[postgis-tickets] [PostGIS] #4779: server process (PID 49666) was terminated by signal 6: Aborted, munmap_chunk(): invalid pointer
PostGIS trac at osgeo.org
Sun Nov 1 21:42:00 PST 2020
  Reporter:  laopsahl  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.1.0
 Component:  postgis   |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by robe):
 Ah I see you are using raster so that is probably the issue.  As mentioned
 bring it oup on pgsql-pkg-yum.  I think yum ships both proj and gdal.  So
 it seems it was compiled with different versions which is bad.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4779#comment:5>
