[postgis-tickets] [PostGIS] #4725: ST_MakeValid causes drastic loss of precision
PostGIS trac at osgeo.org
Thu Nov 5 09:15:18 PST 2020
  Reporter:  atlight  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:
Changes (by pramsey):
 * milestone:  PostGIS 3.1.0 => PostGIS GEOS
Comment:
 As expected, this is a result of GEOS precision reduction routines in the
 old overlay engine trying to back off from repeated topology failures
 during overlay. And as hoped, the new overlay engine does not display the
 same behaviour. A valid output is generated, and the precision is
 basically the same.
 postgis31=# select st_xmin(ST_MakeValid(geom)) FROM a;
       st_xmin
  144.9632208323141
 (1 row)
 postgis31=# select st_xmin(geom) FROM a;
       st_xmin
  144.9632208323141
 (1 row)
 The solution will be to upgrade to GEOS 3.9 when it is released.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4725#comment:2>
