[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-145-g6812b00
Thu Nov 5 09:00:20 PST 2020
the project "PostGIS".
       via  6812b00ed6195e151d04be8c78aa8f1c20c628ea (commit)
      from  04ecdcb2568e27e9a46e1849e002ba24299cb80a (commit)
revisions in full, below.
commit 6812b00ed6195e151d04be8c78aa8f1c20c628ea
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Nov 5 08:59:39 2020 -0800
    Add ST_CollectionExtract(geometry)
    with a behaviour of extracting
    the primitive geometry (point/line/poly) with the highest coordinate
    dimension. So a collection of lines and polys will result in a
    multipoly output. A collection of lines and points will result in a
    multiline output.
    Closes #4784
diff --git a/NEWS b/NEWS
index ec3545c..4ef2903 100644
--- a/NEWS
+++ b/NEWS
@@ -38,6 +38,8 @@ Only tickets not included in 3.1.0alpha2
   - #4746, Micro optimizations to the serialization process (Raúl Marín)
   - #4719, Fail fast when srids don't match ST_Intersection(geometry,raster)
             Also schema qualify calls in function. (Regina Obe)
+  - #4784, Add ST_CollectionExtract(geometry) with default behaviour of
+           extracting the components of highest coordinate dimension. (Paul Ramsey)
 * Bug fixes *
   - #4691, Fix segfault during gist index creation with empty geometries (Raúl Marín)
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 7e52ea2..ddb0de9 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -76,26 +76,35 @@ Given a (multi)geometry, return a (multi)geometry consisting only of elements of
 			  <funcprototype>
 				<funcdef>geometry <function>ST_CollectionExtract</function></funcdef>
 				<paramdef><type>geometry </type> <parameter>collection</parameter></paramdef>
-				<paramdef><type>integer </type> <parameter>type</parameter></paramdef>
 			  </funcprototype>
 			</funcsynopsis>
+            <funcsynopsis>
+              <funcprototype>
+                <funcdef>geometry <function>ST_CollectionExtract</function></funcdef>
+                <paramdef><type>geometry </type> <parameter>collection</parameter></paramdef>
+                <paramdef><type>integer </type> <parameter>type</parameter></paramdef>
+              </funcprototype>
+            </funcsynopsis>
 		</refsynopsisdiv>
 		<refsection>
 			<title>Description</title>
-			<para>
-Given a (multi)geometry, returns a (multi)geometry consisting only of elements of the specified type.
-Sub-geometries that are not the specified type are ignored. If there are no sub-geometries of the right type, an EMPTY geometry will be returned.
-Only points, lines and polygons are supported. Type numbers are 1 == POINT, 2 == LINESTRING, 3 == POLYGON.
-			</para>
+			<para>Given a geometry collection, return a homogeneous multi-geometry.
+            If the type is specified, return a multi-geometry containing only that type, and an EMPTY multigeometry otherwise. If the type is not specified, return a multi-geometry containing only geometries of the highest coordinate dimension. So polygons are preferred over lines, which are preferred over points. Sub-geometries that are not the desired type are ignored. If there are no sub-geometries of the right type, an EMPTY geometry will be returned. </para>
+            <para>Only points, lines and polygons are supported. The type numbers are:</para>
+            <itemizedlist>
+            <listitem><para>1 == POINT</para></listitem>
+            <listitem><para>2 == LINESTRING</para></listitem>
+            <listitem><para>3 == POLYGON</para></listitem>
+            </itemizedlist>
 			<para>Availability: 1.5.0</para>
 			<note><para>
-Prior to 1.5.3 this function returned non-collection inputs untouched, no matter type.
-In 1.5.3 non-matching single geometries result in a NULL return.
-In of 2.0.0 every case of missing match results in a typed EMPTY return.
+            Prior to 1.5.3 this function returned non-collection inputs untouched, no matter type.
+            In 1.5.3 non-matching single geometries result in a NULL return.
+            In 2.0.0 every case of missing match results in a typed EMPTY return.
 			</para></note>
 			<warning><para>When specifying 3 == POLYGON a multipolygon is returned even when the edges are shared.  This results in an invalid multipolygon for many cases
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index f44588f..57d7f32 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1197,10 +1197,7 @@ extern LWGEOM *lwgeom_homogenize(const LWGEOM *geom);
 LWGEOM *lwcollection_getsubgeom(LWCOLLECTION *col, int gnum);
-/* WARNING: the output will contain references to geometries in the input, */
-/* so the result must be carefully released, not freed. */
-LWCOLLECTION* lwcollection_extract(LWCOLLECTION *col, int type);
+LWCOLLECTION* lwcollection_extract(const LWCOLLECTION *col, uint32_t type);
diff --git a/liblwgeom/lwcollection.c b/liblwgeom/lwcollection.c
index e64d723..6d5c5ce 100644
--- a/liblwgeom/lwcollection.c
+++ b/liblwgeom/lwcollection.c
@@ -376,112 +376,102 @@ void lwcollection_free(LWCOLLECTION *col)
 	lwfree(col);
-* Takes a potentially heterogeneous collection and returns a homogeneous
-* collection consisting only of the specified type.
-* WARNING: the output will contain references to geometries in the input,
-* so the result must be carefully released, not freed.
+* Examines contents of collection and finds the largest coordinate
+* dimension of all components. Areal > linear > puntal.
-LWCOLLECTION*
-lwcollection_extract(LWCOLLECTION* col, int type)
+static uint32_t
+lwcollection_largest_dimension(const LWCOLLECTION *col)
-	uint32_t i = 0;
-	LWGEOM** geomlist;
-	LWCOLLECTION* outcol;
-	int geomlistsize = 16;
-	int geomlistlen = 0;
-	uint8_t outtype;
-	if (!col) return NULL;
-	switch (type)
+	int largest_type = 0;
+	size_t i;
+	for (i = 0; i < col->ngeoms; i++)
-	case POINTTYPE:
-		outtype = MULTIPOINTTYPE;
-		break;
-	case LINETYPE:
-		outtype = MULTILINETYPE;
-		break;
-	case POLYGONTYPE:
-		outtype = MULTIPOLYGONTYPE;
-		break;
-	default:
-		lwerror(
-		    "Only POLYGON, LINESTRING and POINT are supported by "
-		    "lwcollection_extract. %s requested.",
-		    lwtype_name(type));
-		return NULL;
+		LWGEOM *g = col->geoms[i];
+		int gtype = lwgeom_get_type(g);
+		if (lwgeom_is_collection(g))
+			gtype = lwcollection_largest_dimension((LWCOLLECTION*)g);
+		if (gtype == POINTTYPE || gtype == LINETYPE || gtype == POLYGONTYPE)
+			if (gtype > largest_type)
+				largest_type = gtype;
+	return largest_type;
-	geomlist = lwalloc(sizeof(LWGEOM*) * geomlistsize);
+static int
+lwcollection_extract_recursive(const LWCOLLECTION* col, uint32_t type, LWCOLLECTION *col_out)
+	size_t i;
+	size_t geoms_added = 0;
-	/* Process each sub-geometry */
-		int subtype = col->geoms[i]->type;
-		/* Don't bother adding empty sub-geometries */
-		if (lwgeom_is_empty(col->geoms[i])) continue;
-		/* Copy our sub-types into the output list */
-		if (subtype == type)
-			/* We've over-run our buffer, double the memory segment
-			if (geomlistlen == geomlistsize)
-				geomlistsize *= 2;
-				geomlist = lwrealloc(
-				    geomlist, sizeof(LWGEOM*) * geomlistsize);
-			geomlist[geomlistlen] = lwgeom_clone(col->geoms[i]);
-			geomlistlen++;
+			LWCOLLECTION *col_part = lwgeom_as_lwcollection(g);
+			geoms_added += lwcollection_extract_recursive(col_part, type, col_out);
-		/* Recurse into sub-collections */
-		if (lwtype_is_collection(subtype))
+		if (lwgeom_get_type(g) == type && !lwgeom_is_empty(g))
-			uint32_t j = 0;
-			LWCOLLECTION* tmpcol = lwcollection_extract(
-			    (LWCOLLECTION*)col->geoms[i], type);
-			for (j = 0; j < tmpcol->ngeoms; j++)
-				 * segment */
-					geomlist = lwrealloc(geomlist,
-							     sizeof(LWGEOM*) *
-								 geomlistsize);
-				geomlist[geomlistlen] = tmpcol->geoms[j];
-				geomlistlen++;
-			if (tmpcol->ngeoms) lwfree(tmpcol->geoms);
-			if (tmpcol->bbox) lwfree(tmpcol->bbox);
-			lwfree(tmpcol);
+			lwcollection_add_lwgeom(col_out, lwgeom_clone(col->geoms[i]));
+			geoms_added++;
+	return geoms_added;
+LWCOLLECTION*
+lwcollection_extract(const LWCOLLECTION* col, uint32_t type)
+	LWCOLLECTION* outcol;
+	if (!col) return NULL;
-	if (geomlistlen > 0)
+	/* Self-discover output type when it is not specified */
+	if (!type)
+		type = lwcollection_largest_dimension(col);
+	* If self-discovery failed, there were no primitive points
+	* lines or polygons in the collection, so send back an
+	* empty collection.
+	if (!type)
-		GBOX gbox;
-		outcol = lwcollection_construct(
-		    outtype, col->srid, NULL, geomlistlen, geomlist);
-		lwgeom_calculate_gbox((LWGEOM*)outcol, &gbox);
-		outcol->bbox = gbox_copy(&gbox);
+		return lwcollection_construct_empty(COLLECTIONTYPE,
+	           col->srid,
+	           FLAGS_GET_Z(col->flags),
+	           FLAGS_GET_M(col->flags));
-	else
+	if (!(type == POINTTYPE || type == LINETYPE || type == POLYGONTYPE))
-		lwfree(geomlist);
-		outcol = lwcollection_construct_empty(outtype,
-						      col->srid,
-						      FLAGS_GET_Z(col->flags),
-						      FLAGS_GET_M(col->flags));
+		lwerror(
+		    "Only POLYGON, LINESTRING and POINT are supported by "
+		    "lwcollection_extract. %s requested.",
+		    lwtype_name(type));
+		return NULL;
+	outcol = lwcollection_construct_empty(lwtype_multitype(type),
+	           col->srid,
+	lwcollection_extract_recursive(col, type, outcol);
+	lwgeom_add_bbox(lwcollection_as_lwgeom(outcol));
 	return outcol;
 LWCOLLECTION*
 lwcollection_force_dims(const LWCOLLECTION *col, int hasz, int hasm, double zval, double mval)
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 1ca1bd5..34c1fea 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -1087,7 +1087,6 @@ lwgeom_is_collection(const LWGEOM *geom)
 int
 lwtype_is_collection(uint8_t type)
 	switch (type)
 	case MULTIPOINTTYPE:
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 964b7ae..7ec18bb 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -5418,22 +5418,22 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     if ( col )
-      col = lwcollection_extract(col, LINETYPE);
+      LWCOLLECTION *colex = lwcollection_extract(col, LINETYPE);
       /* Check if the so-snapped edge collapsed (see #1650) */
-      if ( col->ngeoms == 0 )
+      if ( colex->ngeoms == 0 )
-        lwcollection_free(col);
+        lwcollection_free(colex);
         lwgeom_free(tmp);
         LWDEBUG(1, "Made-valid snapped edge collapsed");
         return 0;
-      tmp2 = lwgeom_clone_deep( col->geoms[0] );
+      tmp2 = lwgeom_clone_deep(colex->geoms[0]);
       lwgeom_free(tmp);
       tmp = tmp2;
       edge = lwgeom_as_lwline(tmp);
       if ( ! edge )
         /* should never happen */
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 369ea1e..c5b9e30 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2713,47 +2713,47 @@ Datum ST_GeoHash(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(ST_CollectionExtract);
 Datum ST_CollectionExtract(PG_FUNCTION_ARGS)
-	GSERIALIZED *input = PG_GETARG_GSERIALIZED_P(0);
-	GSERIALIZED *output;
-	LWGEOM *lwgeom = lwgeom_from_gserialized(input);
-	LWGEOM *lwcol = NULL;
-	int type = PG_GETARG_INT32(1);
-	int lwgeom_type = lwgeom->type;
+	GSERIALIZED *gser_in, *gser_out;
+	LWGEOM *lwg_in = NULL;
+	LWGEOM *lwg_out = NULL;
+	int extype = 0;
+	if (PG_NARGS() > 1)
+		extype = PG_GETARG_INT32(1);
 	/* Ensure the right type was input */
-	if (!(type == POINTTYPE || type == LINETYPE || type == POLYGONTYPE))
+	if (!(extype == 0 || extype == POINTTYPE || extype == LINETYPE || extype == POLYGONTYPE))
-		lwgeom_free(lwgeom);
 		elog(ERROR, "ST_CollectionExtract: only point, linestring and polygon may be extracted");
 		PG_RETURN_NULL();
+	gser_in = PG_GETARG_GSERIALIZED_P(0);
+	lwg_in = lwgeom_from_gserialized(gser_in);
 	/* Mirror non-collections right back */
-	if (!lwgeom_is_collection(lwgeom))
+	if (!lwgeom_is_collection(lwg_in))
 		/* Non-collections of the matching type go back */
-		if (lwgeom_type == type)
+		if (lwg_in->type == extype || !extype)
-			PG_RETURN_POINTER(input);
+			lwgeom_free(lwg_in);
+			PG_RETURN_POINTER(gser_in);
 		/* Others go back as EMPTY */
 		else
-			lwcol = lwgeom_construct_empty(
-			    type, lwgeom->srid, lwgeom_has_z(lwgeom), lwgeom_has_m(lwgeom));
+			lwg_out = lwgeom_construct_empty(extype, lwg_in->srid, lwgeom_has_z(lwg_in), lwgeom_has_m(lwg_in));
+			PG_RETURN_POINTER(geometry_serialize(lwg_out));
-	else
-		lwcol = lwcollection_as_lwgeom(lwcollection_extract((LWCOLLECTION *)lwgeom, type));
-	output = geometry_serialize((LWGEOM *)lwcol);
-	lwgeom_free(lwcol);
+	lwg_out = (LWGEOM*)lwcollection_extract((LWCOLLECTION*)lwg_in, extype);
-	PG_RETURN_POINTER(output);
+	gser_out = geometry_serialize(lwg_out);
+	lwgeom_free(lwg_out);
+	PG_RETURN_POINTER(gser_out);
 PG_FUNCTION_INFO_V1(ST_CollectionHomogenize);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 226fdff..45b053a 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1402,6 +1402,13 @@ CREATE OR REPLACE FUNCTION ST_CollectionExtract(geometry, integer)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
+-- Availability: 3.1.0
+CREATE OR REPLACE FUNCTION ST_CollectionExtract(geometry)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'ST_CollectionExtract'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_LOW;
 -- Availability: 2.0.0
 CREATE OR REPLACE FUNCTION ST_CollectionHomogenize(geometry)
 	RETURNS geometry
Summary of changes:
 NEWS                             |   2 +
 doc/reference_editor.xml         |  27 ++++---
 liblwgeom/liblwgeom.h.in         |   5 +-
 liblwgeom/lwcollection.c         | 156 ++++++++++++++++++---------------------
 liblwgeom/lwgeom.c               |   1 -
 liblwgeom/lwgeom_topo.c          |  10 +--
 postgis/lwgeom_functions_basic.c |  44 +++++------
 postgis/postgis.sql.in           |   7 ++
 8 files changed, 128 insertions(+), 124 deletions(-)
hooks/post-receive
