[postgis-tickets] [PostGIS] #4689: Error using ST_Intersects in WHERE clause
PostGIS trac at osgeo.org
Wed May 13 02:16:48 PDT 2020
 Reporter:  tsc      |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:
Component:  postgis  |    Version:  3.0.x
 Keywords:           |
 After an upgrade from PSQL11 with PostGIS 2.53 to PSQL12 with PostGIS
 3.0.1 I am encountering a bug. The following query is minimal,
 reproducible example of the problem:
 SELECT * FROM
 (VALUES
  ('POLYGON((30 10, 40 40, 20 40, 30 10))'::geography),
  ('POLYGON((81 6,140 35,-70 18,-51 0,-60 -46,106 -6,81 6))'::geography)
 ) AS t (v)
 WHERE (ST_INTERSECTS(t.v, 'POLYGON ((30 10, 40 40, 20 40, 30
 10))'::geography))
 This outputs:
 ERROR:  CircTreePIP: Unable to generate outside point!
 SQL state: XX000
 Version on system producing the error:
 PostgreSQL 12.2 (Ubuntu 12.2-4) on x86_64-pc-linux-gnu, compiled by gcc
 (Ubuntu 9.3.0-8ubuntu1) 9.3.0, 64-bit POSTGIS="3.0.1 ec2a9aa" [EXTENSION]
 PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 " PROJ="6.3.1" LIBXML="2.9.10"
 LIBJSON="0.13.1" LIBPROTOBUF="1.3.3" WAGYU="0.4.3 (Internal)"
 Running the same query with following versions works as expected:
 PostgreSQL 11.6 (Ubuntu 11.6-1.pgdg18.04+1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0, 64-bit
 POSTGIS="2.5.3 r17699" [EXTENSION] PGSQL="110" GEOS="3.7.1-CAPI-1.11.1
 27a5e771" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, released
 2017/11/20" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" RASTER
 **More details:**
 - The problem only occurs when multiple rows are selected - select each of
 the rows in separate queries works.
 - The error only occurs when the ST_INTERSECT is in the WHERE-clause,
 having it in the SELECT doesn't result in the error.
 - The error only occurs with geography, using geometry instead works fine.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4689>
