[postgis-tickets] [PostGIS] #4779: server process (PID 49666) was terminated by signal 6: Aborted, munmap_chunk(): invalid pointer
PostGIS trac at osgeo.org
Mon Nov 2 00:52:07 PST 2020
  Reporter:  laopsahl  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.1.0
 Component:  postgis   |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by laopsahl):
 Yes I am using yum .
 Her is a update from magnus.hagander at redpill-linpro.com while he is
 waiting for OSGeo userid
 [root at dd4500a87f1b /]# ldd /usr/pgsql-12/lib/postgis-3.so |grep proj
         libproj.so.15 => /lib64/libproj.so.15 (0x00007fd55f797000)
 [root at dd4500a87f1b /]# ldd /usr/pgsql-12/lib/postgis_raster-3.so |grep
 proj
         libproj.so.15 => /lib64/libproj.so.15 (0x00007fe056242000)
         libproj.so.19 => /usr/proj71/lib/libproj.so.19
 (0x00007fe04713c000)
 And from gdal
 # ldd /usr/gdal31/lib/libgdal.so.27|grep proj
         libproj.so.15 => /lib64/libproj.so.15 (0x00007f91d168c000)
 (0x00007f91c7a88000)
 gdal are linked against libspataialite:
 # ldd /usr/gdal31/lib/libgdal.so.27|grep spatialite
         libspatialite.so.7 => /lib64/libspatialite.so.7
 (0x00007f6228a8f000)
 # ldd /lib64/libspatialite.so.7|grep proj
         libproj.so.15 => /lib64/libproj.so.15 (0x00007ff5399e5000)
 gdal -> proj19
 So here is the problem :** gdal -> spatialite -> proj 17**
 postgis_raster linkes against gdal...
 Magnus has sent message to Devrim.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4779#comment:6>
