[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-109-g3cf8e87
Fri May 8 08:51:22 PDT 2020
the project "PostGIS".
       via  3cf8e87779a6657c95b094abca76ebd9419e3e08 (commit)
      from  7fba105294a1207dfa9949cbedc804ca4ff1aeb0 (commit)
revisions in full, below.
commit 3cf8e87779a6657c95b094abca76ebd9419e3e08
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri May 8 08:51:19 2020 -0700
    remove duped defn of ST_FrechetDistance
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 3d72810..9b662c8 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3550,13 +3550,6 @@ CREATE OR REPLACE FUNCTION ST_FrechetDistance(geom1 geometry, geom2 geometry, fl
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_HIGH;
--- Availability: 2.4.0
-CREATE OR REPLACE FUNCTION ST_FrechetDistance(geom1 geometry, geom2 geometry, float8 default -1)
-	RETURNS FLOAT8
-	AS 'MODULE_PATHNAME', 'ST_FrechetDistance'
-	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
-	_COST_HIGH;
 -- Availability: 3.1.0
 CREATE OR REPLACE FUNCTION ST_MaximumInscribedCircle(geometry, OUT center geometry, OUT nearest geometry, OUT radius double precision)
 	AS 'MODULE_PATHNAME', 'ST_MaximumInscribedCircle'
Summary of changes:
 postgis/postgis.sql.in | 7 -------
 1 file changed, 7 deletions(-)
hooks/post-receive
