117201e234c3c25342834ff019e01c00eac0de60abb0405599705dd0440ef0163f801cb03be01d103a9031f4dd409fb032e2a233380016b50446f7e2b119807c4068a10d10659df01bd036b439d02ca0377a6035e388002298002672c8001272a8102459302cc0260762f64632ab50241db0224354329d501d9033317f701cb02910113153d0f2c631581015beb01a10439ed022aa901465d8a01
 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
 dab037a4fc6013aca032f5e810209b7022c7398039b04e001cf01ec015dd0022b66025c427c1196028901be033d268c02d2010c1a50f301a80605ce05aa090439e90cca010624238a0128fc01dc016378034c76bd011c161d325e202c449301ba0153631e449e0180014092020bb20333048302d803cf013819e4021e0a1ce302b0013bea01ab03260327b403f1017c2b800bc8090f460708532c011c40037f17382d00079f02b6010502d502a00269b001dc01d001768902c5018302dd03078f03f6020912d803a604139007d301285519c901fe0123a101940443023e0c154edb02d201cb03e20301c804f6020e16a9058405e903b0089701002526228e0447be04d4030625cb03ef028c018f012f194bad010161464b620c0f482b05b6024c39150827c80168b101d001b50130c8029a026631417f8e03cf01074d76022ab0039505da02c90108032ad20117b805db0249cd05e4024d9a01d101fa01830110734666e6013d034d0e4c5213343676170d752678aa0385012d713c6e280dd603ed02032999015fb401684c270d3bab016f520e27512c260025705d5e1d17393446193f5011132b1c260a278601511588013e48329d01729301c8027d23774462ac02a301115520508e011b024d224cd80422880129ea014c14640059360bc0052dda01c603b0019c013762d802308004009a
 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
 9701c601738f012a8f01150b355e0c5e50622f3a14582712321a28ee014db80243626f362e9c0342c20139e201123e4358af02445d409301840153a20154ca01ae01ce01076e3608aa01c001e002fa0366d602079401358201329e0103d801d60171b20320800134fc011bf4028c013c5a1f38289001a001498601062c1e0f52460d284b2a2878022e620158db7aba0a5a53a80201a4027be20112425bb402579601752c160247e202bd036891021a9d022b5b36c3010b8301352f176d584163a704b201e70125c301bd015f1ca70127a001d702af0163615c6c9e04940220b8015f8201870147182da10153286f77ea01c501650fbd012202066719000d5a00575f0002a001cb01010d8d01008e01c901081967d201cf011919dd03c4030f7c2430a702ce01ab01a802310a1c20558001e7025835b6019d01ac0145c801a101743b480a2c352213341a4e235e470e24201b2e281c5364204a179c013c1a36e8015866e4013a5a7eb20209083c9201063250243f0104d2da0a8c4f00009c02509b024f0152cbf008d6484039820102a8038f01a8021eae05fd019202a50190011d880795056aa9018a01db03465ba401394e768e012bdc013a5277673b2a81018f019901a5021459218504ea03f7011aa70143b30103d905d40195015bd701228f02b401371f0c296b331a391f3ed9019d019
 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'::bytea),
Summary of changes:
 LICENSE.TXT                                        |   7 +-
 NEWS                                               |   1 +
 deps/wagyu/README.md                               |   1 +
 .../mapbox/geometry/wagyu/active_bound_list.hpp    |   8 +-
 .../include/mapbox/geometry/wagyu/almost_equal.hpp | 277 +++++++++++++++++++++
 .../include/mapbox/geometry/wagyu/interrupt.hpp    |   2 +-
 .../mapbox/geometry/wagyu/process_horizontal.hpp   |   8 +-
 .../include/mapbox/geometry/wagyu/ring_util.hpp    |  28 ++-
 deps/wagyu/include/mapbox/geometry/wagyu/util.hpp  |  17 +-
 deps/wagyu/include/mapbox/geometry/wagyu/wagyu.hpp |   4 +-
 regress/core/mvt.sql                               |   2 +-
 11 files changed, 324 insertions(+), 31 deletions(-)
 create mode 100644 deps/wagyu/include/mapbox/geometry/wagyu/almost_equal.hpp
hooks/post-receive
