[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-121-g130fdf6
Fri May 15 07:17:05 PDT 2020
the project "PostGIS".
       via  130fdf694621d0406f09f880ec85715f1aa1571f (commit)
      from  4c185f8617824a21f46569170dd16c3427e1b197 (commit)
revisions in full, below.
commit 130fdf694621d0406f09f880ec85715f1aa1571f
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 15 16:16:12 2020 +0200
    Add section about managing stats during topology building/editing
    And refs to it from TopoGeo_addLineString and TopoGeo_addPolygon
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 8a3fe0a..8867b04 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -643,6 +643,44 @@ face without edges |   0 |
 		</refentry>
 	</sect2>
+	<sect2 id="Topology_StatsManagement"
+           xreflabel="maintaining statistics during topology editing and population" >
+	     <sect2info>
+            <abstract>
+                <para>
+This section discusses management of database statistics during
+topology building.
+                </para>
+            </abstract>
+        </sect2info>
+	    <title>Topology Statistics Management</title>
+<para>
+Adding elements to a topology triggers many database queries for
+finding existing edges that will be split, adding nodes and and
+updating edges that will node with the new linework. For this reason
+it is useful that statistics about the data in the topology tables
+are up-to-date.
+</para>
+<para>
+PostGIS Topology population and editing functions do not automatically
+update the statistics because a updating stats after each and every
+change in a topology would be overkill, so it is the caller's duty
+to take care of that.
+</para>
+<note>
+<para>
+That the statistics updated by autovacuum
+will NOT be visible to transactions which started before autovacuum
+process completed, so long-running transactions will need to run
+ANALYZE themeselves, to use updated statistics.
+</para>
+</note>
+	</sect2>
 	<sect2 id="Topology_Constructors">
     <sect2info>
         <abstract>
@@ -959,6 +997,11 @@ The given line will snap to existing nodes or edges within given tolerance.
 Existing edges and faces may be split by the line.
                 </para>
+                <note><para>
+Updating statistics about topologies being loaded via this function is
+up to caller, see <xref linkend="Topology_StatsManagement"/>.
+                </para></note>
                 <!-- use this format if new function -->
                 <para>Availability: 2.0.0</para>
 			</refsection>
@@ -1003,6 +1046,11 @@ The boundary of the given polygon will snap to existing nodes or edges within gi
 Existing edges and faces may be split by the boundary of the new polygon.
                 </para>
+                <note><para>
+                </para></note>
 			</refsection>
Summary of changes:
 doc/extras_topology.xml | 48 ++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 48 insertions(+)
hooks/post-receive
