[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-110-gecae381
Fri May 8 09:16:55 PDT 2020
the project "PostGIS".
       via  ecae381d1b69ae00bb663ef76edf0d24ee7a950a (commit)
      from  3cf8e87779a6657c95b094abca76ebd9419e3e08 (commit)
revisions in full, below.
commit ecae381d1b69ae00bb663ef76edf0d24ee7a950a
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 8 16:55:54 2020 +0200
    Implement GetRingEdges in C
    Closes #4675
diff --git a/NEWS b/NEWS
index 7203935..44b4f23 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,7 @@ Only tickets not included in 3.1.0alpha1
 * Enhancements *
+  - #4675, topology.GetRingEdges now implemented in C (Sandro Santilli)
   - #4681, ST_GetFaceGeometry: print corruption information (Sandro Santilli)
   - #4651: ST_Simplify: Don't copy if nothing is removed (Raúl Marín)
   - #4657: Avoid De-TOASTing where possible (Paul Ramsey)
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 46c245d..832f367 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -4951,3 +4951,130 @@ Datum TopoGeo_AddPolygon(PG_FUNCTION_ARGS)
   SRF_RETURN_NEXT(funcctx, result);
+/*  GetRingEdges(atopology, anedge, maxedges default null) */
+Datum GetRingEdges(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(GetRingEdges);
+  text* toponame_text;
+  char* toponame;
+  LWT_ELEMID edge_id;
+  int maxedges = 0;
+  uint64_t nelems;
+  LWT_ELEMID *elems;
+  LWT_BE_TOPOLOGY *topo;
+  FuncCallContext *funcctx;
+  MemoryContext oldcontext, newcontext;
+  FACEEDGESSTATE *state;
+  Datum result;
+  HeapTuple tuple;
+  Datum ret[2];
+  bool isnull[2] = {0,0}; /* needed to say neither value is null */
+  if (SRF_IS_FIRSTCALL())
+    POSTGIS_DEBUG(1, "GetRingEdges first call");
+    funcctx = SRF_FIRSTCALL_INIT();
+    newcontext = funcctx->multi_call_memory_ctx;
+    if ( PG_ARGISNULL(0) )
+      lwpgerror("GetRingEdges: topology name cannot be null");
+      PG_RETURN_NULL();
+    toponame_text = PG_GETARG_TEXT_P(0);
+    toponame = text_to_cstring(toponame_text);
+    PG_FREE_IF_COPY(toponame_text, 0);
+    if ( PG_ARGISNULL(1) )
+      lwpgerror("GetRingEdges: edge id cannot be null");
+      PG_RETURN_NULL();
+    edge_id = PG_GETARG_INT32(1) ;
+    if ( ! PG_ARGISNULL(2) )
+      maxedges = PG_GETARG_INT32(2) ;
+    if ( SPI_OK_CONNECT != SPI_connect() )
+      lwpgerror("Could not connect to SPI");
+      PG_RETURN_NULL();
+      int pre = be_data.topoLoadFailMessageFlavor;
+      be_data.topoLoadFailMessageFlavor = 1;
+      topo = cb_loadTopologyByName(&be_data, toponame);
+      be_data.topoLoadFailMessageFlavor = pre;
+    oldcontext = MemoryContextSwitchTo( newcontext );
+    pfree(toponame);
+    if ( ! topo )
+      /* should never reach this point, as lwerror would raise an exception */
+      SPI_finish();
+      PG_RETURN_NULL();
+    POSTGIS_DEBUG(1, "Calling cb_getRingEdges");
+    elems = cb_getRingEdges(topo, edge_id, &nelems, maxedges);
+    POSTGIS_DEBUG(1, "cb_getRingEdges returned");
+    cb_freeTopology(topo);
+    if ( ! elems )
+      SPI_finish();
+      PG_RETURN_NULL();
+    state = lwalloc(sizeof(FACEEDGESSTATE));
+    state->elems = elems;
+    state->nelems = nelems;
+    state->curr = 0;
+    funcctx->user_fctx = state;
+    POSTGIS_DEBUG(1, "GetRingEdges calling SPI_finish");
+     * Get tuple description for return type
+    get_call_result_type(fcinfo, 0, &funcctx->tuple_desc);
+    BlessTupleDesc(funcctx->tuple_desc);
+    MemoryContextSwitchTo(oldcontext);
+    SPI_finish();
+  POSTGIS_DEBUG(1, "Per-call invocation");
+  /* stuff done on every call of the function */
+  funcctx = SRF_PERCALL_SETUP();
+  /* get state */
+  state = funcctx->user_fctx;
+  if ( state->curr == state->nelems )
+    POSTGIS_DEBUG(1, "We're done, cleaning up all");
+    SRF_RETURN_DONE(funcctx);
+  edge_id = state->elems[state->curr++];
+  POSTGIS_DEBUGF(1, "GetRingEdges: cur:%d, val:%" LWTFMT_ELEMID,
+                 state->curr-1, edge_id);
+  ret[0] = Int32GetDatum(state->curr);
+  ret[1] = Int64GetDatum(edge_id);
+  tuple = heap_form_tuple(funcctx->tuple_desc, ret, isnull);
+  result = HeapTupleGetDatum(tuple);
+  SRF_RETURN_NEXT(funcctx, result);
diff --git a/topology/sql/query/GetRingEdges.sql.in b/topology/sql/query/GetRingEdges.sql.in
index 7b85ee5..8670adb 100644
--- a/topology/sql/query/GetRingEdges.sql.in
+++ b/topology/sql/query/GetRingEdges.sql.in
@@ -38,43 +38,7 @@
 -- GetRingEdges(atopology, anedge, [maxedges])
 CREATE OR REPLACE FUNCTION topology.GetRingEdges(atopology varchar, anedge int, maxedges int DEFAULT null)
-	RETURNS SETOF topology.GetFaceEdges_ReturnType
-AS
-DECLARE
-  rec RECORD;
-  retrec topology.GetFaceEdges_ReturnType;
-  n int;
-  sql text;
-BEGIN
-  sql := 'WITH RECURSIVE edgering AS ( SELECT '
-    || anedge
-    || ' as signed_edge_id, edge_id, next_left_edge, next_right_edge FROM '
-    || quote_ident(atopology)
-    || '.edge_data WHERE edge_id = '
-    || abs(anedge)
-    || ' UNION '
-    || ' SELECT CASE WHEN p.signed_edge_id < 0 THEN p.next_right_edge '
-    || ' ELSE p.next_left_edge END, e.edge_id, e.next_left_edge, e.next_right_edge '
-    || ' FROM ' || quote_ident(atopology)
-    || '.edge_data e, edgering p WHERE e.edge_id = CASE WHEN p.signed_edge_id < 0 '
-    || 'THEN abs(p.next_right_edge) ELSE abs(p.next_left_edge) END ) SELECT * FROM edgering';
-  n := 1;
-  FOR rec IN EXECUTE sql
-  LOOP
-    retrec.sequence := n;
-    retrec.edge := rec.signed_edge_id;
-    RETURN NEXT retrec;
-    n := n + 1;
-    IF n > maxedges THEN
-      RAISE EXCEPTION 'Max traversing limit hit: %', maxedges;
-    END IF;
-  END LOOP;
-END
-LANGUAGE 'plpgsql' STABLE;
+	RETURNS SETOF topology.GetFaceEdges_ReturnType AS
+	'MODULE_PATHNAME', 'GetRingEdges'
+LANGUAGE 'c' STABLE;
 --} GetRingEdges
Summary of changes:
 NEWS                                   |   1 +
 topology/postgis_topology.c            | 127 +++++++++++++++++++++++++++++++++
 topology/sql/query/GetRingEdges.sql.in |  42 +----------
 3 files changed, 131 insertions(+), 39 deletions(-)
hooks/post-receive
