[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-108-g7fba105
Fri May 8 08:50:19 PDT 2020
the project "PostGIS".
       via  7fba105294a1207dfa9949cbedc804ca4ff1aeb0 (commit)
       via  343bd459964cec07ca44c47850e49ad1747e0dc5 (commit)
      from  9e5df19ed0a3fca351fa6c72ea8ca702fb64da2e (commit)
revisions in full, below.
commit 7fba105294a1207dfa9949cbedc804ca4ff1aeb0
Merge: 343bd45 9e5df19
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri May 8 08:49:58 2020 -0700
    Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit 343bd459964cec07ca44c47850e49ad1747e0dc5
Date:   Fri May 8 08:49:44 2020 -0700
    add a test using ST_MaximumInscribedCircle on the target list
diff --git a/regress/core/geos39.sql b/regress/core/geos39.sql
index b3a1d8f..38799f5 100644
--- a/regress/core/geos39.sql
+++ b/regress/core/geos39.sql
@@ -26,3 +26,9 @@ SELECT 'mic-point' AS name, st_astext(center) AS center,
        st_astext(nearest) AS nearest,
        round(radius::numeric,4) AS radius
 FROM ST_MaximumInscribedCircle('POINT(0 0)'::geometry);
+WITH p AS (
+	SELECT 'Polygon((0 0, 100 0, 100 100, 0 100, 0 0))'::geometry AS ply
+SELECT 'mic-cte' AS name, ST_AsText((ST_MaximumInscribedCircle(ply)).center)
+	FROM p;
diff --git a/regress/core/geos39_expected b/regress/core/geos39_expected
index 8f7a584..29bf00b 100644
--- a/regress/core/geos39_expected
+++ b/regress/core/geos39_expected
@@ -4,3 +4,4 @@ mic-null|||
 mic-line|POINT(50 50)|POINT(50 0)|50.0000
 mic-mpoint|POINT(50 50)|POINT(0 0)|70.7107
 mic-point|POINT(0 0)|POINT(0 0)|0.0000
+mic-cte|POINT(50 50)
Summary of changes:
 regress/core/geos39.sql      | 6 ++++++
 regress/core/geos39_expected | 1 +
 2 files changed, 7 insertions(+)
hooks/post-receive
